TinEar
BM82557 said:1024 - 1028 -- flight of two working Montebello > Brooke, one's a female. Then showed up on 350.25 calling center. Interflight of 141.75 then active with the female being directed to contact Lessburg radio to find out the center freq for the area.
That's a FAST 71 flight of F-16s from NY-ANG Syracuse that got lost on the freqs when Montebello wouldn't answer them. The flight leader added to the confusion when he decided they'd call on 235.65. He almost got it right and I'm sure he was trying to remember 235.625 (ZDC-Blackstone).
At the same time, there's a FAST 81 flight of two F-16s heading back to Syracuse. Their interflight is 138.175. They've come up through the ZDC freqs and into ZNY. At 1040, they are with ZNY-Milton 269.1 beginning a descent from FL 270 to 230 which probably puts their next stop on ZNY-Binghamton 372.0. (This should be the flight you heard yesterday on 138.3 going down to Avon Park.)
Mark said:I was surprised also to hear that EVAC Load message also.Maybe they got pressed
as last minute tail swap so rather than file new flight plan they stuck with that callsign.
Checking past posts of this aircraft and I had it back in January and March of this year
it was also REACH 9743.
The only reason I can figure history of that tail callsign is that there is also a C-5 from Dover 87-0043 that uses REACH 7043 from time to time so maybe to avoid confusion in Air Force computer system that particular C-17 uses 9743.
I guess that's possible Mark but it wouldn't make any difference in the Air Force computers since they list all the info, including the full serial, and don't depend on the callsign for identification. Everything is spelled out for them including departure/arrival points and the full flight info. The only people to get confused by a callsign are listeners like us that take our IDs anyway we can find them.
Edit: When I wrote the above I couldn't get my database to open, but now that it's working again, I see that aircraft did use REACH 7043 as recently as July 25th. Here's where it's interesting...he used 7043 on March 13th and 18th and 9743 in between on the 15th and 16th. I also have him using both in February. He's got a split personality.
