SDS100 Question:
This just began last night and I’m not sure what caused it... it was sitting at the table like it usually does and I noticed it got somewhat unusually quiet. I didn’t think much of it until a few min went by and I looked at it and realized it had lost signal completely. I tried turning it off/back on... remove battery, moved the SD card, took the antenna off and back on, updated firmware, tried different systems, tried different channels, checked control channel for the trunked system etc, nothing at all. It picks up nothing. My other scanner DOES pick them all up just fine though...
I’m not sure what happened? I haven’t changed settings in forever. I didn’t push anything either.
It did pickup a signal for a brief moment a while after but when the screen went to sleep, the signal was lost. (I Monitor p25 trunked systems along with conventional channels together)
I let it sit overnight last night and when I turned it back on this morning, it worked flawlessly for a couple minutes and then completely stopped again. It scans, but there is no sign of the signal bar at all. Help please!!
