New version .37
Added codes back to program
https://drive.google.com/file/d/0B_Jndzk4GdzJXzVFZjFVVGpxZU0/edit?usp=sharing
New version .37
In clicking on the URL I received a message that "no preview is available" but the file offered to be downloaded is only 1 MB in size. The other versions of your excellent program were over 3 MB so if you added code I expected it to be at least as big.
Does Google or your upload have a problem?
Vonskie, good work, thanks!
Version .32 working fine on Windows 7 and a BCD996T scanner.
Will installing a newer version just overwrite the older version?
If the program was installed with the installer it will install the newer version over the old.
If you just copied the exe to your desktop it will not replace it.
Delete the old version on your desktop then run the installer.
It was installed using the installer, so I'll be good to go whenever I upgrade.![]()
Just tried to download, Norton deleted it.
Reason: WS.Reputation.1
First time I got that message and file deleted.
That's strange I looked it up and I have to file a dispute with Norton have no clue why. Unless someone downloaded it and marked it as such. I will send the code to anyone who wants to review it, it's a pretty simple program.
That's the first time I got that and downloaded all of them that you have posted since the beginning. I just wanted to let you know.
Give me about an hour and I will compile it with the older compiler and see if the error message goes away
New version .39 compiled with older free pascal compiler 2.6.2
https://drive.google.com/file/d/0B_Jndzk4GdzJMHBjejNjUkNNMlU/edit?usp=sharing
Highpockets try this version and let me know.
I am filing with Norton to get my file whitelisted.
When did the error (reputation level) occur?
When downloading or uploading a file
While using an application
When installing an application
High Pockets?
