Sticky Thread for MilAir II
TinEar
Glen Burnie, Maryland
Mark said:
1149z this morning heard a FLASH 29 with Andrews/Griffin Command self id as
C-37... New callsign for me..
PS: I see today on Airliner net that Dover's latest C-17 06-6167 is about ready for delivery..
http://www.airliners.net/search/photo.search?aircraft_genericsearch=Boeing%20C-17%20Globemaster%20III&distinct_entry=true
Mark, I presume you mean new callsign for C-37 types. Yours was a C-37A from the 310th AS at MacDill. There were two of them at that time in the area....01-0028 and 01-0029. (Edited from original as new info turned up.)
We'll have to keep an eye out for Dover's new Charlie 17. They must have a camera fixed in place out there for those C-17 photos. Every last one of them is taken from the same spot with that Marriott hotel in the background.
0900: COSMIC 41 (F-16, NJ-ANG, Atlantic City)) flying...138.2 (CAP starting)
0901: TANKER 21 with HUNTRESS....260.9
0907: TANKER 21 to HUNTRESS says he was told the area (CAP area) was not hot yet...he's leveling at FL 270...260.9
TANKER 21 is a KC-135R, tail 61-0298, from the 126th ARS, WI-ANG at Milwaukee.
0910: COSMIC 41 flight w/HUNTRESS....139.7
0911: COSMIC 41 reports as fragged and holding outside the airspace per ATC...139.7
0914: COSMIC checking in with HUNTRESS on Uniform freq...TANKER 21 reports at FL 250 and says he's cleared into the area at this time...260.9
0914: TANKER 21 checks in with Potomac at FL 250...tells Potomac he's unreadable on this freq and asks for another one...gets 126.55....350.25
0914: COSMIC 41 checks in with Potomac on 135.525 (He spells callsign as COSMK...so we're going to have to change full spelling to COSMIK after all this time)
0917: COSMIK 41/42 told to use 350.25 so switch over there...they make arrangements with HUNTRESS to use Victor freq 139.7 for ops
0917: COSMIK flight sent now to Potomac's 269.5 and check in there...(This is getting to be a circus with freq changes)
0918: COSMIK 41 gives a PIREP to HUNTRESS and performs the Datalink's alpha check to the bullseye....139.7
Potomac really has the freqs screwed up this morning...TANKER 21 had to settle for 126.55 and COSMIK 41/42 for 269.5 for their ATC freqs. TANKER 21 seems to be working HUNTRESS on 260.9 and COSMIK 41/42 on 139.7. TANKER 21 is now in the regular orbit at FL 240.
0926: MARINE 1 is calling HARASS instead of HUNTRESS on 260.9 (He's a a little confused apparently by last weekend's CAP over Kennebunkport where HARASS were the fighters from Langley.)
This makes two CAPs in a row now that Shaw hasn't had the duty. Guess they've been taken off the s***list.
0930: The CAP is in place now...the only remaining question is which boom freq they'll use when they get around to the first refueling. (Answered at 1013 below)
0958: COSMIK fuel checks...41 has 7100 and 42 has 6900 pounds...both report outboard tanks dry...139.7
0958: BLACKJACK 1 calling HUNTRESS...139.7
Second half of 0900 hour has all kinds of transports, tankers and LBEs moving around the area. There is a pair of TEAM KC-10A tankers from McGuire (79-1711/79-0434) working interplane 139.875 and with ZDC-Salisbury 120.975 in the block 220-230 for their work. LBEs galore...one of them, Navy 7C511, is coming into Andrews to pick up a Navy 3-star and will actually take another couple of pax if they want a seat. Imagine that! Add a couple of C-9B types from VR-56 and VR-52 also into/out of Andrews.
0958: JEDI 62 (C-17A, 03-3127, 6th AS McGuire) climbs out of McGuire and starts on a southerly route....with ZDC VHF
1007: COSMIK 41 tells 42 he's cleared to the tanker at 15 after the hour...139.7
Early 1000 hour there are F-16s flights working from the DC-ANG Andrews on interflight 143.6 (SCARY flight of 4) and from NJ-ANG 138.875 (BANGER flight of 2). SCARY flight with ZDC-Hagerstown at FL 190 at 1016 on 227.125. Heading north.
1013: TANKER 21 and COSMIK 42 meet up on 139.7 to begin the AR op.
