Sticky Thread for MilAir II
JackTV
Cap Up
Sounds like the CAP is up. Pitman's are the fighters
No A/A yet
228.9
260.9
139.7
Jack
ScanManQSL
QTH: Montgomery County, MD / Washington, DC
Cap Info
228.900 - Refueling
260.900 - Ops
135.525 - GuardDog
143.800 - Chit-Chat (77th FS V-8)
UPDATED @ 1800Hrs
1607Hrs: The CAP is still up the players are SKATOR 07, PITMAN 33 & 34 & TANKER 17. SKATOR 07 & PITMAN 33 has one end of the cap and 34 has the other side. PITMAN 33 is Refueling w/ the tanker.
1614Hrs- SKATOR 07 Advises that he see’s spray coming from PITMAN 33’s left wing and that he has a wet under wing. PITMAN says that this had happen to him before and had stop after a minute.
1615Hrs- For document purposes PITMAN 33is a F16 CJ 60.
1621Hrs - SKATOR 07 is now Refueling
1741Hrs - PITMAN 33 is going back to the boom for more fuel
1842Hrs - I must have missed something when I went downstairs. PITMAN 35 & 36 is up
1845Hrs - TANKER 16 check's into GuardDog for some reason. (135.525)
1858Hrs - PITMAN 33 check's into GuardDog (135.525) and RGBing to the homeplate. (I missed PITMAN 34 & SKATOR 07 checking into GuardDog)
1700Hrs - THE TOP OF THE HOUR STATUS.....THE PLAYERS: TANKER 16, PITMAN 35 & 36
1800Hrs - End of my MilAir log - Im about to go out for the night.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Jay Dehm over on Scan-DC reports that 143.8 is the chit chat freq - that suggest the 77th FS has the duty this time (that's their V-8 freq). 73s Mike
TinEar
Glen Burnie, Maryland
The new pair, PITMAN 35/36 using 139.925 for tac/chat while 33/34 stayed on 143.8 to chat their way home. (139.925 possibly preset V-12)
I had copy on the CAP early today from a hill just west of Hartford, Connecticut. It lasted about five minutes and then faded away as I started down into a valley. Then the roads leading to New York just had too much traffic to play with the radio any longer.
These guys from the 77th FS at Shaw seem to talk a lot more than the 79th did when it was their turn.
2005: PITMAN 35 refueling from TANKER 16 on boom freq 228.9. 35's tail number is 97-108.
PITMAN 35 confirms they are from the 77th Fighter Squadron, 20th Fighter Wing at Shaw AFB. TANKER 16 confirms his tail number is 60-0328 and that they are from the 931st Air Refueling Group at McConnell AFB KS. He also told PITMAN 35 that SKATER 07, the previous tanker, was from the 108th ARW at McGuire which confirms something I had been guessing at. Our callsign database shows SKATER to be at Bangor ME but I had always caught SKATER 07 going back to McGuire when done in the CAP. Changing my callsign list to reflect this.
2014: PITMAN 36 heading for TANKER 16 to refuel on 228.9. TANKER 16 did not ask for his tail number when refueling was completed at 2023.
2123: PITMAN 35 back to TANKER 16 for more gas on 228.9
Based on messages from listeners in the area of Shaw that say they've heard PITMAN fighters spell their callsign on ATC freqs several times, I've changed my spelling to just one "T" from the way I had been spelling it as in Pittman Nevada.
2127: PITMAN 36 to TANKER 16 for a topoff. «228.9»
2136: While on tac 139.925, PITMAN 35/36 indicate the CAP will end early tonight as it has over the past couple...I'm guessing at 11 p.m. and this pair will have it until the end. They said they can't believe another tanker is on the way (considering he'll only be on station for about an hour.)
2233: PITMAN 35 to TANKER 16 for final refueling...says he'll only need 1,000 pounds. «228.9» They should get their total offload for the entire flight this time from the tanker.
2238: PITMAN 35 takes his 1,000 pounds and is told he took 11,600 pounds during his flight. «228.9» Over on tac 139.925, PITMAN 36 decides he doesn't need anymore fuel. 35 tells him to go to boom freq and find out his total offload. He does...TANKER 16 tells him he took 11,400 pounds today. «228.9»
2231: PITMAN 35 tells HUNTRESS they are done with the tanker tonight. «260.9» (Hint to let the tanker go home. HUNTRESS doesn't bite.)
2248: PITMAN 35 to Center on 135.525 but not joy after a couple of calls. Wants to start working his clearance back to Shaw.
2250: TANKER 16 to 135.525 to get his clearance...says in about 5 minutes he'll be leaving.
