Are Ellisville and Eureka still on Muni-West or have they been moved? The 3rd was moved from 3/5/7 to 3/4.
They were still on Muni West last evening and I assume they will stay there.
The only one I saw that has multiple talkgroups now is West County Dispatch Center using 55414, 55415 and 55416.
414 was being used for Creve Coeur, 415 I assume is Frontenac and 416 was Town & Country. Of course these are not STL County talkgroups. West County Dispatch center was formed to dispatch for just a few cities in its area and they kept the same frequencies each city was on before the common dispatch center was formed.
County PD TG ranges run from 55394 to 55399.
They have others as well but those will be encrypted. Things like the old car to car channel will no longer be monitorable and I assume most of their riot channels will also now be encrypted.
It's pretty easy to decipher which TG is used for Muni-North and West as the car numbers will generally contain a letter. Like for Chesterfield, it is usually heard like 5Charles24. I forget what letter Eureka used but Muni West also dispatches one area that uses simple 4 digit car numbers (no letters) which very well could be the Eureka cars or the car numbers used before Muni-West became a channel and was still just a precinct.
I seem to recall them being in the 6,000 range but am not sure if those were Eureka cars or areas that Muni West dispatches for the actual 5th or 6th precinct. The Muni channels used to be just unincorporated areas but most of the areas north and west dispatch for are now incorporated cities but kept a dispatch contract with the county.
Check the WIKI for St Louis County PD and it will explain the contract cities the county dispatches for. I'm not sure how up to date the wiki is but it should get you close.
I think Fenton is the only city that still uses an actual Precinct number.
That also gives them their own talkgroup within the six County PD talkgroup range. Fenton could be the precinct considered 6.
There is also an 8!
In short, Muni-West and North both still dispatch the same cities they did before moving to Slater.
55394 - StL Co PD: 1st Precinct
55395 - StL Co PD: 2nd Precinct
55396 - StL Co PD: Muni West
55397 - StL Co PD: Muni North
55398 - StL Co PD: 3/4 Precinct
55399 - StL Co PD: 5/7 Precinct
55414 - West County Dispatch Center - Creve Coeur PD Dispatch
55415 - West County Dispatch Center - Frontenac PD Dispatch (not positive on this one, someone needs to confirm)
55416 - West County Dispatch Center - Town & County PD Dispatch
West County could have others as each of the above cities had multiple analog PD channels but I'd imagine those will now be on both, encrypted Support channels and clear City channels that could be marked as Public Works depending on how they get listed.
