ScanNewEngland connection problem
floridafuzz
Hope, RI
Has anyone else received this error message when trying to view information on the ScanNewEngland website?
Secure Connection Failed​
An error occurred during a connection to www.snewiki.com. SSL received a record that exceeded the maximum permissible length.
Error code: SSL_ERROR_RX_RECORD_TOO_LONG
  • The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
  • Please contact the website owners to inform them of this problem.
I am on windows 10, using Firefox 136.0.2, and Norton, and Malwarebytes. In the past I have been able to log on to view information in the RI portal without any problems.
ecps92
Taxachusetts
Disable/Shut off Malwarebytes, seems they have flagged SNE
One of the Core users indicated he needed to add the entire IP address to get it to function
I only use Malwarebytes to Scan periodically, so no issues for me.
floridafuzz
Hope, RI
HI Bill, thanks for the additional update. Do you know what the IP address is for ScanNewEngland so I can add it to my Malwarebytes program?
KC1UA
Scan New England Janitor/Maintenance
Marstons Mills, Cape Cod, Massachusetts
This seems to be limited to Malwarebytes at this point and is apparently a false positive of some nature. As excluding the website doesn't solve the problem, the IP to exclude is: 108.178.43.106 .
For peace of mind purposes, the webhosts have done scans and found no issues.
Additionally, the Google Transparency Report shows no issues: Google Transparency Report
Other well-known online security scanners also did not detect any issues with the website.
Free Website Scanner - Check Site Security & Malware
Sucuri Security
It seems this is just a "one of those things" things at the moment.
floridafuzz
Hope, RI
Sucuri Security
Scott-
Thank you very very much, that did the trick. It is much appreciated. That worked like a charm!
