Scanner Screen software for 436 and 536
Vonskie
Allen, TX
Mac Version of SSDiag
Will do a STS to scanner grab results and put in clip board please paste the results in the forum with scanner model.
https://drive.google.com/file/d/0B_Jndzk4GdzJZ1Y4NG1Fb0VBU3c/edit?usp=sharing
Example:
436 When active
<Data>STS,00110110110000,F0:----------14:47,,S0:----------Mar22,________________________,Plano,Allen,Wylie,,,Murphy(PAWM)P25,,AllenArea,________________________,PlanoPolice,,,,PAWMSimulcast,________________________,PlanoPoliceDispatch1,,,,TGID:3,,LawDispatch,________________________,,,Tag:--.--.---LNK,,1,0,0,0,,,5,OFF,0</Data>
436 when idle
<Data>STS,00110110110000,F0:----------14:48,,S0:----------Mar22,________________________,Plano,Allen,Wylie,,,Murphy(PAWM)P25,,AllenArea,________________________,PAWMSimulcast,,,,,________________________,IDScanning...,,,,,,,________________________,,,DAT,,1,1,0,0,,,5,OFF,0</Data>
southernCTscan
Branford, CT
BCD536HP
<Data>STS,0000100,F0:1--------16:05,,S0:12*******Mar22,,NewHaven,,NewHavenCounty-EastHa,,EastHavenFireDispatch/Ops,,FireDispatchC203.5,,453.5625MHzJack,,1,0,0,0,,,5,OFF,3</Data>
southernCTscan
Branford, CT
536 Idle Screen
<Data>STS,0000100,F0:1--------16:08,,S0:01*******Mar22,,Middlesex,,MiddlesexCounty-EastHa,,Scanning...,,,,Jack,,0,1,0,0,,,0,RED,3</Data>
Let me know if you need more.
Saint
Fort Erie Ontario Canada
Scanner Screen Diag
<Data>STS,011000,,,BuffaloPolice,,Channel3,,,,S1:12-4-----0,,GRP12-4------,,1,0,0,0</Data>
Uniden 396t scanner
Do you need anything else
Steve
Vonskie
Allen, TX
Uniden 396t scanner
Steve
Thank you if you could also do a capture when its not active that would be great
davenlr
North Little Rock, Ar
Just got my serial card installed in the computer, and finally have it working without the buggy USB connection...but someone beat me to the 536 results. Looking forward to your programs evolution.
Vonskie
Allen, TX
Thank you for your feed back. What I have determined so far based on the raw data dumps is.
The STS command varies from scanner to scanner as the display is different on the various scanners. This makes coding some what harder if I use the sts command. I hope uniden will publish the 436 / 536 remote command reference guide soon so I can look at other options to get data that will be similar between the four scanners 396 996 436 536.
Thanks once again and have a great weekend
Vonskie
Allen, TX
Just noticed this on the butel site
Important Information: because of issues with the reliability of USB/serial port on the 436/536 scanners ARC536PRO must be used with the BCD536HP rear port or the BCD436HP GPS port for reliable virtual control. The use of the front/usb port is the users risk and may not work reliable. This is beyond our control. See software manual for details.
Vonskie
Allen, TX
New version of SSDiag for the STS command PC version
https://drive.google.com/file/d/0B_Jndzk4GdzJSFNzcnBZd3JDYXc/edit?usp=sharing
Please run the above program and paste the results this one shows the hidden characters that are returned from the scanner important for the fixed length fields of the STS command.
This will allow me to see exactly how many characters per field.
Please run and paste results for example
436 when Idle
<Data>STS,00110110110000,<#32>F0:----------<#32>12:10<#32><#32><#32><#32>,,<#32>S0:----------<#32>Mar23<#32><#32><#32><#2>,________________________,Plano,<#32>Allen,<#32>Wylie,<#32><#32><#32><#32>,,Murphy<#32>(PAWM)<#32>P25<#32><#32><#32><#32><#32><#32><#32>,,Allen<#32>Area<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32>,________________________,PAWM<#32>Simulcast<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32>,,<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32>,,<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32>,________________________,ID<#32>Scanning...<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32>,,<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32>,,<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32>,,<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32>,________________________,<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32>,,<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32>DAT<#32><#32><#32><#32>,,1,1,0,0,,,0,OFF,0</Data>
436 when active
<Data>STS,00110110110000,<#32>F0:----------<#32>12:11<#172><#173><#32><#32>,,<#32>S0:----------<#32>Mar23<#32><#32><#32><#32>,________________________,Plano,<#32>Allen,<#32>Wylie,<#32><#32><#32><#32>,,Murphy<#32>(PAWM)<#32>P25<#32><#32><#32><#32><#32><#32><#32>,,Allen<#32>Area<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32>,________________________,Plano<#32>Police<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32>,,<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32>,,PAWM<#32>Simulcast<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32>,________________________,Plano<#32>Police<#32>Dispatch<#32>2<#32>,,<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32>,,<#32>TGID:5<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32>,,Law<#32>Dispatch<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32>,________________________,<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32>,,Tag:--.--.---<#15><#16><#14><#11>P25<#32><#32><#32><#32>,,1,0,0,0,,,5,OFF,0</Data>
Thank you for your help.
Saint
New SS Diag
from uniden 396t scanner
<Data>STS,011000,<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32>,,Attractions<#32><#32><#32><#32><#32>,,AN<#32><#32><#32><#32><#32><#32><#32><#32>SC<#32><#129><#32><#32>,,<#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#32><#181><#182>,,S1:123------0<#32><#183><#184>,,GRP1-3-------<#32><#32><#32>,,0,1,0,0</Data>
Vonskie
Allen, TX
Thank you.
Hopefully I can get the output from a 996 as well and a 536.
And please do a capture when idle and active. Was the above when it was active or idle on the scanner?
