Is that system a rebanding issue? since it ends in 5 and not 0 i wouldnt think so unless the LCN is wrong on the 857 control channel day.. can u see if the LCN's match up on all frequencies?
I do not believe that is true for a MOT II (analog) system. I'd try programming a reband band plan.The SDS100 gets its bandplans from the control channel, so it's not something you need to worry about. If the control channel broadcast was wrong, system users would have trouble.
You can add or remove most items as you see fit.
To add a little to what Jon has already noted, you can download Sentinel here.I am looking to buy new scanners which will work with p25 phase II as all my scanners are analog only. Do have a pro-668 but it will need to be reprogrammed by Whistler before the switchover by UCA. I have been researching the SDS100 extensively. The bad speaker quality, proprietary battery (large & expensive) along with the huge learning curve is quite daunting especially considering the price.
Also considering a couple of SDS200's as well. The question is can one hide all the unwanted items from the display one doesn't care to see?
Bcd325P2 does phase 2 nxdn and dmr and pro voice, it might be a cheaper option but it may not do the simulcast like the sds models, UCA has a few current simulcast sites, idk what it will look like when they switch, it might be a while though, 2-3 years idk maybe sooner maybe not , maybe phase one or 2 we don’t know, but at least we are readyI am looking to buy new scanners which will work with p25 phase II as all my scanners are analog only. Do have a pro-668 but it will need to be reprogrammed by Whistler before the switchover by UCA. I have been researching the SDS100 extensively. The bad speaker quality, proprietary battery (large & expensive) along with the huge learning curve is quite daunting especially considering the price.
As long as the usb cable is not low voltage usb, u should be able to charge and scan with the sds100, it will automatically disable this function if it gives u low volt usb error, there is a setting to enable it againThanks for the suggestions and comments. I will download Sentinel and play with it. I read somewhere you can charge the battery or listen to the scanner but could not do both at the same time?! As I get older the scanners I use most give me grief in understanding what they are saying. Using the attenuation feature doesn't seem to help nor does adjusting the sensitivity settings. External speakers help but my hope is to get a
scanner with tech upgrades which makes it easier to understand.
I live right in the middle of UCA Trunk Site 1 - Weber Simulcast! Which is tied to Box Elder EOC through TGID 66520 so all of BE Co is coming through our simulcast as site 4. Site 4 is actually the old "Reservoir Hill" site. That site is also tied to Cache Co simulcast with a TGID in the 49000 range so we get alot of Cache Co traffic also.
The learning curve is ridiculous - Software for each RS scanner I own which is 12. Not all are programmable with software but the 197's use one and the pro-107 uses a different one and the pro-668 uses yet another. I also have a couple other RS scanners which can have data sent to them but not read back from them. They didn't survive the reband so I use them in conventional mode. After sending my 668 into Whistler to have it
reprogrammed the software will be Whistler branded not RS branded.
I think I'm going to purchase one SDS100 & SDS200 and see how it goes. My simulcast coverage sucks. Now where to buy?
gldavis - I am an old dog and new tricks are not my thing! Have been trying to understand the concept of "object oriented programming".
since they introduced the concept. Just cannot seem to understand it and how it relates to programming frequencies, control channels, talkgroups, radio id's.....etc. I've never been a fan of the "zip code" programming. Uniden has their "home patrol" software which infuriates me. It addresses
the needs of the people who don't want to do the work to learn scanning and leaves us old war horses with broken tools in which to work with when it comes to programming of any kind. I know traffic which comes from jails, public works and animal control. I don't need a scanner to departmentalize them for me since I'm going to lock them out anyway. LOL
FYI - There is a newer version from 07 March 2019 found here:Unitrunker is free. Index of /download/
There are other programs that will work, but I like this one.
