Here is what I am able to determine based on Jays info.
The number at the end of each line is the field number.
Question is there is one more field than documented, field 19 anyone know what this field is?
*Idle/scanning:*
<DataHP1>
RMT<#9>0
STATUS<#9>1
<#9>2
<#9>3
0<#9>4
<#9>5
<#9>6
<#9>7
Clearwater<#9>8
<#9>9
<#9>10
0<#9>11
1<#9>12
0<#9>13
Local<#9>14
<#9>15
0<#9>16
0<#9>17
0<#9>18
2760 19
</HP1Data>
_Note:_ "Clearwater" was the system tag and "Local" the favorites list, but they were only on screen because the scanner was scanning through them.
*Receiving:*
<DataHP1>
RMT<#9>0
STATUS<#9>1
<#32>154.8300<#9>2
FM<#9>3
0<#9>4
82<#9>5
NONE<#9>6
2<#9>7
Rockyview<#9>8
Public<#32>Safety<#32>-<#32>Cochrane<#9>9
RCMP<#32>A15<#32>South<#9>10
1<#9>11
0<#9>12
4<#9>13
Full<#32>Database<#9>14
<#9>15
0<#9>16
0<#9>17
0<#9>18
7707 19
</HP1Data>
<Sub Command STATUS>
[RMT][¥t]0
[STATUS][¥t]1
[freq/tgid][¥t]2
[mode][¥t]3
[att][¥t]4
[ctcss/dcs][¥t]5
[p25nac][¥t]6
[svc_tag][¥t]7
[name1][¥t]8
[name2][¥t]9
[name3][¥t]10
[sql][¥t]11
[mute][¥t]12
[sig_lev][¥t]13
[name4][¥t]14
[name5][¥t]15
[system_avoid][¥t]16
[department_avoid][¥t]17
[channel_avoid][¥t]18
[????????][¥t]19
FUNCTION:
Get current radio status.
PARAMETER:
[freq/tgid] Frequency or TGID
[mode] Modulation (AM/FM/NFM)
[att] Attenuation status (0: OFF / 1: ON)
[ctcss/dcs] CTCSS/DCS Status (0-231)
*See CTCSS/DCS CODE LIST for the details of this code.
[p25nac] P25 NAC Status ( 0-FFF: 0-FFF / NONE: NAC None)
[svc_tag] Service Type ID
*See Service Type ID List for the details of this.
[name1] system name
[name2] department name
[name3] channel name
[sql] Squelch Status (0:CLOSE / 1:OPEN)
[mute] Mute Status (0:OFF / 1:ON)
[sig_lev] Signal Level ( 0 – 4 )
[name4] Favorites list name
[name5] Unit ID name
[system_avoid] System Avoid status (0: Unavoid, 1: Avoid)
[department_avoid] Department Avoid status (0: Unavoid, 1: Avoid)
[channel_avoid] Channel Avoid status (0: Unavoid, 1: Avoid)
NOTES:
This command can only be used in scan mode.
The frequency format in this command is MHz with decimal point same as the display frequency on radio. ( eg: 25.0000 )
If scanner doesn’t display follow, status command sends blank data.
Department name / Channel name / Service type / Frequency, TGID / Modulation / ctcss,dcs /
P25 NAC