1019: COSMIK 42 completes AR after taking 7000 pounds...they used boom intercom so no tails or other info from them....139.7
1019: SCARY flight handed off to ZNY-Middletown...check in at FL 200...mention asking if they got info from RANGER...322.4
1020: COSMIK 41 heading to the tanker...139.7
1022: SCARY flight cleared into Delta/Echo airspace in R-5802 (Bollen Range)...322.4 (When was the last time we heard F-16s working Bollen?)
1023: COSMIK 41 cleared to contact the boom of TANKER 21....139.7
1024: SCARY flight handed off to the range, they push Button 15 and check in with BALKY, the range controller at Bollen Range....flight leader gives BALKY the various missions and armaments they'll use for their attacks...237.2 (Flight is still using 143.6 for interflight chat...SCARY 2 is a female)
1024: BANGER flight working ACM activity with a simulated DARKSTAR AWACS controller....138.875
1027: COSMIK 41 completes refueling after also taking 7000 pounds...tells HUNTRESS he's reestablished in the CAP....139.7
1028: COSMIK fuel checks...41 has 12,100 pounds and 42 has 11,600 pounds...139.7
1040: Dover's new C-17A (06-6166) off the ground...349.4
1041: COSMIK 42 given a track to monitor for now (36260 on his datalink)...139.7
1043: TESTER 15 (T-38C, 59-1604, USN Test Pilot School, Patuxent NAS) just performed a supersonic run about 20 miles to the southeast of Pax...reached 1.05 mach at FL 330...354.8
1043: RAVEN pair of A-10s up from Martin State...working interflight...142.3
1045: Raven Ops talking to AXEMAN A-10s on the ground at MTN so expect more in flight soon...347.2
1048: RAVEN flight chatting about AXEMAN flight not being off the ground yet...142.3
1045: COSMIK 42 told to skip it on the track he was monitoring...139.7
1052: TANKER 01 coming into the area...says his boom is in the green...10-15 minutes out yet....260.9
1054: RAVEN 1 to Raven Ops says the helo rendezvous will not occur until 1130...143.8
1056: TANKER 01 asks HUNTRESS the altitude to enter the area...told FL 250...260.9
1058: RAVEN to ???? to say AXEMAN will be 10-20 minutes late...plan on rendezvous for 1120 local...143.8
1059: COSMIKs given track 30040 to watch...42 doesn't see him, 41 has a lock at 7000 feet on the target....139.7
1100: TANKER 01 wandering into the general area...he's a KC-135E, tail 57-1496 from the 132nd ARS, ME-ANG at Bangor....260.9
1101: HARASS 33/34 (F-15 Langley) coming into the area to pick up next CAP shift....260.9
1102: TANKER 21 asks HUNTRESS if HARASS needs gas...says it will help him out for his landing fuel requirements.....HARASS says he can take 2000 pounds and that's all he can handle...260.9 (After all is said and done...it seems no one will take gas from TANKER 21...he says he'll "make do")
1103: COSMIK 41 asks HUNTRESS for position of the HARASS flight...260.9
1106: SCARY flight on the way home to Andrews...all four jets are Code 1 status...143.6
1107: TANKER 21 asks HUNTRESS for estimated time of their release from the CAP....he's cleared to RTB...260.9
1109: TANKER 01 has been descending for arrival into the CAP...he's made it down to FL 250...260.9
1111: HARASS 34 does his bullseye check.....he's told to go to 139.7 but responds he doesn't have VHF, wants to work HUNTRESS Primary (260.9)...260.9
1112: TANKER 01 says he'll work VHF with COSMIKs and then switch to UHF for the HARASS flight...260.9
1114: AXEMAN flight (A-10 MD-ANG MTN) reports airborne at 12 past the hour...347.2
1116: I was sure TANKER 21 was told to RTB but he's still orbiting at FL 240 in the area....TANKER 01 is in but using FL 250 for now.
1118: AXEMAN 1 contacts RAVEN 1 on Ops freq 143.8 and says his flight is 7 minutes out from Red 1...RAVEN 1 says he'll send him some info.
