Saratoga County TRS Official Thread
Warthog1
Silent Key
Northville, NY
I do know that somebody really had their act together when they designed this system. I am quite amazed at just how good it sounds. Now I just have to figure out how to get radio ID's on my PSR-600. I really don't think it is possible. I only have 4 P25 capable radios out of 13. I sure do hate the idea of shelling out another $500 just to read radio ID's !!
Warthog1
Silent Key
Northville, NY
Well it appears that the NYSP units are the only ones on the county 911 system that do not have UID's.
They come-up as '0". The rest appear as they are programmed by county.
Thanks for the suggestion of Unitrunker, Thunderknight...this makes it easier !!
Thunderknight
Bletchley Park
Glad it's working well. It is a powerful tool.
The NYSP units are probably still coming in on VHF 911 through some type of patch (as figured out by an earlier poster).
D
DaveNF2G
Guest
For P25 systems, I use PRO96COM for tracking and analysis. Unitrunker is too finicky for my taste, but I do use it occasionally for analog systems.
I was not "tracking" the system when I took my little drive last week. I was using my PSR-500 in Analyze mode. In that mode, it steps (manually) through all of the channels assigned to a trunked system (Saratoga County has 22 repeater pairs licensed beside the national Interop pairs which are not to be trunked). When a signal is detected, the S-meter indicates and, if it's a control channel, the SysID and tower ID and decode percentage are displayed.
Only one CC was ever detected. It was always on the 851 frequency that everyone has reported. Signal strength on the S-meter varied according to my elevation and my distance from the Barkersville tower. I have heard simulcast distortion on other frequencies (most notably 154.415 in Albany County), so I know what to listen for. I heard none on 800 MHz.
As for the Waterford testing, does anyone know for certain whether they were testing on the trunked system or on the simplex tactical channels?
As an aside, while monitoring VHF 9-1-1 the other night, COMSEC was complaining that mobiles in Clifton Park were unreadable.
D
DaveNF2G
Guest
To display RIDs on the PSR-500/600:
If you are using Don Starr's Win500, check the box "Show radio IDs for group calls" on the Extended Settings tab.
If you are not using Win500, then you are working much too hard. LOL.
I just checked my 600 and I can't locate that feature in the scanner's menus.
Warthog1
Silent Key
Northville, NY
OK...Thanks Dave. I use all BuTel software, so mine is ARC-500.
Unitrunker is working excellent for talkgroup and UID's. I'm seeing units log-in on new talkgroups.
We will get this thing nailed down.
As for Waterford, the techs have been testing radios on C-TAC (trunked) and occasionally on TAC-14 (also trunked). Not certain if any were Waterford units because I didn't have Unitrunker then. If I can isolate those units, I will let you know.
Thunderknight
Bletchley Park
That's analog simulcast. How about P25 simulcast? It will cause serious hits in the decode rate due to intersymbol interference which will affect both the audio and also the control channel decode. No "warbling or whining", just undecoded or extremely distorted audio and loss of control channel sync.
We have confirmed that there are at least 2 control channels active in this system with different site IDs, the one you heard and the one on 852.6 MHz that Warthog1 hears (not "everyone" is hearing only 1 as you state), which is licensed at Fraker (Edinburg) and Lakeview. We know Warthog1 is near Fraker and probably hearing that site since he states Lakeview is not built yet. That implies a multizone system. Quick look at the frequencies in the RR database shows a 3rd set at Lake Luzerne and Hadley, so there may be a 3rd zone yet to be discovered or on the air.
(Warthog1, do you show any neighbors besides T0101 in Unitrunker?)
The fact that all of the same frequencies are licensed at Corinth, Wilton, Saratoga Springs, Ballston Spa, Barkersville, Stillwater, Halfmoon 1 and 2 implies those sites are or will be simulcast. Given the number of channels, it is unlikely each one of those sites could be it's own zone as each would require it's own control channel and a huge duplication in working channel traffic as those would be very small and overlapping zones.
