SDRSharp Build 1191
jasonhouk
Uniden AlphaMan
Uniden Representative
Marion, Ohio
I'll give it a go and see in the scanner/trunker plugins are working with the newest version.
Boatanchor
The Frequency & Scanner plugin works, that's all I use.
The dap (digital audio plugin) is almost mandatory if you are into FM/analogue scanning/monitoring :)
http://translate.google.ru/translate?hl=ru&sl=ru&tl=en&u=rtl-sdr.ru
This plugin now includes the alternative (S/N) squelch and the bandpass filter in one.
I use a combination of both the original SDR# squelch and dab squelch to eliminate all squelch crashes while allowing the scanner plugin to keep working.
And the audio bandpass filter works so much better than the SDR# audio filter. Set it to 0Hz (or 300hz if monitoring channels with CTCSS) to 3khz - 4kHz and you get 'real' radio audio.
RonnieUSA
Rowan County,KY (Morehead)
ðÅÒÅ×ÏÄÞÉË Google
The only thing I'm using SDRSharp for is to listen to 3 NXDN frequencies.
That my scanner can't receive.
garys
Central Texas
I'm trying to set up SDRSharp to work with Unitrunker, but I'm getting an error message.
Can anyone tell me what I did wrong? I'm running SDRSharp rev. 1191.
garys
Central Texas
Version 1192
Although I already posted this in another thread, I am get a similar message as "garys" did when using the trunker pluggin when I use the CTCSS pluggin.
Last version I have that CTCSS decoder works with SDR# is 1177.
moonbounce
I have just downloaded SDR Sharp version 1192 and I have it running with the Frequency Manager and Scanner plugin. Right now I am just playing with it, and getting used to it. Certainly is a lot of fun having a scanner on your computer that will do infinitely more than any scanner on the market, lol.
What a hobby!!
garys
Central Texas
This might be a dumb question, but it won't be my first. Is there a particular install process for new versions or is it a matter of copying and pasting the new files into the proper directory?
I downloaded version 1192, but don't want to mess with it since I have it running so well.
What a hobby!!
