Thanks. If I were going to use my phone with the SDS200 in my truck, it would probably be fairly simple. If I were going to look for a cheap Android something to use, it would probably be even easier. Using it with my SDS100 in the house would be a bit more of a challenge as I'd have to figure out how (if it's even possible) to connect the SDS100 to my network.
Something to think about when I have time.
You're right, I really had no intention to go this far when I started it.
It should run on any Android version later than 7, but Android has some very diverse products, so no guarantees.
You can connect to any of the supported 4 scanners with USB or the Wifi connected scanners with Wifi. It works pretty much the same either way, except for the audio from the wifi connection. There is no way that I know of to get the audio over USB.
For USB you need a cable to run between the phone and the scanner direct, no hubs or anything.