2251: Guard Dog calling PITMAN 35 on 135.525 but 35 is with HUNTRESS on 260.9 complaining that he has no contact on 135.525 so doesn't hear Guard Dog calling.
2254: TANKER 16 told to RTB by HUNTRESS on 260.9 and goes to 135.525 to pick up his clearance. Guard Dog tells him to maintain FL 250 direct Morgantown.
2255: Guard Dog clears TANKER 16 to FL 350 and gives his routing to Wichita.
2255: PITMAN 35 asks Guard Dog for his clearance to Shaw and does it on ZDC-Swann freq 360.7. He's told to stand by so Guard Dog can work it up.
2256: TANKER 16 handed off to ZDC-Potomac 133.975 where he checks in at 29,500 climbing to 350
2259: PITMAN 35 gets his clearance direct Shaw at FL 250. «360.7»
2259: HUNTRESS clears PITMAN flight to RTB «260.9»
CAP IS DONE
2300: Guard Dog hands PITMAN flight off to Potomac TRACON 343.7 where they check in but call Washington Center. No one argues with them. (First gave them 269.5 and then changed it to 343.7)
PITMAN 35/36 still using 139.925 for chat as they work their way home.
2306: TANKER 16 handed off to 125.425 (Don't know who that belongs to...not following him)
2306: PITMAN 35/36 handed off to ZDC-Montebello 284.7 where they check in.
2311: PITMAN 35/36 sent to FL 220. «284.7»
2317: PITMAN 35/36 handed off to ZDC-South Boston 352.0 where they check in at FL 220.
And that's the end of my coverage and log for tonight.
Ramp Freeze at Andrews in effect 2315-2345
ScanManQSL
10/01/2006 0951Hrs CAP UPDATE
228.900 - Refueling
260.900 - Ops
135.525 - GuardDog
The Players
TANKER 18
PITMAN 41/42 44?
0955
: PITMAN 41 just got 5.4k of fuel from TANKER17
0956: I hear TANKER 18 checking in on 135.525.
0959-1005:TANKER 17 checks in to GuardDog. RTBing back to Lincoln AFB and handed off to WashCenter on 134.15
1030: Its been quiet just small Chit-Chat conversations on 143.8
1033: PITMAN 41 notifies Huntress(260.9) that a thin cloud deck is coming in to the space. He might have to take over some more airspace.
1039: Huntress advices the weather forecast to PITMAN and that the clounds are comming in from the west....The problem is the clouds are at a low altitude.
1045: (260.9) PITMAN 42 requests to hook up with the TANKER.
CitationJet
Northern Virginia
10/02/2006
1339Z 118.950 Potomac DEP - REACH 538T (C-17A) - deps ADW to 13000' dir LDN QSY 120.65.
1344Z 119.300 Potomac APP - PACER 07 (C-21A) - deps ADW @ 2000' VFR dir BRINE for VFR holding.
1410Z 120.650 ZDC-Linden - ARMY 01053 (UC-35C 00-1053) - climbing to FL210.
1414Z 118.950 Potomac DEP - MARINE 981 () - dir HAFNR.
1454Z 118.950 Potomac DEP - REACH 508T () - deps ADW to 17000'.
1550Z 118.950 Potomac DEP - PAT 174 () - deps ADW to 11000'.
1643Z 378.100 SAM CP Andrews - NAVY JU 198 () - clg here no joy.
1655Z 378.100 SAM CP Andrews - JOSA 324 (C-21A) - t/off time ADW 1652Z.
CitationJet
Northern Virginia
10/03/2006
Busy at work so far this am but one from the drive in earlier this am,,,
1332Z 118.950 Potomac DEP - VIPER 01 (C-12 visual confirmation - hunch is that this is 76-0168 89th AW) - deps ADW to 12000' dir BRV QSY 118.675.
...and back at the radios...
1506Z 279.575 Potomac DEP - DRAGO 51 (presumed MAD HOGs out of Willow Grove given dest.) - climbing to 7000' out of 3.9. Requesting something direct, Willow Grove or DQO down the line, DQO preferred.
1545Z 118.950 Potomac DEP - PAT 076 () - deps ??? to 7000' QSY 126.65.
1926Z 119.300 Potomac APP - BOXER 65 (C-40 201st AS DC ANG) - 6000' for 4000' req ILS option then one more ILS.
2004Z 118.950 Potomac DEP - PAT 1270 (C-12T 85-1270 OSACOM VA RFC) - descending for the vis. to rwy 14 @ DAA QSY 126.300.
