PatrickPierre73
- Joined
- Oct 4, 2020
- Messages
- 49
- Reaction score
- 3
Yes it uses standard SDR# squelch and is the reason that the scan rate is so much slower.Has anyone utilized the scan function in the Frequency Manager (FreqMan) plugin? Does it use the normal squelch control in the SDR# radio dropdown and how fast is the scan rate?
The list should sort primarily by frequency.Hi there !
About duplicates, the change log states : "the first occurrence is drawn at top (in bold green) and following duplicates are drawn as normal in the following list (in green)". It works as expected.
A question though : how is this "first occurrence" defined ?
In some cases, it matches the order shown in SDR# "frequencies.xml", in other cases it is different (see attachment).
This does not seem to be related to 'alphabetical order ...
Is there a trick so that the order of the duplicates in "frequencies.xml" is kept in the freqman table ? (to make the stations appear from the most likely to the least likely).
I'm running v1.1.5.0
Thanks a lot.
Let say #1 and #2 are change request ...
#2. currently we have only one tag <GroupName> per entry
It is useful one more tag:
<MemoryEntry>
<GroupName>AIR</GroupName>
<GroupName2>HF</GroupName2>
</MemoryEntry>
<MemoryEntry>
<GroupName2>VHF</GroupName2>
</MemoryEntry>
or so.
Thanks for your attention.
Gio'
that's what I have today... thanks so much for your time.
