Scanner Screen software for 436 and 536
alphaacres
Oswego, New York
<DataHP1>RMT<#9>STATUS<#9><#9><#9>0<#9><#9><#9><#9>Services<#9><#9><#9>0<#9>1<#9>0<#9>William<#32>Jackson<#32>2-11-2014<#9><#9>0<#9>0<#9>0<#9>4004</HP1Data>
<DataHP1>RMT<#9>STATUS<#9><#9><#9>0<#9><#9><#9><#9>CBP<#32>><#32>Nac<#32>301<#32>F1<#9><#9><#9>0<#9>1<#9>0<#9>William<#32>Jackson<#32>2-11-2014<#9><#9>0<#9>0<#9>0<#9>4112</HP1Data>
<DataHP1>RMT<#9>STATUS<#9><#9><#9>0<#9><#9><#9><#9>CNYICC<#32>P25<#32>System<#9><#9><#9>1<#9>1<#9>2<#9>William<#32>Jackson<#32>2-11-2014<#9><#9>0<#9>0<#9>0<#9>4504</HP1Data>
<DataHP1>RMT<#9>STATUS<#9><#9><#9>0<#9><#9><#9><#9>CNYICC<#32>P25<#32>System<#9><#9><#9>1<#9>1<#9>0<#9>William<#32>Jackson<#32>2-11-2014<#9><#9>0<#9>0<#9>0<#9>4502</HP1Data>
<DataHP1>RMT<#9>STATUS<#9>8012<#9>NFM<#9>0<#9>0<#9>NONE<#9>2<#9>CNYICC<#32>P25<#32>System<#9>Oswego<#32>County<#32>Law<#32>Enforcement<#9>Os.911<#32>Dispatch<#32>Sheriff/SP-D<#32><#32><#9>1<#9>0<#9>4<#9>William<#32>Jackson<#32>2-11-2014<#9>911<#32>Law<#32>Dispatcher<#9>0<#9>0<#9>0<#9>12050</HP1Data>
<DataHP1>RMT<#9>STATUS<#9>8012<#9>NFM<#9>0<#9>0<#9>NONE<#9>2<#9>CNYICC<#32>P25<#32>System<#9>Oswego<#32>County<#32>Law<#32>Enforcement<#9>Os.911<#32>Dispatch<#32>Sheriff/SP-D<#32><#32><#9>1<#9>1<#9>3<#9>William<#32>Jackson<#32>2-11-2014<#9><#9>0<#9>0<#9>0<#9>10508</HP1Data>
<DataHP1>RMT<#9>STATUS<#9>8012<#9>NFM<#9>0<#9>0<#9>NONE<#9>2<#9>CNYICC<#32>P25<#32>System<#9>Oswego<#32>County<#32>Law<#32>Enforcement<#9>Os.911<#32>Dispatch<#32>Sheriff/SP-D<#32><#32><#9>1<#9>1<#9>4<#9>William<#32>Jackson<#32>2-11-2014<#9><#9>0<#9>0<#9>0<#9>10509</HP1Data>
<DataHP1>RMT<#9>STATUS<#9>8012<#9>NFM<#9>0<#9>0<#9>NONE<#9>2<#9>CNYICC<#32>P25<#32>System<#9>Oswego<#32>County<#32>Law<#32>Enforcement<#9>Os.911<#32>Dispatch<#32>Sheriff/SP-D<#32><#32><#9>1<#9>1<#9>0<#9>William<#32>Jackson<#32>2-11-2014<#9><#9>0<#9>0<#9>0<#9>10505</HP1Data>
<DataHP1>RMT<#9>STATUS<#9>8012<#9>NFM<#9>0<#9>0<#9>NONE<#9>2<#9>CNYICC<#32>P25<#32>System<#9>Oswego<#32>County<#32>Law<#32>Enforcement<#9>Os.911<#32>Dispatch<#32>Sheriff/SP-D<#32><#32><#9>1<#9>0<#9>4<#9>William<#32>Jackson<#32>2-11-2014<#9>UID:894382<#9>0<#9>0<#9>0<#9>11114</HP1Data>
<DataHP1>RMT<#9>STATUS<#9><#9><#9>0<#9><#9><#9><#9>Fire<#32>/<#32>E.M.S.<#9><#9><#9>0<#9>1<#9>0<#9>William<#32>Jackson<#32>2-11-2014<#9><#9>0<#9>0<#9>0<#9>4036</HP1Data>
<DataHP1>RMT<#9>STATUS<#9><#9><#9>0<#9><#9><#9><#9>Law<#32>Enforcement<#9><#9><#9>0<#9>1<#9>0<#9>William<#32>Jackson<#32>2-11-2014<#9><#9>0<#9>0<#9>0<#9>4634</HP1Data>
<DataHP1>RMT<#9>STATUS<#9><#9><#9>0<#9><#9><#9><#9>CNYICC<#32>P25<#32>System<#9><#9><#9>0<#9>1<#9>0<#9>William<#32>Jackson<#32>2-11-2014<#9><#9>0<#9>0<#9>0<#9>4501</HP1Data>
<DataHP1>RMT<#9>STATUS<#9><#9><#9>0<#9><#9><#9><#9>CNYICC<#32>P25<#32>System<#9><#9><#9>1<#9>1<#9>3<#9>William<#32>Jackson<#32>2-11-2014<#9><#9>0<#9>0<#9>0<#9>4505</HP1Data>
<DataHP1>RMT<#9>STATUS<#9>8012<#9>NFM<#9>0<#9>0<#9>NONE<#9>2<#9>CNYICC<#32>P25<#32>System<#9>Oswego<#32>County<#32>Law<#32>Enforcement<#9>Os.911<#32>Dispatch<#32>Sheriff/SP-D<#32><#32><#9>1<#9>0<#9>4<#9>William<#32>Jackson<#32>2-11-2014<#9>UID:850640<#9>0<#9>0<#9>0<#9>11103</HP1Data>
mule1075
Washington Pennsylvania
I had to run as an admin on my windows 7 machine to keep the program from not responding and having to force shutting it down.Here are the results.