2004Z 118.950 Potomac DEP - JOSA 318 (C-21A) - deps ADW dir LDN QSY 120.650.
2018Z 126.300 Davison AAF TWR - NAVY 7C 179 (UC-12B NAS Oceana Norfolk Flt. Det.) - lands rwy 14.
2038Z 118.950 Potomac DEP - SAM 0728 () - deps ADW QSY 120.650.
TinEar
I don't have the time to listen much today but there seems to be a boatload of MilAir activity going on. The Philadelphia TRACON, Atlantic City Approach, Dover AFB freqs seem to all be busy with aircraft movements that are probably related to the Dover airshow practice. There were NOTAMs published about flight restrictions and activity related to it.
Also just heard a flight of four probable A-10s land at Andrews at 1252. Picked them up on TRACON freqs 322.3 and then 335.5 before switching to Tower on 349.0 to land. They were using callsign HOG which might make them from either Nellis AFB NV or Barnes ANGB MA.
There is also an AWACS using callsign GOLIATH operating with Giant Killer to the south, probably in area W-122 based on freq usage 251.6. There is also a group of fighters (sound like F-15s) on 288.4, a HUNTRESS freq, in ACM activity that is probably related to GOLIATH control.
The ZNY/ZDC Center freqs are also busy with aircraft movements.
1500: A flight of fighters (probably A-10s) coming down the coast with ZNY-Dixie 307.8 that sound like they're going to Warren Grove Range. No callsigns heard yet. They are at 15,500 feet and say their return trip will be at FL 210. There is also activity on tac freq 141.675 which may be the same flight.
1501: VA-ANG F-16s active on 141.825 tac.
1505: Leesburg Radio talking to PYLON 12 (Not in my database) on FSS freq 255.4 who is entering VR-042 at point "H"....can't hear the aircraft though probably because it's down so low to enter the low level flight route.
1535: AXEMAN flight of A-10s returning to Martin State with Tower on 121.3 for landing. Heard them with Dover on 257.875 and with ZDC-Cofield 323.0 a little earlier.
1538: RAVEN flight of four A-10s returning to Martin State with Tower on 121.3
Published NOTAMs for the Dover AFB airshow:
M0287/06 - DOVER AFB AIRSHOW OPERATIONS IN EFFECT. DOVER AFB PATTERN CLOSED. AEROBATIC/HIGH SPEED/LOW ALTITUDE/MULTILPE AIRCRAFT FORMATION FLIGHTS IN VICINITY OF DOVER AFB, SURFACE TO 15,000 FEET
04 OCT 19:00 UNTIL 04 OCT 20:00 (Zulu times)
05 OCT 18:30 UNTIL 05 OCT 20:30
06 OCT 16:00 UNTIL 06 OCT 21:00
07 OCT 15:00 UNTIL 07 OCT 21:00
08 OCT 15:00 UNTIL 08 OCT 21:00
L0131/06 - AIRSHOW CONTAINMENT AREA ENCOMPASSING SOUTH RAMP, TWY-E AND INFIELD AREA WEST OF APCH END RWY-32. USE CAUTION FOR SNOW FENCING, TENTS, AND MEN WORKING IN THIS AREA. MAKE ALL 180 DEGREE TURNS ON THE APPROACH END OF RWY-32 FROM LEFT TO RIGHT TO MINIMIZE JET BLAST 02 OCT 15:22 UNTIL 09 OCT 23:59
freqhopping
Since there is little activity at all in the Maine forum. I figure I'll share it here. I spent the last weekend in the Freeport, ME area. I didn't get to listen all that much but I did hear some activity from Brunswick NAS. Callsigns heard were TIGER-21 (possibly an E-2 from Norfolk, I know the E-2 is common at Brunswick plus they mentioned something about surveillance), LANCER-?? (visually confirmed as a P-3 while I was in Bath at the Maritime Museum) and BRAVO KILO 292 (could've been general aviation). All the comms were on VHF channels.
Then while on the way home I had a few hit on NORAD's 364.2 while in NE Massachusetts. Later around 1100 in CT there was some refueling activity on 295.8 AR631. I never caught the callsigns but I did hear that the tanker was returning to Albany. At the same time I had activity on 269.2 which I had listed as a HUNTRESS frequency, but it was clearly the Boston Center ground side that I was hearing. On the VHF side I matched it to the comes on 134.7.
TinEar
Travis, I logged a couple of FIGHTING TIGER P-3s from Brunswick NAS last week that came down to the W-386 area to work with Giant Killer. I had an email from someone close to Brunswick who told me their P-3s use both that callsign and just plain old TIGER most of the time. So, that was probably who you heard if he was correct.