1120: COSMIK 41 reports final fuel as 7800 pounds and he's Code 1...139.7
1122: RAVEN gives routing to AXEMAN...red 2, red 5, blue 1, blue 4, blue 3, blue 2, red 10, ROCKFISH, Objective...egress red 6, red 4 (I have no blinking idea what that's all about)...143.8
1124: COSMIK 41 tells HUNTRESS they'll push 138.2....push button 16 to get to 138.2
1124: HARASS 33/34 established in the CAP...260.9
1125: COSMIK 42 reports he's Code 2 for radar altimeter...41 says he's still Code 1....138.2
1126: COSMIK 41 cleared 43 off to fetch the ATIS report....138.2 (on their way home now)
1127: TANKER 21 on his way out of the area finally...now up to FL 310...(didn't hear him get clearance -- didn't know which freq to monitor the way they were switched around upon arrival into the area)
1129: Tail numbers to TANKER 01 from HARASS 33/34...33 is 81-0036 and 34 is 83-0013.....260.9
1131: Looks like TANKER 01/HARASS 33-34 will use HUNTRESS Primary for an AR freq....260.9
1135: COSMIK 41/42 flight was w/ZDC UHF but I wasn't paying attention...now with Atlantic City Approach and report 17 miles east of Sea Isle...327.125
1135: COSMIK 41 reports heading to runway 31 for full stop...327.125
1140: HARASS 34 reports nose is cold...heading to the tanker...260.9 (By the way, HARASS 33 has called himself HARASS 61 several times - at least I don't think there's a third F-15 involved.)
1141: RAVEN and AXEMAN flights are still passing coordinates back and forth for that unknown type activity they're involved with...AXEMAN is calling ASSAULT on same freq but since I can't hear whoever that is, I don't know what he is or what he's doing...143.8
1142: There are F-22A flights going to the offshore areas with Giant Killer...249.8
COSMIKs are gone home, TANKER 21 has gone home...TANKER 01 and HARASS 33/34 are established for the next four hours so it's break time. Color me outta here!
nightwatch
Wisconsin
cap is up
tanker 21 checked in on 260.9 cosmic f15's on the way or so huntress told tanker21.audio feed is on teamspeak ip 12.172.250.250
CitationJet
Northern Virginia
Re: QUID 99
Hi Tin,
The 351st ARS USAFE is actually based out of RAF Mildenhall and I'll bet he was headed to Robins for maintenance...I hope so, I hope so he says, because I'll be down there next Thursday or Friday! :cool:)
Best regards,
Tony
TinEar said:
Nice catch on that QUID 99 Tony. He was tail 61-0299 from RAF Lakenheath in the U.K. The 351st is an extremely busy unit.
BM82557
Berkeley Co WV
Cap 07062007
0851 - HUNTRESS to Tanker 21, you'll have 2 16's out of Atlantic City, callsigns COSMIC 41 & 42, they're not yet airborne - 260.9
0902- HUNTRESS to Tanker 21, the 16's are airborne, 60 miles east of the cap - 260.9
0903 - COSMIC 41 checking in with Washington Center (Swann), at 16000' - 360.7
0906 - COSMIC 41 working Swann - 360.7
0906 - activity on MUSSEL freq - 241.0
0911- COSMIC 41 requesting uniform freq - 139.7
0913 - HUNTRESS with COSMIC 41 - 260.9
0914 - HUNTRESS verifiying that Tanker 21 wants to use 260.9 as boom freq - 260.9
0914 - MUSSEL 07 on final M1 - 241.0
0915 - COSMIC 41 - 135.525
0916 - COSMIC 41 - 350.250
0916 - COSMIC 41 instructed to go back to v freq 139.7 - 260.9
0917 - HUNTRESS telling Tanker 21 that COSMIC flight will be on 139.7 - 260.9
TinEar
CitationJet said:
Hi Tin,
Best regards,
Tony
Of course it's Mildenhall. I let a personal memory at Lakenheath creep into my post (somehow.) The 351st ARS of the 100th ARW has such a fantastic past and it's great that they still honor the "Bloody Hundred" and still have that lone D on their tails. I guess that's the only Air Force unit to carry a single letter on its tail. At one time, the 351st had to be augmented by stateside units deploying to them because of their extremely heavy workload refueling most of NATO. I guess those days are past now that they've had more tankers assigned to them. Anyway, it was great to have that one come through the area. Hope he is at Robins for you to take a peek at when you get there.
TinEar
Getting close to 1500 so we should have a shift change soon in the CAP. AT 1454, TANKER 01 is requesting FL 320 leaving here for his trip back to Bangor ME and checking the weather while he's at it.
