BCD436HP/BCD536HP: Uniden BCD436HP/BCD536HP Version 1.28.15 Released 06/12/24
AngWay
Curious
Buchanan, Va
I have a quesation i just bought a used 536hp and it has firmware version 1.11.31 .. is this a old version? also it says SN3752608003145
SUM=125,M-VER=1
what does this mean and should i hook it to sentenel and update all of it. oh and by the way it only asys dmt under upgraes i doesn't say to upgtade to NXDN i thought the 536HP wooould upgfae go NXDN and DMR was i wrong???? PLEASE HELP
RMason
Mississippi / Colorado
SUM=125,M-VER=1
The curent firmware for the 536hp is
1.28.17 (06/12/2024)​
So, yes. Your firmware is very old. Version 1.11.31 was released on 7/7/2017.
Regarding the NXDN upgrade: Support for NXDN was added to the 536hp in version 1.14.00 (3/26/2018). You will need to update your firmware to enable NXDN.
See here for details: https://info.uniden.com/twiki/bin/view/UnidenMan4/BCD536HPFirmwareUpdate
AngWay
Curious
Buchanan, Va
AngWay
Curious
Buchanan, Va
oh and i bought the 996 squelch and volume buttons from uniden and they fit like a glove
AngWay
Curious
Buchanan, Va
when i try to upgrade to dmr it tells me the SUM is not correct but i enter the sum that is in the settings under firmware. SN37526068003145 SUM=125, M-Ver=2 that is what i says under firmware verions
what am i missing here?
RMason
Most likely the serial number is not being entered correctly
tvengr
Well Known Member
Baltimore County, MD
Hexadecimal numbers use the numbers 0 thru 9 and the letters A thru F. The number 8 and the letter B are often confused. The scanner serial number on the back of the scanner and the electronic serial number shown on the scanner menu are different. If you are trying to enter the serial number or electronic serial number on the my.uniden site, the first several characters are already entered. If you are upgrading to DMR in the scanner, you need to enter the key emailed to you by Uniden,
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
I wouldn't have posted my whole S/N and SUM as a mean person could buy the upgrades and prevent you from getting them...and then offer them to you at a higher price.
AngWay
Curious
Buchanan, Va
it says this
The Checksum you entered is not valid. Please recheck your input to ensure that you have entered the 3 digits of the SUM value correctly.
Please go back by clicking your back button.
and if i use 260 instead of Z it won't let me enter the whole serial number
AngWay
Curious
Buchanan, Va
I just tried with the info you supplied and had no issues.
Under S/N be sure you are entering 26068003145 (without the 375).
Edit... nevermind i got it i didn't know i had to leave about the first 4 numbers of the SN why is that