I have heard units on the 911 channel, who are coming though the 800 system (i.e. sheriff units, no repeater tail), scattered around the county. Seems unlikely they could be operating on Bakersville 800 from all of those areas. In fact, if EMS is operating countywide on the 800 system, then it's highly unlikely that Barkersville could be providing that coverage.
Stepping back from the technical, why would they move users from a multisite VHF system to a single-site 800 system that wasn't finished, when we know the VHF (e.g. 911) is still working (since the NYSP are still using it - have a repeater tail), and then move EMS and plan a near move of fire.
I still think it's very possible we are facing a hard to scan system (at least in the south and east high site density areas), especially given the number of sites and the probable overlapping covearge as a result. These systems are designed for commercial P25 radios with high quality receivers that are designed to work in a simulcast environment with LSM (versus plain C4FM in a regular P25 system). If you search the forums here, you'll see this is a common problem with certain P25 simulcast systems. Some scanners are better than others. Some systems work betters than others. Sometimes it can be mitigated through the use of directional antennas (high gain narrow beamwidth Yagis) aimed at, or sometimes away from, a certain site.
Warthog1
Silent Key
Northville, NY
The only peer I am showing is 001-002. The sheriff's cars are using 800 on the 911 system according to the UID's The SP cars come up as "0", since they are on the VHF patch. Fraker also has two new VHF frequencies along with the 800. The repeater outputs are 151.49 (pl 123.0) and 151.31 (pl 114.8).
They ARE up and running if needed. It looks like the sheriff's units are using dual band (800 / VHF Hi) portables as well.
Weather88
Halfmoon, NY
For those still doubting, I can ASSURE you the County is not operating with just one 800 tower. The VHF system was working perfectly well, and there would be absolutely no reason to switch us over to an unfinished system. EMS and Sheriff's are operating on the 800, and fire will be moving there shortly. We get coverage at Albany Med and other outlying hopsitals, and that would not be possible with just one tower in Barkersville. I am by no means a radio expert, but it's just common sense.
D
DaveNF2G
Guest
Common sense does not always apply in the commercial/government procurement arena. Sell a system that won't work properly, move users onto it before it's finished, demand more cash to make it work right? Sound familiar? Happens a lot.
I'm not accusing the contractors for Saratoga County of any of this. But I'm reading a lot of speculation here without a lot of proof. The possibility of misleading information coming from "official" or "inside" sources - particularly ones without radio expertise like firefighters - is strong enough that it must be considered.
Does FM capture effect not work at 800 MHz? If I am near a strong site, I should have very little trouble with more distant co-channel sites. Even if the interference is sufficient to disrupt digital decoding, my S-meter should indicate a strong signal. In my part of the county and in the nearby areas I traveled last week, it never showed more than 4 bars (out of 5) and was usually around 2 bars.
E-MAC
Saratoga county
800 coverage in Waterford
The Waterford FD and EMS have tested and are using the 800 system with out dead spots.
It must be your equipment or configuration..
Also, there are 10 towers on line in saratoga county.
e-mac
D
DaveNF2G
Guest
e-mac
If that is true, then what is the CC for each tower?
Warthog1
Silent Key
Northville, NY
So far on my end, Unitrunker has logged the following:
Fraker Mtn, control channel : 852.6
Barkersville shows 4 control channel hits 851.1625 & 851.5875 (confirmed) and 851.65 & 851.975 probable. I have logged well over 300 different UID's.
I still say that it's easier to load all of the freqs up in a trunk group, set it as Motorola P25, and let the radio find the CC. Well.......easier than trying to disprove the obvious.
I think you will find that next week, everyone will be on that non-existant trunked P25 system.
This system seems to work so well that many units are only running portables.
ALSO...I'm finally getting an idea on the use of those encrypted TG's !! This is fun !
