HP-2: Reviews
jonwienke
More Info Coming Soon!
VA
They don't do DMR or NXDN at all, and they suck at simulcast worse than every other scanner model I've tested. If any of those are on your listening wishlist, pass.
N9JIG
Sheriff
Moderator
Far NW Valley
While Jon is correct on the HP2, it is actually a good scanner if you do not have simulcast issues where you are. It is easy to set up after you update the database and you can create Favorites Lists once you get familiar with the radio. It does require a Windows computer to update it and run the free Sentinel software, the initial updates are pretty easy.
Programming Favorites Lists are a little more challenging but if you can follow the directions (or watch the several videos on it) it is pretty simple to figure it out.
jonwienke
VA
For simulcast, a SDS or Unication are your only options that will work consistently. And the Unications are only designed to monitor a single system--they aren't general-purpose scanners.
