SDR# SDR# 1911 & rtl-sdr
PDXh0b0
Woodland, WA
so I tried posting on groups.io, it vanished...
new release of sdr# version 1911
have tried 3 pc's with windows 10
downloaded, extracted, place the folder in C drive
ran the install-rtlsdr.bat
No plug-ins have been added
no problem making changes before pressing play
once I press Play, any action causes 1911 to crash example (changing frequency, gain ect.)
this is with blogv3,nesdr v4 & v5
basically I am wondering if anyone is experiencing the same results, or should I keep digging ... whats your experience with the new release using an rtl-sdr dongle
PDXh0b0
Woodland, WA
I have the same problem with v1911. When I try to change the freq, it closes. When I reopen, the source is set back to airspyR2.
If you select source, make settings adjustments and than close sdr# it will save your settings...
rabbit108
S.E. VA
If I make the settings adjustments in v1911 before I click on PLAY, it works. But if I try to change a setting of freq or RF gain during PLAY, it will close.
Skipwire
Oregon
Application: SDRSharp.exe
CoreCLR Version: 7.0.523.17405
.NET Version: 7.0.5
Description: The process was terminated due to an internal error in the .NET Runtime at IP 0x00D0CF80 (0x00BF0000) with exit code 0x80131506.
Faulting application name: SDRSharp.exe, version: 1.0.0.1912, time stamp: 0x641ddaa7
Faulting module name: SDRSharp.exe, version: 1.0.0.1912, time stamp: 0x641ddaa7
Exception code: 0x80131506
Fault offset: 0x0011cf80
Faulting process id: 0x0x32AC
Faulting application start time: 0x0x1D999B7ADA7928A
Faulting application path: C:\Users\XXX\Downloads\sdrsharp-x86\SDRSharp.exe
Faulting module path: C:\Users\XXX\Downloads\sdrsharp-x86\SDRSharp.exe
Report Id: 4cb7ed97-a1f8-413e-9888-3e432af91757
Faulting package full name:
Faulting package-relative application ID:
Ran SDR# sharp in both admin and non admin privledges with no change.
Update .Net 7.05 to fix the problem
Download .NET 7.0 (Linux, macOS, and Windows)
SDR# still broken after a few minutes after .Net update and a reboot.
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: SDRSharp.exe
P2: 1.0.0.1912
P3: 641ddaa7
P4: SDRSharp.exe
P5: 1.0.0.1912
P6: 641ddaa7
P7: 80131506
P8: 0011cf80
P9:
P10:
rabbit108
S.E. VA
v1913 download removed by Norton piece-by-piece
MELERIX
mciupa
Canadian DB Admin
Moderator
I'm here a lot
I agree with @MELERIX , I use v1910 solely with the TETRA plug-in on a busy dedicated TETRA channel and it works superb.
I admit though if I fuss with different frequencies it may shut down, hence the play and walk away.
