What I cannot figure out is why I am hearing CC signals on only one frequency, with a signal strength that varies between S0 and S3.
The CC is only on one frequency. All towers broadcast the same signal simultaneously on the same frequency. When voice channel(s) are actively transmitting, the same is true.
Phase differences between the several towers are controlled by system design and as long as you're inside the designed system coverage radius the phase differences are "guaranteed" to be below the applicable error thresholds. If you venture outside the zone three cases exist:
1) far enough out, you have total loss of signal
2) in range of a single tower, there is no simulcast distortion
3) in range of >1 tower, the possibility of partial or full cancellation exists (at random)
You should not expect the S meter (i.e., the receiver AGC line level) to display anything meaningful. There are at least two reasons. First, the several stations at the same time effect renders any quantitative interpretation of the result sort of ... redundant. Second, the waveform itself is not even "FM" (it contains distinct "AM" components). It's perfectly reasonable to get swings on the AGC line corresponding to 10-20 dB (minimum) variations in RSS over very short time periods (< 1 sec).
Also it's not possible to receive this stuff properly using FM demodulation. I don't know but I've been told that all scanner mfgr's today derive the digital baseband by tapping the FM discriminator after demodulation. While this works as designed for C4FM, it's inherently not suited for "CQPSK" in the presence of simulcast. The FM demodulation action effectively mangles the signal (irrevocably).
The solution is straightforward - tap the IF. Any good old 1980's scanner (PRO 2006) has basic RF performance (intermod etc.) FAR superior to today's models. Direct tap the IF of one of these and you get a receiver with superior performance due to
- improved RF-side (better intermod and spurious rejection)
- improved digital-side (reduction of troubles caused by simulcast)
Well I've hijacked the thread long enough? For more info you might check out my LSM gallery
LSM Gallery
73
Max
