Sentinel vs. RRDB
dvendt
Elysian, MN
I was just comparing the Sentinel database and the RRDB and they don't jive. Looking at the MN db's, Blue Earth Co. freq.s on the on sentinel have no matches on RR. Waseca Co. do have some matches but the Sentinel doesn't have the control channel. I noticed this with quite a few counties. Am I comparing these wrong? Has anybody else notice this?
kevino
Database Administrator
Chicagoland
I have heard that the Sentinel database hasn't been updated for something like a couple of weeks.
nessnet
What month is it?
This would have nothing to do with his question - unless the counties in question have been VERY recently been changed.
ScubaJungle
West Central Florida
I've noticed that the arrangement is often different. By me, there were a few systems and frequencies that seemed completely absent from Sentinel, but they were under a department/site of another system, so it took some digging around through "businesses" or "industry" to find.
I dont think I've seen any completely different entries though, especially in the case of a system that wasnt recently updated.
I just checked out the county youre referencing, and it looks like the frequencies are there under
"Blue Earth"
then "Blue Earth County - Cities, Mankato, Good Thunder"
the "ARMER" system is under "Statewide"
cm205
In the past I have noticed similar discrepancies - systems that were listed in the RRDB (and had built out sites and talkgroups) not being pulled into Sentinel's nationwide database. Also, some incorrect or absent color code information for DMR systems. It has been relatively rare, and did not impact systems I frequently monitored. They seem to be corrected after a few months, so I don't know if they were fixed on the RR or Uniden end, or something just unjammed in the system.
hiegtx
Dallas, TX
Where are you looking? I'm not seeing what you are describing.
Waseca in the Sentinel Database:
84770
Same site on database page
84771
New Richland in Sentinel
84772
New Richland on database page
84773
Mapleton (Blue Earth) in Sentinel:
84774
In the database
84775
Lake Crystal- Sentinel
84776
In the database
84777
Sentinel does not flag the control channel, as by default, it includes all the frequencies in the database.
While the frequencies in Sentinel and on the database page may not be sorted the same way, the same frequencies are there in both sources.
If you are seeing a difference somewhere else, provide a link or description as to where that can be found.
dvendt
Elysian, MN
Sounds good. Thanks all. That's what 48 hours without sleep will do to an old fella. I hate insomnia.
dvendt
Elysian, MN
Should I go through and delete all the voice channels and keep only the control and alternate channels or is that a bad idea? Want to speed up scanning rate if possible.
jonwienke
More Info Coming Soon!
VA
No. The scan speed difference is negligible (<5%), some systems rotate the control channel regularly, and if you delete the voice channels, you'll miss all traffic when the listed control channel isn't actually being used as the control channel.
dvendt
Elysian, MN
Thanks for the info.
ofd8001
Louisville, KY
If you want to "gild the lilly", you could move the known control and alternate control channels to the top of the list of frequencies. That scanner "latches" on to the the first active control channel it sees and forgets about the rest of them. I'm not sure the effort is worth it, except to the most discerning scannist.
Jimbnks
Central, KS
I have done this, as well as monitor the tower in the current activity mode to see how the channel are rotated on a regular base, and adjust the list in on my scanner. It has speeded up the scan some.
