SDS100/SDS200: SDS 200 ethernet connection is spotty
burgus
Stronghurst
The ethernet connection is hit and miss. I've tried different cables and different switches. It does not connect to my network nor does the connection lights come on. It was working for 9 months. Suddenly it has a mind of its own on making a connection.
Any troubleshooting tips?
nessnet
Eastside of Lake WA
No Ethernet connect lights means either the cable, or the RJ-45 itself is bad.
I'd bet it is the physical connection somewhere....
burgus
Stronghurst
Software isn't a concern at this point. But I use proscan of course.
The switch is 1 foot away from the scanner. And I've tried different cables. I went into the setting and changed IP address with no luck.
And this morning, it was back on. Makes it hard to trouble shoot.
dave3825
Suffolk County NY
When it's working properly, the orange light confirms the link and the green flashes when data is transmitting. A while back I had to wiggle my cable around to get the connection to work and it was a bad cable.
Inside the connector on the 200 there are 8 pins. Do they all look to be the same height? Do they all look clean?
buddrousa
My SDS200 has been plugged up a running on my network from day 1 and I was an early adapter that got the scanner in the 1st batch shipped. As stated above are the 8 pins in the scanner shinny? You can plug and unplug several times to kind of clean then they are easy to bend and get out of alinement so be careful sticking anything else in the jack.
burgus
Stronghurst
Been working on and networking computers since 1979. I changed the cable for a new one. I make my own pigtails. Only 4 wires are used out of the 8 in the bundle. I've cleaned the socket with electrical cleaner. I've wiggled and prayed.
I was hoping it was something software controlled. I'm sure I have ruled out wiring and switches. I would like to rule out everything before I call tech support. I really don't want to send it in and get someone else's problem in exchange.
nessnet
Eastside of Lake WA
Or the port got turned off.
I suppose since it is an SDS, it's possible ...
Out of curiosity - why just 4?
Isn't it just as easy to crimp all 8 - assuming you are using CAT5/6...
I also have been in networking for decades and I have pulled my hair out troubleshooting for hours - only to find a bad RJ-45.
dave3825
Suffolk County NY
Could also be something wrong on the inside of the lan jack where it connects to the circuit board. Maybe like a csj. @ OP, does your scanner stay on all the time or is it turned off when not in use?
BinaryMode
2600 dialtone blvd
What kind of switch? Is that suspect?
The IP address was able to be changed? Or wasn't? I'm assuming the IP address could be changed just still didn't get a connection after the IP address was changed.
I'd isolate from the switch or other stuff like routers and plug directly into a computer and see what happens.
They do sell network testers...
burgus
Stronghurst
Nit-picking my post isn't helping me at all. Of course, I use all 8 wires. I've been doing networking longer than most of you have been alive.
I'll try a new network card.
Still doesn't connect straight to a computer.
I was able to change the IP address.
The crazy thing is that it comes on all by it's self. And then it stops. Sometimes right away. Sometimes it works for hours?????
wtp
Port Charlotte FL
i think the average age here is just about retirement age.
you must have started networking early.
not trying to be picky, trying to be funny.
i was going to say build up on the connections, but i see you did clean them.
wi-fi computer and not a usb wi-fi card thing right ?
burgus
Stronghurst
Everything is cabled.
  • Like
Reactions: wtp