<DataHP1>RMT<#9>STATUS<#9><#9><#9>0<#9><#9><#9><#9>Businesses<#9><#9><#9>0<#9>1<#9>0<#9>Full<#32>Database<#9><#9>0<#9>0<#9>0<#9>3519</HP1Data>
<DataHP1>RMT<#9>STATUS<#9><#9><#9>0<#9><#9><#9><#9>State<#32>Police<#9><#9><#9>0<#9>1<#9>0<#9>Full<#32>Database<#9><#9>0<#9>0<#9>0<#9>3608</HP1Data>
<DataHP1>RMT<#9>STATUS<#9><#9><#9>0<#9><#9><#9><#9>State<#32>Police<#9><#9><#9>1<#9>1<#9>0<#9>Full<#32>Database<#9><#9>0<#9>0<#9>0<#9>3609</HP1Data>
Vonskie
Allen, TX
Oooh, I hadn't tried that. I'll put that on my list too.
Please try running it as your normal user account first.
If it was privileges it would never connect and read the com port, unless something else is going on with the driver I am not aware of.
Thank you.
Vonskie
Allen, TX
Is this with the 1.5 version, the one I posted this morning?
Strange it would need admin account to run, try the latest version running under your normal user account.
There are some programs that will lock down the com port to where only admins can access it.
Let me know and thank you for your assistance.
mule1075
Yes it was the one posted this morning. When I try to run it on my regular used account when I go to click stop it quits responding.Not sure why though.
Vonskie
Allen, TX
The stop button turns off the timer and the program will stop querying the scanner.
Strange that it would freeze.
Vonskie
Allen, TX
Could be a problem on my end.I will check when I get back home.
Also when you click the stop key it copies the contents of the Memo box to the clip board if another app has the clip board locked then this could cause the problem as well.
The main thing I am looking for here is if you leave it running does it lock up.
When you hit stop and it locks that is another issue.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Thanks for reminding me - I got distracted by something shiny.
In normal mode, it ran for about eight seconds (17 iterations of the data packet) before locking up.
Run as Administrator, it ran for 9 iterations before locking up.
I'm going to try something here, running in compatibility mode for XPSP3. Still appears to lock up, although the window never changes to "Not Responding". After about 30 seconds, it registered my "stop" push. When I tried to "Start" again, it locked up hard (still, again, not showing 'not responding').
<DataHP1>RMT<#9>STATUS<#9><#9><#9>0<#9><#9><#9><#9>AFRRCS<#9><#9><#9>0<#9>1<#9>0<#9>AFRRCS<#9><#9>0<#9>0<#9>0<#9>2133</HP1Data>
<DataHP1>RMT<#9>STATUS<#9><#9><#9>0<#9><#9><#9><#9>Limestone<#32>Ridge<#9><#9><#9>0<#9>1<#9>0<#9>AFRRCS<#9><#9>0<#9>0<#9>0<#9>3151</HP1Data>
<DataHP1></HP1Data>
Jay911
Something just occurred to me. I have other radios feeding into both legacy and universal serial ports on this machine. I'll disconnect them and see what happens.
No difference. Ran for 11 iterations and froze.
garys
Texas
I received my 436HP yesterday and have spent some time setting it up. I got around to running Scanner Screen today and after a bit of trouble getting the serial drivers installed, it works great. Very nice little app that allows me to put the scanner down and still see what's going on.
I hope someone will create an entry with a link in the Wiki.
Other than making it fully control the scanner :), the only real request I'd have would be a transparency control so I can have the app running and still see through the window. Well, that and having it save the Com Port and Scanner type settings.
