Im checking out the real time grid, but instead of putting new logs at the top, and rolling the older ones off the bottom, after it fills the screen, it just adds them to the bottom off the screen, and the scroll bar moves up (if I am doing it correctly). This means to read current info, I have to keep scrolling with the mouse.
Also, when I adjust the size of the fields in the window, the next log entry reverts them back to what they were.
Really long department names, keep making the window wider and wider, auto resizing the window after it was set.
PS: Not bi*ching, just making observations. If its supposed to work this way, no biggie![]()
The following error showed up after about 30 lines of log were written to the logfile successfully.
Program continued to operate, without logging enabled.
System is Win7 Ultimate, 64-bit.
New version .46
Autosizing of the grid is disabled.
User sets the column size
Grid clears when you close the window.
https://drive.google.com/file/d/0B_Jndzk4GdzJaHo2TFlCUkl2SHM/edit?usp=sharing
Access denined is caused by a program locking the log file most of the time, excel is famous for this.
Did you view the log file with excel?
I didn't touch the log file. The program was running on its own while I was in another entirely separate application which wouldn't have been even in the My Documents folder, let alone the Scanner Screen subfolder.
Vonskie, how often do you query the scanner (GLG) to get data? I know you started at every 1 second.. Not sure if you have shortened that?
Outstanding stuff! I was wondering, with the main window, there is a lot of real estate, could the "running log" be combined with the main screen to achieve a single "command type" screen?
