Salem County P25 System
policefreak
Berlin, NJ
I'm in Malaga that puts me at where the Gloucester County, Cumberland County, and Salem County lines all meet. (My back yard is in Cumberland County) So I put the Salem County TRS in my SDS200 running ProScan in ID Searching. I will post IDs soon as I get a good list.
BTW for some reasons I get NJICS Berlin (Clayton) and Cumberland County (Vineland) sites also of course Gloucester County TRS (also Clayton), but cant get the Atlantic County's TRS here!
Mike N2ICV
Good, you should be pretty close to be able to hear Salem County from there. Your nearest tower site is in Pittsgrove not far from Schalick HS. Atlantic County has a dead spot down that way from Franklinville on down to Forest Grove. Not sure why. I actually thought the Mays Landing tower was the stronger in that area - but either one was poor.
policefreak
Berlin, NJ
Ah wow OK. Apparently Malaga is within the coverage area of Mays Landing/Egg Harbor City. Who woulda thunk it?
Yes. And sometimes those maps can be a little deceiving. Often they will not account for directional sites, terrain, etc. My experience has been that if you're using a portable SDS Scanner/Unication pager/radio with a portable antenna within about 7 miles of a site (especially on 700/800mhz) you have a decent chance of hearing it so long as you're not in a basement or bank vault. Beyond that, it really depends. With a better antenna I have heard the Atlantic County Mays Landing/EHC site in Willow Grove, PA almost 50 miles away. But with the same antenna it struggles in the more wooded areas around Franklinville and Malaga. Go figure.
N2ICV
Gloucester County FM29in
Photo is what I'm receiving, But no TG;s so far.
Whiskey3JMC - Ant is an COMET CX-333. 144 / 220 / 440 MHz Fiberglass Base Vertical Antenna feed with 30 + or - ft of LMR 400 @ Approximately 25 feet high. HASL is 69ft. and I get no P25 CCs on 800Mhz but a few on 700MHz.
policefreak
Berlin, NJ
Has anyone recorded any in the clear transmissions yet? Just curious. I am going to hook up my Unication G5 to my yagi and let it sit and record some weekday.
Whiskey3JMC
Don't feed the squirrels
Simulcastylvania, TE
Squelch is set to 10? Way too high, set it to 2 or 1. Any improvement? Try "invert" filter as well. This filter gives me the best results for the more distant 700 & 800 targets
neilhuss
Fire6man
Newark De
How are you guys listening to the system ? i have a sds 100 and im not able to search the system ?
N2ICV
Its set at 3 or 4 when scanning Conv and P25PII systems. I dont how it got to 10. But with the good RSSI and how close the site is it is working find, but its back to 0.
policefreak
Berlin, NJ
How far is that hospital from you? I'm almost willing to bet there's lots of cell towers and other transmitters on that building. Set your Squelch to 0. Use a dedicated 700/800mhz antenna. You can even press the CHANNEL button and manually tune to 774.40625 and press CHANNEL again. If you do that what happens. Are you hearing silence with a DATA icon or are you hearing noise? Is there maybe a sweet spot in your place? Just some things to consider.
