SDS100/SDS200: SDS100 SD Card
LN2R0gue
Hi all,
I'm new to scanning and got an SDS100. I pulled the SD card to do a firmware update and I'm having a rather hard time getting the SD Card back in to the slot. Is there a trick to it?
LN2R0gue
Check on YouTube there is a video
I checked there and didn't see anything however the laws of internet kicked in and when you recommended to check it popped up in the recommended section. Thank you
Hit_Factor
Saint Joseph, MI
You don't have to pull the SD card out to do a firmware update.
Other than replacing a faulty card, I can't think of a reason to take it out.
Of course, this doesn't help now. Keep in mind for the future.
LN2R0gue
I'm guessing I can hook the included cable to my computer and run sentinel software to do that?
kruser
Well Known Member
W St Louis Cnty, MO
Yes, when you attach the USB cable, the SDS100 will prompt you to press E/yes or ./NO. You press E/Yes button to select Mass Storage Mode.
After a short period, a new drive letter should appear in My Computer or This PC. That's the SD card in your SDS100 and you can use Sentinel to update the firmware directly to the card in the radio. Mass Storage Mode basically turns the SDS100 into a card reader.
ofd8001
Louisville, KY
The 436 isn't much more friendly on that, either. I won't remove a portable's SD card unless it goes bad for that reason.
In addition to updating firmware, you can update the Master Database and any Favorites Lists with the cable connected method.
n1chu
Farmington, Connecticut
Whatever you do, don’t force it. There is absolutely no excessive pushing or pressing required to replace the SD card. Look closely at the carriage the card goes into. You can determine which way the card must be oriented in order to get it mounted, and how it’s slides into it’s locked position. The Utube will help.
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
Hi & welcome to the RR forums:
Acquiring Uniden Sentinel & the firmware update procedure are explained in great depth in this Youtube video. There should be no reason to remove the SD card if you don't suspect it is faulty, the assembly is very delicate. Additionally I'd strongly recommend perusing through the easier to read SDS100 manual to familiarize yourself with the SDS100 and its basic operations. Welcome aboard!
nessnet
What month is it?
Yes, or any other mini USB cable. The one that came with the scanner is not special.
Yes - and no.....
Yes, it is a standard USB configuration, BUT is also uses AWG24 for the power wires inside of it. Necessary because the 100 is a power hog and if you use a smaller gauged cable, you will get the dreaded low voltage errors...