1448: REACH 383 (C-17A, 98-0054, 62nd AW McChord AFB WA) on his way into Andrews...378.1
1450: Belgian Air Force 618 (A-310, tail CA-01, 21 Squadron) making its way toward Andrews. He came off the Atlantic, across southern Delaware and is currently over the Bay. At 1503 he's with ADW Tower for landing...118.4
1450: RAVEN and AXEMAN flights still working MD-ANG Ops freq 143.8 in the exercise they've been working for the past few hours.
1456: TANKER 01 has been given the RTB command by HUNTRESS...260.9
1456: TANKER 02 on the way in...he's a KC-135R, tail 58-0117 from the 171st ARW PA-ANG at Pittsburgh...260.9
1458: REACH 4837 (KC-135R, 64-14837 from the 22nd ARW McConnell AFB KS) climbing out from Andrews...TRACON (he came in last night as EVAC 44837)
1503: TANKER 01 with ZDC-Brooke departing the area via Nottingham...327.0
1504: HARASS 35/36 sound like they're entering the area...but 35 was just telling 33 about some problem with 36...260.9
1507: TANKER 01 handed off to ZDC-Bay and checks in in a left hand turn to Robinsville...will maintain FL 240...379.3
1508: HARASS 33 and 35 go to AUX freq 360.15 to set up the transfer and talk about a problem aboard 36. 35/36 are still 30 miles south. (During the Kennebunkport CAP the HARASS F-15s used this freq for the entire CAP for interflight chat)
1510: HARASS 35 gives the game plan to HUNTRESS....36 has a flight control problem....so, HARASS 33 and 36 will head for Langley...34 and 35 will maintain the CAP until 36 can get a new jet and return and then 34 will go home...260.9
1516: HARASS 35 gets together with Potomac on the 269.5 freq (Everyone is having trouble hearing Potomac today on the 135.525 and 350.25 freqs)
1517: HARASS 35 asking HUNTRESS for a point out to TANKER 02...260.9
1519: HARASS 33 tells Potomac he'll be leading HARASS 36 (on the trip back to Langley)...269.5
1520: HARASS 33 and 36 are joining up for the trip...tellls HUNTRESS they're holding hands for his call for RTB....told to scoot on home...260.9
1521: HARASS 33/36 to Potomac to report RTB at this time...get clearance via Nottingham, Harcum, direct Langley...269.5
1522: HARASS 33/36 go over to 360.15...36 is asked if he needs to dump fuel and 36 says he does...33 tells him to do it now and get down to 9000 pounds....360.15 (If you suddenly feel rain and it smells funny....)
1524: HARASS 33/36 report to Potomac they're exiting the area at this time...269.5
1525: HARASS 33/36 handed off to ZDC-Calvert and check in there...281.4
1527: HARASS 33/36 discuss procedures for landing on runway 26 back at Langley...360.15
1530: HARASS 33/36 leaving FL 210 for 10,000 feet...281.4
1536: HARASS 35 tells 34 about needing to man the north part of the CAP...260.9...they change to MAN Prime 360.15 where 34 wants to know what constitutes the "north"
Shift change is done - at least until HARASS 36 gets back with a new jet so that will end the CAP log for now.
A few minutes ago in the middle of that CAP changeover, I heard JEDI 62 (C-17A, 03-3127, 6th AS McGuire) on FSS freq 255.4 talking to Raleigh Radio asking for weather reports. Not sure where he was but he's heading to McGuire. There was also an EVAC 33116 (C-17A, 03-3116, 183rd AS MS-ANG Jackson) heading toward Andrews. There has also been a REACH 3037 (C-130H, 93-1037, 50th AS Little Rock) calling McGuire with no joy on 319.4
Done again. Back later.
freqhopping
VEGAS-52 calling Raven Ops on 347.2
1620- Heard him with center, did get the freq though.
1628- VEGAS-52 on 270.275 and HARASS-36 is heading back, currently over Hopewell.
1629- DRAGO-51 with TRACON 335.5 FL170 direct Linden. Handing off to 319.1
1630- HARASS-36 with ZDC-Calvert
1632- HARASS in the CAP advises that 36 is 120miles out.
1637- DRAGO-51 (not a heavy) to 371.9. FL260 for 280. Hearing ZDC-Linden controller perfectly with my BC890+RS mag mount.
