sdrtrunk-vce - web interface, analytics, optimizations - Testers Wanted!
tylerwatt12
Cleveland
dave3825
Suffolk County NY
Is it possible to run this headless?
I'm working toward this, but I want to move a significant amount of the configuration to web first.
tylerwatt12
Cleveland
Looks like a misdecode event. This happen occasionally, usually when signal quality drops below ideal levels. Without resorting to funky per-band/frequency hacks, it's almost impossible to prevent these as they've passed error correction and CRC. I have various filtering stages that prevent misdecodes from being added to the channels tab, but the live tab has to take what ever data it receives and display it.
W4KRR
Coconut Creek
When running any of the dark modes, the minimize, restore, and close icons on the title bar are invisible. In light modes, they are difficult to see at best.
vince48
Central Valley, CA.
greetings,
will you be adding SDR control, meaning - being able have a choice to select a dedicated SDR for control channel and SDR for voice channels?
far342
Oregon
Monitoring a P25 system it seems to miss quite a few transmissions and cut out a bit. And are there any ways to combine the call activity view of two sites of the same system so that I don't have to keep clicking back and forth between the two?
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
Which mode are you in? I'm guessing "Material Deep Ocean?" That's the closest I could get to how your UI looks. Try "Dark", "Nord" "Dracula" or "Arc Dark" for better top button visibility
W4KRR
Coconut Creek
Yes, but all the dark modes have poor contrast, from poor to unviewable. And the light modes aren't much better. In all cases, the minimize button is almost invisible. I have been unable to correct this in Windows display settings.
far342
Oregon
An idea i've had for a while for sdrtrunk would be some type of "patch linking". The p25 systems I listen to have quite a few "patches" where the older analog frequency they used to use is linked to the current talkgroup on the trunked system so that whenever someone transmits on the original analog frequency/repeater it will convert that audio to digital onto the talkgroup and have a custom radio id for that analog frequency. So I was thinking of being able to link that radio ID with the actual analog frequency in my playlist so that whenever that whenever someone does transmit on the analog side of the talkgroup the program would use the next available tuner to listen to the analog frequency instead of the talkgroup as a seemless blend. Having some sort of "delay" variable would be helpful for this as well as some of these patches are offset by a certain amount of time (positive or negative)
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Why in the world would you need to switch over to the analog freq (which you may not even be able to hear, and would require an additional tuner), when the same traffic is already being heard on the talkgroup as a patch? That seems like overkill. If I were the author I would not waste time on something like this. One person in about 30,000,000 would even care about trying this out.
