thewraith2008
- Joined
- Nov 22, 2016
- Messages
- 1,866
This is an update (v1.1.1.0) to the Frequency Manager - FreqMan plug-in for SDR#.
TSSDR (Vasili) has given me the approval to update and release this plug-in.
Not sure how many people still use this plug-in but there has been some requests for it so here it is.
A large part of this update is to have to plug-in UI be more compatible with SDR# 1732+ (Telerik + dock control).
Other things where also done to improve the plug-in over all. (see changelog.txt)
This plug-in version adds/changes and fixes some items:
As this is the initial release, there are bound to be bugs.
Please report issues here.
Download
NOTE: Use 7zip or WinRAR to extract files from the .7z file and read the .txt files for installation and usage of files with SDR#.
MD5 HASH: 15e0e370df4872c67f47382960c8b39c
Code:
1.1.1.0 - Release
Changed: Further tweaking to the Telerik UI detection and controls handling.
- Some SDR# v1778+ themes were not 100% in the newer interface (for plug-in).
1.1.0.0 - Initial release (limited)
Updated the plug-in UI to work better with SDR# Telerik UI
Fix: If scan was pressed when there where no frequencies defined, a crash was seen.
- Message box will now be shown to alert user of the lack of entries.
Fix: When scanning, keep the tuned frequency entry in the visible area of frequency list.
Fix: Scanning: When paused on active frequency and 'next' button was pressed, it would halt (for 'Wait' time) before
resuming scan. Now it will resume scan immediately.
Added: Label for number of entries for selected group.
- Shown to right of 'Delete' button.
Added: Option to enable the squelch when scan started.
Added: Active time to scan control window title.
- Will show when states are 'Play' and 'Wait' as [X s]
Added: Group [Duplicates]
- This group will show frequency duplicates in database.
Tooltip will show: Group, Mode and bandwidth.
If you delete a duplicate frequency from the database, the other frequency will be removed from duplicates list (as it is no longer a duplicate)
NOTES: If SDR# 'Slicer' is used, most of the plug-in functionally is disabled. (see changelog for more details)
NOTE: If any other plugin position is used other than 'Plugin panel'
- Normally if you close this window in SDR# 1778+, you will need to restart SDR#.
Now the window will reopen automatically.
There is no PDF Documentation
- Usage is fairly straight forward to use.
- Some basic documentation is supplied within the archive.
see 'changelog.txt' for full listing and details of changes/fixes and new features.
Download