1850- TANKER-02 cleared back to Pittsburg via Indian Head and NESTO. TANKER-03 is inbound at 180deg 70miles from bullseye.
1930- HARASS-42 110miles out. 357.1 Irons Ops
n3bxv
Severn, MD
DPD1 Quote:
Originally Posted by TinEar
Dave, my question about HARRIER 01 was kind of rhetorical. It's not a new call. They've used that callsign forever in the Guard Dog CAP in this area. It's just that we've never pinned down precisely what type helo it was and from where. I previously thought it was a Coast Guard helo (could that picture be an MH-60 type?) from somewhere in the area. I'm not sure it's always the same helo that has the mission of being HARRIER 01 during the CAPs but it's probably from the same unit. I was under impression though that all Coast Guard helos bore the service's colors which the one in the photo certainly does not. So, it's an H-60 of some flavor but we still don't have the unit pinned down. Your guess of it being from Oceana is as good as anything else we've come up with.
DPD1 said:
Yeah, that's what I was basing it on... I've never heard of any basic gray USCG ships. I don't think there are any. The closest mission ready Navy helos in the area would be one of the HSC units from Oceana. That would be either HSC-22, 26 or 28. I doubt the FRS would handle that. It looks like a 60S to me, which all those units have. There's also HCS-4 which fly's the 60G. That seems like it would be more of a 60S mission though. I've never heard Navy helos involved in VIP protection out here, but I think they take that stuff more seriously on the east coast. But who knows, they may have done it around San Diego at some point. The only other thing I can think of is that the base flight at Brunswick or Pax now has a 60S. That's not out of the question, because Whidbey replaced their base flight H-1s with the 60S. So my guess is 60S from one of those units for that incident at least. It might be a shared mission with the USCG though.
Dave
www.DPDProductions.com
Makers of the "MilTenna" Monitoring Antenna
At least some of the missions are flown by US Army UH-60's
http://www.decaturdaily.com/decaturdaily/news/051029/warrior.shtml
TinEar
First CAP shift this morning is manned by HARASS 33 and 34 (F-15s from Langley) and TANKER 04 (KC-135R, 62-3506, 133rd ARS NH-ANG Pease). Primary freq with HUNTRESS is still 260.9 - also used for a boom freq. Fighters interflight is 360.15. Sounds like HUNTRESS is transmitting from two different antennas at times. Sometimes he is loud and clear from here and other times I can't hear him at all.
CitationJet
Northern Virginia
07.06.2007
Hi,
Some logs from very brief monitoring opportunities yesterday...
1356Z 139.700 HUNTRESS - COSMIC 41/42 (F-16C/D 119th FS NJ ANG) - passing operational figures.
1406Z 139.700 HUNTRESS - wkg COSMIC 41 (F-16C/D 119th FS NJ ANG) for rx check. COSMIC ready for tanker in 15 mins.
1411Z 251.500 USN Andrews PTD - YANKEE 85 (KC-130T VMGR-452 Stewart) - C-130 10-15 mins. out.
1412Z 143.600 121st FS DC ANG IF - SCARY 2/3 (F-16C/D 121st FS DC ANG) - up with operational chatter.
1413Z 260.900 HUNTRESS - TANKER 01 wkg COSMIC 42 (F-16C/D 119th FS NJ ANG) coord. refueling.
1420Z 139.700 HUNTRESS - COSMIC 41 (F-16C/D 119th FS NJ ANG) - heading to tanker now.
1427Z 139.700 HUNTRESS - COSMIC 41 (F-16C/D 119th FS NJ ANG) - restablished back in the CAP.
1442Z 354.800 BayWatch - TESTER 15 (T-38C 59-1604 NTPS) - going supersonic at this time FL390.
2015Z 378.100 GRIFFIN CP Andrews - REACH 6418 (C-130H 86-0418 758th AS AFRC) - reporting 20 mins. out req. fuel.
2022Z 279.575 Potomac DEP - DRAGO 51 - 2000' for 5000' then cleared to 17000' dir LDN QSY 118.675
2022Z 335.500 Potomac APP - DRAGO 51 - comes back looking for correct freq. sent to ZDC-Linden 120.650.
CitationJet
Northern Virginia
07.07.2007 am
1218Z 260.900 HUNTRESS boom TANKR 04 (KC-135R 133rd ARS NH ANG) - advises HARASS 34 took on 8.2 fuel.
