Repeater Double Kerchunk
BlueDevil
WA
I recently setup a Bendix King Rapid Deployment Portable Repeater. Everything seems to be operating normally however we are getting a double kerchunk after transmitting through the repeater. I haven't been able to isolate the cause. However I do know that it's not normal because we have other identical units that do not have this problem.
Any suggestions or ideas?
New York, NY
Sounds like you're not getting the PL turn-off code and are hearing noise before the squelch closes. Could be either on the uplink or downlink. You didn't specify what model of portables you are using. Do they have a "PL" setting on the squelch controls and are both radios set to that position?
BlueDevil
WA
We are using two Bendix King GPH5102XP VHF radios. We have the receive radio set to inhibit transmit and also has a RX PL/CG Tone. I do not recall if we put a TX PL/CG Tone on the transmit radio. I think that you are right on with your assessment of the problem. I am new to the programming of the BK radio however I have used this type of repeater multiple times with preprogrammed radios and never encountered anything like this before. The repeater is currently out in operation so I am not able to double check the settings.
