SDSRemoteDisplay Android App
x1sspic
Swanton, VT
"all I would have to do is download the release 1.52 file, go to where the file was saved and click on it to install?"
That is correct. Due to security restrictions, you will likely be met with a message preventing the installation. On my phone the message contained a direct link to enable installation of 'unknown app' from the files app that I use. I simply toggled this on, swiped back, and clicked on the apk, which then successfully installed SDSRemoteDisplay. On my device, you can also go to the app info settings page (for the app that you are installing from - typically your web browser or files app) and toggle this setting (install unknown apps).Screenshot_20250105-100440~2.png
dmfalk
Eureka
I guess I should just bite the bullet and put it on Google play
Depends on whether you want to keep it free or not. Google Play charges developers, even when something's free, so some have gone to adding ads, even from ad sources that aren't exactly on the up-and-up, just to pay developer fees.
W1SPG
Florida
To put it on Google play, I need to do a "closed beta" first. Which means I need 20 beta testers. Anyone want to volunteer?
If so, send me an email to W1SPG.Radio at gmail.com. I think all I need is your email address.
Not sure what the testing involves, probably just installing the app and telling me if it doesn't work
W1SPG
Florida
I only got one response, so I will not be able to publish the app on Google Play. Have to stick to sideloading.
WatnNY
Living The Dream In Tennessee
I didn't see your post until today. Did you say it was like $25 for you to post it on Google play? Heck, I would gladly pay half of that for you for my donation to a great product! I think I have read quite a few people on here say they would like to donate to you, so that should be more than enough to cover the fee, unless I misread something...
WatnNY
So, with the help of x1sspic (I owe that man a cup of coffee!), I was able to get the app downloaded (easy-peasy once you know where to go to get the file!). The app connected to my SDS-100 (to Samsung S20) the first time. When I first plugged them together the font size was too big (see first picture), so I had to reduce the font size on the phone to the smallest possible to get it so most of the words are on the screen (see second picture). All of the touch screen buttons work perfectly. The only thing I can't get the display to do, is go into landscape mode. I'll keep playing to see how to get it to do that.
WiSPG, if you want to try Beta Testers again, feel free to add me to the list.
I think all of us who have downloaded the app and are using it should donate to W1SPG so they can put the app on Google Play! I'm willing to donate if told where to!
cpfinlay
Philadelphia, PA
Works on Samsung 24 Ultra (latest OS updates previously applied). Understanding the differences between USB and Wi-Fi, would it be much effort to add Wi-Fi or would it require a different app? I used to use Uniden's Siren back in the day. It was poorly coded but it worked on certain older phones.
W1SPG
Florida
No current plans to do that
Ubbe
Stockholm, Sweden
Is anyone else getting a "low USB voltage warning" and scanning stops sometimes? This does not always happen. What am I doing wrong?
If you get too much voltage drop in the USB cable then that low USB voltage warning will be displayed. Avoid having the battery charger function on to reduce the amount of current needed. Bad USB cables could have poor shielding and the USB data signal leaks out and interfere with reception so that the squelch thinks that there's a signal and stops scan. So both cases comes from a bad quality USB cable.
/Ubbe
W1SPG
Florida
I get it on my SDS100 when the charging line is disconnected from the OTG Y cable. Check your connections
It's very annoying.
WatnNY
/Ubbe
Thanks Ubbe. It's a cheap USB cable from eBay. Sometimes works with no problems, other times after a while of usage I suddenly get the error.
AngWay
Curious
Buchanan, Va
I just found this. so can i get by using this for the gps feature without buying the gps puck ?
W1SPG
Florida
So u can use a usb c hub in place of the cable from amazon?
No, no hub. Direct connection between scanner and phone.
GPS will work as long as the app is displayed on the screen, not in the background. You could also use an old phone since no network connection is required (other than to possibly load the app)
AngWay
Curious
Buchanan, Va
Ok i got i tried it with a hub and i got it working or at least it shows gps on the sds100 but i have to keep disconnecting and reconnecting like 10 times before it will show that, the first time i connected it it starting showing the channels scan but i can't get it to do that anymore. i'll buy the cable maybe it's because of the hub i'm using causing the issue. it works fine with my 536hp not so much with the sds100