1219Z 260.900 HUNTRESS - HARASS 34 (F-15C/D 71st FS Langley) - advises in the CAP arms safe.
1231Z 260.900 HUNTRESS wkg HARASS 33 (F-15C/D 71st FS Langley) - "I'm not sure if anyone told you, but there must be one fighter established in the northern part of the CAP at all times."
1235Z 260.900 HUNTRESS - HARASS 33 (F-15C/D 71st FS Langley) - advises HUNTRESS now proceeding to tanker, has visual. HUNTRESS requests check nose cold weapons safe cleared for contact.
1241Z 260.900 HUNTRESS - HARASS 33 (F-15C/D 71st FS Langley) - arms safe has contact with TANKR 04.
1244Z 260.900 HUNTRESS - wkg HARASS 33 (F-15C/D 71st FS Langley) - requests verify present position and track to confirm you are not a TOI. "Just wanted to make sure that was you falling off there..."
1250Z 260.900 HUNTRESS - wkg TANKR 04 advising replacement is about an hour and four mins away for a 1325Z scheduled on station. TANKR 04 advises we were told RTB was 30 mins from now. HUNTRESS advises they show TANKR 04 as fragged Guard Dog 0950-1400. HARASS 33/34 advise TANKR 04 that they will not need further fuel, might need a boom check on one and a top off on the other.
1310Z 260.900 HUNTRESS - HARASS 34 reports to 33 that he will be relieved by HARASS 35 in 50 mins.
1325Z 260.900 HUNTRESS - HUNTRESS passes 1255Z Pease wx to TANKR 04.
1327Z 260.900 HUNTRESS - HARASS 34 wants 2k fuel. HUNTRESS requests if HARASS 34 can wait for TANKR 05? TANKR 04 says they can do 2k no problem.
1330Z 260.900 HUNTRESS - wkg TANKR 05 will be fragged in the Guard Dog CAP from 1400-1900Z FL210-250, req. FL250 from center to enter the CAP.
1331Z 260.900 HUNTRESS - HUNTRESS wky HARASS 33 - will you need fuel? No, time as fragged good to go.
1346Z 135.525 ZDC-Guard Dog - TANKR 04 - advises five min. heads up for RTB. Req. FPR dir OOD-FL310 on a 075 degree heading from present pos.
1351Z 135.525 ZDC-Guard Dog - TANKR 04 - RTB cleared dir OOD FL250 to exit the CAP.
1352Z 260.900 HUNTRESS - TANKR 05 to TANKR 04 - TANKR 05 entering the Guard Dog CAP @ FL250, TANKR 04 is exiting the CAP right around DCA also @ FL@50, but will keep to the northern part of the CAP to avoid conflict.
1354Z 350.250 ZDC-Guard Dog - TANKR 05 - req FL240.
1354Z 269.500 Potomac DEP - HARASS 33 accepts MARSA. Interesting freq here!
1355Z 360.15 Langley IF - HARASS 34 reports to HARASS 33 that TANKR 05 is in the air.
1356Z 260.900 HUNTRESS - TANKR 05 requests that HUNTRESS confirm the end of their fragged duty in the CAP - they show 1830 but 1900 is advised as the termination by HUNTRESS and the PTA for TANKR 06.
1358Z 260.900 HUNTRESS - HARASS 34 to 33 - would like you to have 10K when you leave, 12K for 34.
1400Z 260.900 HUNTRESS - HUNTRESS advises replacement is now airborne.
1408Z 260.900 HUNTRESS - TANKR 05 to HARASS 34 A/R finished, FY is 83- for 34. HUNTRESS advises that HARASS 35/36 are now 40 nms. s of the CAP.
TinEar
Starting about 1020, while HARASS 35 and 36 were gassing up with the tanker, HARASS 33 and 34 were sent after a TOI. HARRIER 1 was also involved. Heard the HARRIER helo asking for bogey dope at 1023. Eventually, Potomac TRACON got in radio contact with the intruder and was directing him into Winchester. HARASS 33 gave the tail number but was so low at the time that it was only partially heard here....28F were the last three characters. Did anyone closer to the action get the full ID for the TOI? Anyway, by 1028 it was all resolved and 33/34 started for home a couple of minutes later as 35/36 had finished refueling and were established in the CAP. Anyone else notice how HARASS 33 kept pronouncing Potomac as pa-TAW-mac?
