SDS100/SDS200: SDS100/SDS200 New Public Release Sub CPU 1.03.05
JoeBearcat
Uniden Representative
I noticed the Type II Beta Files are now both removed from the SDS100 and 200 TWiki. Any reason as to why?
Not needed, as they are incorporated in the regular firmware release.
VA3ADP
Mississauga, Ontario Canada
I tried reverting back to 1.21 on my SDS200 and my reception on UHF and VHF is still really bad. Not sure if this is solely a software issue or a hardware issue as I just got it repaired not too long ago. Not sure If an SD card format would make any difference.
JustLou
NY/NJ
FWIW, I monitor dozens of UHF and a few VHF frequencies that are both near and not so near. I haven't noticed any difference in reception between firmware versions. The ones that come in good still do, and the ones that are weak still come in weak.
Ubbe
Stockholm, Sweden
It seems that what filter setting to use may change between firmware versions. If you do not have a lot of other adjacent channels with RF carriers you may not notice this I.E. you have previously not needed to change any filter settings or use IFX at your location.
/Ubbe
N9PVW
Louisiana
I did all the updates, including the waterfall. My SDS200 is working just as well now as before, I also notice that before updates my volume was always set on 10, I now lowered is to 8.
ctiller
I changed the modulation to FM rather than default and that seems to have helped my issue with garbled transmissions a bit. It's still there but not as bad as it was.
