Link has expired.same issue here with 1912, it crashed instantly after changing frequency a bit or moving the spectrum.
here is a copy of build 1910 if somebody needs it (available for 7 days): Download files - Filemail
Thank you!here, available for 7 days: Download files - Filemail
THANK YOUhere, available for 7 days: Download files - Filemail
MELERIX SDR# v1910 works well with my RTL-SDR.COM V3 dongle.check there: SDR# - SDR# 1911 & rtl-sdr
Thank you for the v1910 download. It also works well with my RTL-SDR.COM V3 dongle.sdrsharp1910 - Download - 4shared SDRSHARP 1910
Correct.SDR# 1910 + Keenerds RTL-SDR Drivers is the best combination for now.
NOTE: librtlsdr.dll must be renamed to rtlsdr.dll
Correct.
Thank you for the correction. I did have some stop & start problems when I first used early versions of SDR# with the RTL-SDR.btw, Osmocom RTL-SDR Driver is unstable too because it causes crashes sometimes when you start & stop SDR#, so is not recommended, while Keenerds RTL-SDR Drivers are really stable with SDR# 1910.
That worked OK, so I thought the binary was the right choice.I use the 32 bit version and I have tested it in several versions of sdr# lower than v1784 and they work perfectly, it improves the reception in general and it does not freeze anymore. In the case of the osmocom drivers, the latest version of 2019 is the one that has worked best for me. Index of /binaries/windows/rtl-sdr/
In each version that you download, in the case of Windows, there is a file called " librtlsdr ", you have to rename it to " rtlsdr " and copy all the DLLs to your sdr sharp folder.
That sounded like good advice, but I wasn't certain about where to look for it.1910 with keenerds , been flawless for me
That gave me a link to try.btw, Osmocom RTL-SDR Driver is unstable too because it causes crashes sometimes when you start & stop SDR#, so is not recommended, while Keenerds RTL-SDR Drivers are really stable with SDR# 1910.
Nortons gave me the BSD in 1999, junk lolThank you for the correction. I did have some stop & start problems when I first used early versions of SDR# with the RTL-SDR.
I looked for advice from different sources about using the RTL-SDR.COM V3 dongle with SDR# v1910.
First advice from Zeifer69:
Second advice from PDXh0b0:
Third advice from MELERIX:
Norton false positive? I'll try allow:
Good, now I can compare the zip file size:
More later.
OK, I'll bite:Nortons gave me the BSD in 1999, junk lol
OK, I'll bite:
Blue Screen of Death?
What internet security do you use?
Now I have a problem. I don't know which dlls from the Keenerds build to insert in the SDR# v1910 folder.
I copied these to my sdr# folder
drive.google.com
Thank you very much for the dll download.View attachment 144098sdrSharp dlls - Google Drive
drive.google.com
