Sds100 vs 200
noaim
Milwaukee, WI
My sds100 picks this up no problem but the 200 does not
I don’t have any upgrades on the 200 and do have dmr and NXDN
I don’t think that’s the issue though same profile same full database and it’s not being avoided
Any ideas?
Sent from my iPhone using Tapatalk Pro
noaim
Milwaukee, WI
Ham is turned on very weird both radios using stock antennas
Sent from my iPad using Tapatalk Pro
Ubbe
Stockholm, Sweden
Can you hold the SDS200 on that channel, push enter and disable CTCSS by setting it to search or off, and turn down squelch to zero and listen when the repeater is active for any kind of signal. Try moving the scanner as just a few inches could make a big difference when using an antenna inside a room with all the reflections going on.
/Ubbe
dfw1193
Venus, Texas
Make sure all service types is turned on for a test, set the global filter to off for the test, be sure your ctcss tone is correct. If it still does not receive it I would try another signal with a ctcss tone if the 100 gets it and the 200 dont side by side and work it from there, at least you can compare, if you are a ham and have several handhelds you can goto a simplex freq setup a ctcss tone on all sets and transmit a test message to make sure the sds200 ctcss tones are working right and troubleshoot from there.
dfw1193
Venus, Texas
Also I see your 100 signal is -86db play with the filters on the 200 and see what the rssi shows when the 100 gets a signal on it.
N5XTC
Hampton, Virginia
what does
what does the global filter do? mine was set to normal on my 200 and i just sent it to OFF. i could read the manual, but i just got the scanner and have not delved into that yet.
RCjim
New York
My SDS200 has a USB A port on the front of the unit what is that used for? Can I plug my 100 in and use it to power or charge my SDS100? Thank You
N5XTC
Hampton, Virginia
put an RS 800 antenna on the 200 using an elbow adapter. seems to do better than the stock telescoping whip on p25 systems here. anyone else experiment with the antenna on either the 100 or 200?
RCjim
New York
Mr. Upman what is the USB A port on the SDS200 used for, I don't see it in the manual. Thanks
noaim
Milwaukee, WI
How do you set range on sds200? This may be the issue
noaim
Milwaukee, WI
I even made a favorites list and it won’t pick it up the sds100 picks it up anywhere in the house even right next to the 200 the 200 is quiet not sure why even with the same profile on each it just won’t pick it up
TailGator911
Silent Key/KF4ANC
Fairborn, OH
I have 3 of them - Remtronix - and use them on SDS100 and TRX-1 with great results monitoring my Ohio MARCS digital P25 Phase I simulcast system. Great antenna that sells by various names.
JD
kf4anc
