SDS100/SDS200: SDS100 frequency lists
regal233
Odenton Md
I’m new to the SDS100 and have a question that hopefully one of you could answer. I have been able to create a Favorite using a range of frequencies. I would like to create a Favorite using a list of specific frequencies but I haven’t been able to do that. Is that possible? Am I missing something? I would appreciate any help you can provide. Thanks in advance.
nessnet
What month is it?
Best practice here is to give enough information so that others can help.
Do you have Sentinel installed and working?
Did you use Sentinel to program the favorite list you now have?
What are you trying to program (the "list of specific frequencies").
Are they conventional or trunking?
Help us to help you.
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
Welcome to the RR forums. Here are some excerpts from the easier to read manuals we often refer members to for FAQs:
Uniden Sentinel is available for free for your programming & firmware updating needs. Its easier to read manual is linked here. Only drawback to Sentinel, particularly with trunked radio systems as far as favorites list building goes is that it imports every site and talkgroup on a given system and then you have to go through the favorites list and remove what you don't want. I strongly recommend Proscan over Sentinel for favorites list building as Proscan allows you to pick and choose only the site(s) and talkgroup(s) you're interested in hearing without the need to remove everything else you don't need. You get a 30 day free trial you can use to create your favorites lists and after the 30 days elapses, $50.00 gets you two activations. Only prerequisite is a RR premium subscription which you have already.
Your county operates on the trunked radio linked below. Talkgroups designated as modes "A" and "D" on said system can be monitored. Mode "DE" talkgroups are fully encrypted and cannot be monitored. "De", lowercase "e" are partially encrypted meaning some communications can be monitored but not others.
If these terms seem foreign to you I'd suggest having a read at the trunking basics wiki linked below to get you up to speed on the terminology. As previously mentioned, specific info goes a long way here when asking a question but I hope the aforementioned info will help get you on the right path
regal233
Odenton Md
Sorry, I’m new to RR as well as the SDS100. I do have Sentinel installed and working i did use Sentinel to program the favorites I have now. I programmed a couple of favorites of frequency ranges using Sentinel. These weren’t anything special, just trying to learn. I wanted to try a list o frequencies that I believe are conventional. They are just a list of air traffic frequencies in my area.For example
KBWI tower 119.400
Potomac approach 124.550
Potomac approach (BUFFR sector) 133.850
etc.
The complete list has about 15 frequencies.
Hope this helps make my question clearer. Thanks.
tvengr
Well Known Member
Baltimore County, MD
Are these conventional frequencies or talkgroups on a trunked system? If it is a trunked system, you need to have the system in ID Scan. In ID Scan, you will receive only the talkgroups you have programmed. In ID Search, you will receive every talkgroup on the system. While scanning a trunked system, press the scroll knob and then E to toggle between ID Search and ID Scan. In Sentinel, click on a system and then the Options tab. ID Search should be Off for ID Scan and On for ID Search. The KBWI frequencies are conventional. The Modulation is AM. Here is a list of ATC frequencies for BWI Airport: The ATIS frequency will need to have an Avoid. It is a continuous transmission with airport info.
119.400BWI Tower VHF
257.800BWI Tower UHF
121.900BWI Ground VHF
120.200BWI Grnd Alt VHF
377.075BWI Ground UHF
118.050BWI Clear Deliv
122.950BWI Unicom
127.800BWI ATIS
119.000Pot App/Dep VHF
119.700Pot App/Dep VHF
124.550Pot App/Dep VHF
125.525Pot App/Dep VHF
128.700Pot App/Dep VHF
282.275Pot App/Dep UHF
290.475Pot App/Dep UHF
307.900Pot App/Dep UHF
317.425Pot App/Dep UHF
121.500Aero Emerg VHF
243.000Aero Emerg UHF
dmfalk
Eureka
This should already be in Sentinel's database, and just a matter of clicking on your county's "Airports" folder, putting it into a Favourites list, and editing out what you don't want.
maus92
OCMD
Anne Arundel County has fully transitioned to their new P25 system so the OP should add it to their programming rather than the P16 system:
Whiskey3JMC
ofd8001
Louisville, KY
Also, YouTube has great videos on how to program Favorite Lists using Sentinel.
regal233
Odenton Md
Thank you very much for your reply. I haven’t had a chance to fully go through all the information you provided but it sure looks like it’s full of a lot of information and in a much easier format than the Uniden information. Thanks again. I’m sure I will learn a lot.
regal233
Odenton Md
122.950BWI Unicom
127.800BWI ATIS
This is exactly the type of list that I would like to make as a Favorite. Can you point me in the right direction to learn how to create a favorite like this? Thanks.
K3FAN
Anne Arundel County, MD
Anne Arundel County switched officially. My database was uploaded from RR ZIP CODE programming on the SDS-200. ALPHA (Dispatch) works fine. I can MANUALLY stop and listen to a TAC Channel. But in SCAN, it will NOT stop on a busy TAC channel. Is this a problem with my Radio or the FREQ UPDATE?
hiegtx
Mentor
Dallas, TX
Make sure that you have the ‘Tac’ service type enabled, both in your profile in Sentinel, and verify that it is also enabled on the scanner (in case, somehow, it was accidentally turned off). Is Tac channel you are referring to entered in a Favorites list? or are you scanning using the database and location?
