Scanner Screen software for 436 and 536
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
New version 254 PC HP-1 changes to see if it helps.
https://drive.google.com/file/d/0B_Jndzk4GdzJaUM3ZUp0R3dJMzg/edit?usp=sharing
Please test and let me know.
This time it locked up after 2 seconds.
Tomorrow afternoon (evening), when I have some time, I'll purge the x36HP drivers and the HP1 drivers from this machine, reboot it, and install the HP1 drivers fresh from a new download from the Uniden site, then try it again and see if that makes a difference.
Is there anything like baud rate that could be of concern? The port initially connected as COM41 at 9600, but I changed it to COM8 at 115200. (Tried it both ways with your program, made no difference).
Vonskie
Allen, TX
115200. is what I use
Good luck and let me know
alphaacres
Oswego, New York
Running 2.54 does not remembering sizing also the real time log sizing and spacing
Can you connect the real time log to the virtual display when running more than one instance it can get confusing
I'm running HP1 Extreme port speed 128000
can you go faster than 2 seconds on scanner probe?
Can you add PL, DCS, NAC to real time log?
Thank you for adding UIDs
Vonskie
Allen, TX
>>Real time long config sizing and spacing is not saved yet.
>>I have had a few other users request this will add
>>Interesting baud rate
>>It probes the scanner every 1/2 second and its up to the scanner to respond that fast.
>>Will have to look into these
Jay911
I purged my entire system of Uniden data including drivers, rebooted, installed the new drivers, installed version 255 from above, confirmed communication on the port thru PuTTY, and ran version 255.. showed "Scanning or Idle" for six seconds, then "Cannot communicate with COM port" (or similar) and froze.
Sorry, I tried. If someone else has it working, I'd suggest further testing go through them.
jlally
Spokane, WA
Scanner Screen Program Locks up.
I am having the same problem as Jay and Phask. Using HP1, vista 32, latest firmware update for HP1, serial port 18 at 9600 baud.
John Lally
Vonskie
Allen, TX
Strange I am using the same serial program library on the other scanners that I am using on the HP-1
I wish I had one to test with.
I may have to remove support of it for now.
Vonskie
Allen, TX
I may have to go down and purchase one and then return it so I can test it with the program. I hate to do that but it is the only way, also most radio com in my area is TDMA so the HP-1 would not work for that.
Saint
Fort Erie Ontario Canada
RE-STOCKING
Make sure there is no re-stocking fees or it will cost you to bring it back
Steve
mrkelso
NNJ
This thing is working Great!! on my Mac under Parallels using the null modem cable/serialto Usb. Just gotta Love it.........!!!!!
