SDRTrunk SDRtrunk help
dave3825
Suffolk County NY
It will do that unless you remove the yes for both listen and record on each talk group which sets them basically to ignore.
maus92
Eastern Shore
I got it working but it's getting all of the alias for the counties I have in after I put in the ones I wanted
You will need to explicitly lock them out. That means you will need to define the talk group, then set Listen slider to off.
maus92
Eastern Shore
It's in the Playlist Editor section. You will need to create a new alias for each talk group that you do not want to hear. Once you have created it, set Listen slider to off (left / grey). That will mute the talk group.
Bonkk083
Union, SC
I put the listen listen to off and it's still coming through even when I just put in a site and comes through without aliases, If I have just say I have 20 talk groups I would need create 20 aliases list
maus92
Eastern Shore
In order to fully control what is played, you must create an alias for every talk group that could possibly be transmitted on a site. For each talk group that you want to hear, set its Alias to Listen (slider to the right / blue); for those you don't want to hear, set Listen to mute (slider to left / grey). Make sure to restart the program after making changes. If you are still hearing a talk group that you think you set to mute, you've done something wrong - recheck your configuration.
dave3825
Suffolk County NY
And if its not a tg that's set to mute, meaning one that's not in your alias list, then it would be a tg that nobody identified and or submitted, or you did not import all talkgroups.
Create one new tg and name it unknown.
Set the identifier to p25 tg range and use range 1 thru 65535
Turn off Listen and Record. Click save
Bonkk083
Union, SC
I did one is that right and do I delete the top identifier
dave3825
Suffolk County NY
Definitely not right. You added a identifier to an existing talk group (48501 sptg DISP) and looks like you changed the tgid on another, tg sptg ch2 trf.
Go to that tg, 48501, and click on the identifier you added and hit delete identifier. Then hit save.
Then go to tg sptg ch2 trf and change its tgid back to what it should be.. Hit save
Not 65300
Bonkk083
Union, SC
So go to that tg, 48501, and click on the identifier you added and hit delete identifier. Then hit save.
Then go to
I deleted it, then I added a unknown
Bonkk083
Union, SC
I believe that did it the next that I'm stumped on is the medical helicopters are listed statewide but Lifenet can only be heard on Laurens and medtrans on Spartanburg how should those be listed
dave3825
Suffolk County NY
You really should read up on how trunked systems work as well as how radio affiliations work.
Bonkk083
Union, SC
What does frequency rotation mean does that have to do with how fast it picks up a talkgroup it seems like it has delay picking up
RMason
Mississippi / Colorado
Frequency rotation is how fast it cycles through the list of control channel frequencies looking for a control channel.