I don't have a tail number for TANKER 05 but he's from the 126th ARS, WI-ANG, at Milwaukee.
Someone has to pull a five hour shift in a 17-hour CAP day so it was the second shift today - HARASS 35/36 and TANKER 05.
TANKER 06 into the area in the second half of the 1400 hour. He's a KC-135R, tail 59-1523, 171st ARW PA-ANG Pittsburgh.
HARASS 41/42 are the next pair of F-15s on duty until about 1900 local. 42 has made it into the area...no 41 heard from yet. 36 has returned to Langley and 35 has stayed behind.
1457: HARASS 35 calling Andrews Command Post...asks if ADW can connect him to Langley's operations supervisor...gives the DSN at Langley as 574-xxxx...wants to find out the status of HARASS 41...wants to know how long for him to get out here (to the CAP)...378.1
1502: HARASS 35 gets a reply from Andrews CP passed from Langley but since I can't hear the ground controller I have no idea what the status of HARASS 41 is...378.1
They're should rethink the idea of putting Langley F-15s back into CAP duty. A little over a day and they've already had three maintenance problems preventing aircraft from reaching the CAP on time or completing their shift.
1506: HARASS 35 heading to TANKER 06 for fuel...at 1509 he's behind the tanker and is cleared to contact the boom...asks for 2000 pounds...gets it by 1510 and returns to his position in the CAP...260.9
1512: Both HARASS 35 and 42 tell HUNTRESS they've got one hour of flight time (remaining)...260.9
1522: REACH 594 (C-17A, 01-0195, 437th AW Charleston) calling SAM Command...x2, no joy...378.1
1533: REACH 594 makes contact w/Andrews...ETA 1950Z...378.1
1548: HARASS 41 reports in the airspace to HUNTRESS (only an hour late)...checking status of the link (Link 16 datalink)...260.9
HARASS 41 sounds like he has a bad mic...transmissions are cutting out. Confirmed by HARASS 35 that his transmissions "are clipped." Then HARASS 42 tells 41 that only every other syllable is coming out.
1550: HARASS 41 requests permission to head for TANKER 06 and asks if any chicks are in tow...260.9
1553: HARASS 41 behind the tanker and is cleared to contact the boom...makes contact and asks for 3000 pounds...gives tail as FF 83-0013...offload complete at 1555...260.9
1556: HARASS 42 taking gas also...cleared to contact at 1557...will take a topoff...260.9
1557: HARASS 41 trying to call 35 on interflight..no joy...360.15
1558: HARASS 41 tells HUNTRESS he's going to try some radio transmissions and wants to know which are most clear...then he starts calling for radio checks in the middle of 42 being directed onto the boom...260.9
1600: HARASS 35 has called several times requesting to be released now that 41/42 are on station and have reported both able to take gas from the tanker...260.9
1601: HARASS 35 tells 41 he's leaving...41 says he's sorry he was late...260.9
1602: HARASS 42 finishes the AR after taking 13,000 pounds....41 sends 42 to the southern portion of the CAP and 41 is going back to the tanker...TANKER 06 waits a few minutes, then finally asks him if he's coming for more gas, 41 says not for another hour...260.9 (We obviously both heard 41 say he was going to the tanker...however, if he was going to the tanker, he should have sent 42 to the north, not to the south so he knew he wasn't going for gas, just misspoke about the tanker apparently. End of psychoanalysis.)
Okay...end of log. Everyone is in place for the next three hours or so until 1900 local when the last shift should come on duty taking us up to the 2300 end time.
A German Air Force C-160D, tail 51+06 is in the area early in the 1500 hour.
In the 0900 hour this morning I had Belgian Air Force BAF 618 (A-310, CA-01, 21 Sqaudron) in the area.
In the 0700 hour there was a Royal Air Force ASCOT 2307 (VC-10, XR808, 101 Squadron). It was a C1K model that has the tanker role along with transport.
BM82557
Berkeley Co WV
1027 Toi
I didn't get his tail number either. Did hear HARASS 33 tell HUNTRESS that "Potomac approach is talking to the pilot, he is flying into Winchester"
andy3315
Hatboro Pa
Blade 21 VMFA-115 Woked With Knxx GCA Did 3 Par's All Missed Approches And Then To Overhead For 1 T&G Then Landed For A Mairne Bird It Is Really Clean.
