SDSRemoteDisplay Android App
ProScan
Software Provider
Ontario, Calif.
Menu is fine
Keep pressing the up key until the bar is at the bottom then you will see the problem, the menu moves up.
{edit} Since the operation is reversed, Keep pressing the up key until the bar is at the bottom top then you will see the problem, the menu moves up down.
W1SPG
Florida
StolenLemur
Another radio?
Alberta
I’d like to lend you one of my 436 if you live in Canada if you’re interested in working on maybe splitting the app or having a radio discovery/ and some features will split. I dunno. I don’t program. Or maybe someone from your area has an extra radio they’d like to?
Anyway, thanks for putting your time into this.
W1SPG
Florida
Thanks anyway, but i'm in Florida
littlebigbaby
Midwest, USA
Hey OP, I have been experimenting with using a rooted Android Head Unit (2023 Joying 9") in my car. I'd like to try your software to run on the head unit and plug my scanner into it. Especially interested in the GPS NMEA messages being passed through from the host to the scanner. That could really simplify my mobile setup, especially if the software can run as a background app continuously providing GPS data. Then I won't have to carry my GPS puck all the time and find ways to bury it in the dash and provide it power. If I can just plug the scanner into the head unit, it can piggyback off the head unit's GPS (and power), and that's less cable clutter to deal with. Not to mention the display features. Would you consider making the software link available again?
EDIT my apologies I see it's on GitHub. Release 1.4 · seangildea/SDSRemoteDisplay
Thank you!
W1SPG
Florida
Thank you!
FYI, It is not currently setup to provide GPS data while running in the background, but let me know how it works out
Reconrider
Inside the Galaxy
Radio Galaxy
I would like to put it on google play for free, but google requires a $25 payment to set up a dev account. Kind of annoys me I have to pay money to give something away free.
I'm sure if you put up a donate link everyone using it on here will donate to help you achieve that google account at no cost to you
hydes2004
Thanks. Yes I did. I cleared cache, rebooted, reinstalled. I’m running a clean version also. Nothing else on this phone. What baud rate and gps location format works best?
W1SPG
Florida
I created an virtual device for a Pixel 3a running android 12 and it opens fine, but I can't run it on the emulator due to the USB connection not existing.
Maybe try downloading it again?
The baud rate doesn't matter, the scanner seems to autodetect whatever speed I give it. Not sure why there is even a setting for that.
The GPS format I use is DDD.ddddd, but I'm not sure that matters either
F1RLN
Biarritz, FRANCE
Hi all,
My phone, running Android 12 through OxygenOS, is constantly saying "Not Connected", no matter what unit (SDS 200 / Phone) I do first turn on. I've tried both USB sockets at no vail. Did you guys have trouble with a micro-USB/USB-C adapter or is it a fail safe go-through thing?
When questioned, App info is showing "version 1.0" even if the 1.4 apk has been installed.
That's kinda poor, sorry!
hydes2004
I was able to get it to work without issue. I bought new usb otg cable.
W1SPG
Florida
Hi all,
Never tested it with OxygenOS, may not work. Try connecting the scanner after the app is launched.
I've used adapters, but yours could be charge only
hunterca
SDS150
Ottawa
Are you using the SDS100 scanner? If so, you need a mini USB, not a micro USB to USB C. Micro USB is only for power no data comms.
F1RLN
Biarritz, FRANCE
As initially written, an SDS200 is involved. I thought a mini USB couldn't fit on a micro socket and vice-versa ... Already tried to launch the App before/after switching ON the Scanner, no difference. OxygenOS is basically Android 12 with minor cosmetics "enhancements".
