So, the MD380?
FireBall517
Clinton
Is it actually worth it?
I've seen that it could accept modified software. Does this allow for any more digital modes? I'm excited to get one, I've also noticed the newer model of this radio. Can it accept mod firmware as well? Is this dual band? I hate to be lazy because Google never works for me at work, its blocked. However this site isn't.
jonwienke
More Info Coming Soon!
VA
It's DMR Tier I and II, even with the "aftermarket" firmware. The same is true of the MD-390.
None of the TYT radios are dual-band.
The main difference between the 390 and 380 is the 390 has an IP67 waterproof case, and can be had with an internal GPS. The 380 has a less robust case but very similar internal guts.
Dafe1er
Off in a far away place, far from u.......
I love my 380. Wish I would have bought it sooner. If you have dmr systems around you, you'll enjoy using it as a scanner and if you are a ham, you'll really enjoy using the radio.
Sent from my SM-N920P using Tapatalk
FireBall517
Clinton
I would like to get one because I know we have a few businesses around that utilize DMR, specifically our utility board. I believe we have a few DMR repeaters, but I would probably need an amp or a Yagi to reach them.
Other than that, our area has D-Star or Fusion. I'd like a P25 cheapie like this radio.
ArtU
Is TDMA {DMR 4fsk} somehow different on amps then FDMA {Fusion 4fsk}? Fusion repeaters do not need any special amps. The repeater amp is expensive because it must hold up to 100% duty cycle, where home amps do not, just need to run lower duty cycles. Also DMR commercial amps must hold up to expensive interference standards as MotoTurbo is one of the large causes of inter-mod in the City Inter-mod ally even with their increased filters...
The HD TV revolution had folks selling special HD antennas when old fashioned ones work even better, the RF part is RF. The Amp sees 9600 baud FM modulated RF on digital modes.
Art
wx5uif
Broken Arrow, OK
If I remember correctly, repeater amps don't need to be special.. but subscriber radios would have to have special fast switching amplifiers.
N4GIX
Hot Springs, AR
ArtU
Thank You, that makes since perfectly on the subscribers portables. Thanks for the link.