1802: Refueling activity on AR-636 primary freq 238.9
1800-1845: There has been activity down in area W-122 with Giant Killer on 251.6 but it's just too weak from here to copy
1849: REACH 7039 calling ???? Dispatch on 372.2. He wants to check NOTAMs for KNGU (Chambers Field, Norfolk)
1849: DC 23 (KC-135R 756th ARS Andrews) with Andrews on 378.1 and tells someone to change to 266.4
1850: DC 23 and DC 21 make contact on 266.4 (All they did was establish comms and nothing more.)
1852: REACH 7039 tells the ground station to read all the NOTAMs for KNGU and he'll pick out the ones he needs. (Ground probably didn't want to read all of them since there are a whole bunch about GPS service being out for various times. Every military base has the same group of NOTAMs that read like this one for KNGU....
GPS NON-PRECISION APPROACH MAY NOT BE AVAILABLE 05 OCT 06:50 UNTIL 05 OCT 07:51....They are for various times on the 3rd, 4th and 5th of October for all bases.)
1858: ROMAN 09 (F/A-18C VFA-106, NAS Oceana) with ZDC-Calvert 281.4
1859: ROMAN 09 handed off to ZDC-Bay 379.3 where he tries several times to check in at FL 250 before making contact.
1901: ROMAN 09 (now female voice) trying to make contact with ZDC-Bay on 379.3
1902: ROMAN 09 (male again) reports speed 310 knots. «379.3»
1908: ROMAN 09 handed off to ZDC-Woodstown 363.0 where he checks in at FL 250.
1914: ROMAN 09 told to descend to FL 200. «363.0»
1920: ROMAN 09 says he'll take a Victor freq for the handoff and is given 127.3. (Won't follow him there.)
1929: BATON 54 (EC-130J, 193rd SOG PA-ANG Harrisburg) with Baton Ops on «395.1» to ask that Ops contact Giant Killer to let him know they won't be there tonight (probably means to area W-107 where he often works). Says he's 60 miles out (from Harrisburg.)
1932: BATON 54 says he's A-3 for a banging noise in the rear (which is probably why he's headed for home rather than to Giant Killer's area.). «395.1»
1932: ROMAN 51 (F/A-18 VFA-106 NAS Oceana) with ZDC-Woodstown «363.0» reporting at FL 250.
1936: ROMAN 51 repeats that he's cleared to descend via the ?COREY?-3 arrival. «363.0» (ROMAN 09 reported the same thing but I didn't even have a hint of what he said at that time. Sounds like COREY-3)
1938: ROCCO 62 (KC-135 108th ARW McGuire AFB) with Atlantic City Approach at 8000 feet and descending. «124.6»
1940: ROCCO 62 cleared down to 7000 feet direct Coyle and then McGuire. «124.6» (Over the next couple of minutes there was an open mic on 303.0 which is their squadron freq so it might have been him.)
1955: SAM 0714 with Andrews Approach on 119.3 and then at 1956 with ADW Tower 118.4 where he reports 10 miles out for the ILS to runway 19L for full stop landing.
1959: Refueling freq 228.0 active (Primary for AR-777) One aircraft slowing to 250 knots since he's about 4 minutes early for the IP...the other aircraft is accelerating to 340 to get there on time. Flight level 210 is being used for the AR.
CitationJet
Northern Virginia
10/04/2006
1308Z 118.950 Potomac DEP - PAT 1204 (C-12T OSACOM VA RFC) - cleared for the vis. to rwy 32 @ DAA QSY 126.300.
1315Z 118.950 Potomac DEP - MARINE 474 (UC-35D 166474 MASD Andrews) - deps ADW to 11000' dir HAFNR.
1318Z 119.300 Potomac APP - VENUS 22 () - vectors for the ILS app to 19L then dir Patuxent QSY 121.0.
1842Z 141.550 GRIFFIN CP Andrews - JOSA 978 (C-21A) - dep msg off ADW.
1847Z 126.300 Davison AAF TWR - PAT 7104 (UC-35A 97-0104 OSACOM VA RFC Davison) - conducting multiple practice apps to rwy 14.
1857Z 119.300 Potomac APP - PAT 304 () - 4700' for 3000' on the app to 19L @ ADW - cleared and QSYs 118.400.
1859Z 119.300 Potomac APP - PAT 255 () - 3700' for 2000' on the app to 19L @ ADW - cleared and QSYs 118.400.
1927Z 118.950 Potomac DEP - PAT 147 () - Davison in sight QSY 126.3 then on the left base for a full stop rwy 14.
Mateo
The Dee Sea
This would be the KORRY3 arrival into LGA. http://204.108.4.16/d-tpp/0610/00289KORRY.PDF
VFA-106 was the unit for the F-18 flyby at Yankee Stadium last night. The flyby at Shea this afternoon was apparently PA ANG A-10s ex Willow Grove.
TinEar
Thanks Mateo. I looked up every spelling of KORRY (but with a C) that I could find on Airnav and couldn't come up with the correct one. Those fixes can be tricky spelling even when you hear it correctly if you're not familiar with an area.
P.S. I just listed my Uniden BCD996T and ARC996PRO package in the For Sale thread at a pretty good price if anyone from this area is interested. It's programmed with a scad of trunked systems and conventional public safety and MilAir freqs for this area which will give you a head start while learning how to use that amazing beast of a scanner.
And a heads up for this area. Tomorrow I'm going to list my Icom R75 for sale on that thread. It's like new and perfect operationally and cosmetically. It also includes the UT-106 DSP option that sells for $140 installed. It covers the HF range and beyond up to 60 mHz. I have three of them but now I just bought an Icom R8500-12 so something has to go. I'm going to list the R75 for $475 including shipping. Take a look at:
http://www.grove-ent.com/ICR75.html
THUNDERBIRD 8 paid a visit to Dover this afternoon around 1510 local in
prep for this weekend's airshow there.
A couple survey passes with appch 257.8750 real strong reception here
before landing.
CitationJet
Northern Virginia
10/04/2006
1337Z 119.300 Potomac APP - BOXER 53 (201st AS DC ANG) - i/b RATTA for the TACAN 1R.
1338Z 118.950 Potomac DEP - AIR FORCE TWO (C-32A 89th AW) - deps ADW to 12000' dir MCRAY QSY 123.825.
1349Z 118.950 Potomac DEP - SAM 0748 () - deps ADW.
1409Z 257.200 Potomac DEP - HOG or HAWG 1 () - mentions "we're two by two now..." deps ADW to 11000' heard them head over the area nice and loud!
Finally some U here!! :cool:
1440Z 118.950 Potomac DEP - REACH 4708 () - deps ADW to 11000'.
1505Z 378.100 SAM CP Andrews - REACH 5037 (C-130H 85-0037 357th AS AFRC) - departed ADW @ 1500Z.
1506Z 118.950 Potomac DEP - REACH 5037 (C-130H 85-0037 357th AS AFRC) - deps ADW to 13000' dir CSN join V140 QSY 118.675.
1544Z 118.950 Potomac DEP - NAVY AX 600 (C-130T VR-53 NAF Andrews) - deps NSF to 15000'.
1546Z 378.100 GRIFFIN CP Andrews - ????? ?? - C-21A 84-0117 10 mins. out in the local pattern.
1556Z 118.950 Potomac DEP - RIDER 04 (???) - deps ADW dir FLUKY to FL210 QSY ZDC-Montebello 284.7 and checks in there.
1606Z 118.950 Potomac DEP - PAT 386 () - deps DAA 600' for 7000' dir PALEO QSY 125.650.
1758Z 118.950 Potomac DEP - MARINE 474 (UC-35D 166474 MASD Andrews) - deps ADW to 17000' QSY 123.825.
1803Z 118.950 Potomac DEP - NAVY JS 536 (C-9B VR-46 NAS Atlanta) - deps ADW to 17000'.
1809Z 119.300 Potomac DEP - AIR FORCE TWO (C-32A 89th AW) - cleared for the localizer app @ ADW.
1927Z 118.950 Potomac DEP - ARMY 1778 (C-37B 04-1778 OSACOM/PAT Andrews) - deps ADW to 11000' QSY 121.050.
1941Z 118.950 Potomac DEP - BOXER 296 (201st AS DC ANG) - deps ADW to 17000' QSY 123.825.
2014Z 260.900 ZDC-HUNTRESS - BLACKJACK 1 (Customs fixed wing aircraft at DCA) - no joy on V checking in on U. No response from HUNTRESS.
2018Z 126.300 Davison AAF TWR - BLACKJACK 1 (Customs fixed wing aircraft at DCA) - now entering pattern at DAA. Then back on 260.900 again clg HUNTRESS @ 2019Z.
2040Z 118.950 Potomac DEP - JENA 622 (G5 N596GA) - deps DCA on course for HEF QSY 125.800.
2059Z 118.950 Potomac DEP - PAT 173 () - deps DAA to 12000' QSY 118.675.
