1317: MACE 91 with ZDC-Shenandoah checks in at FL 280...270.35 (F-16s but not sure yet from where - a couple of possible choices)
1318: MAD HOG 1 (A-10 Willow Grove) with ZDC-Hagerstown at 13,000 feet...227.125
1319: MAD HOG 1 handed off to ZNY-Middletown and again check in at 13,000 feet (seem to be headed toward home)...322.4
1320: MAD HOG and FLYER flight chatting on Ops freq...one mentions a flight of three heading toward R-4006 (at Pax)....141.8
1325: FLYER flight of three A-10s from Willow Grove checks into the Pax area...250.3
1326: FLYER 1 to Pax Advisory to report they are 3 A-10s at 6000 feet...270.8 (FLYER flight must be working low band FM for interflight...never heard them on VHF)
1329: WILD flight of 3 F-16s off the deck at Andrews...with TRACON climbing out...257.2
1330: WILD flight using interflight freq...139.15
1332: MAD HOG 1 flight to Philadelphia TRACON...passing 10 for 6000 feet, direct Willow Grove...273.575
1333: WILD reports bullseye is at 360 degrees, 153 miles (hmmm...W-107? ..or the Duke?)...139.15
Should've known it was the Duke MOA since they took off to the west indicated by the 257.2 TRACON freq and were headed due north to the bullseye.
1334: MAD HOG 1 flight to Phil. TRACON and down to 5000 feet...291.7
1334: BRAVE F-16 flight scramble from Andrews...with Potomac TRACON...348.725
1334: BRAVE 61/62 flight to HUNTRESS...139.7
1337: WILD flight with ZNY-Middletown...direct Slate Run...322.4 (Heading your way Dave to The Duke)
1339: BRAVE 61/62 into the Pax area and cleared in for simulated work...270.8
1342: FLYER reports to Pax they're rejoining...1 and 3 were doing PARs at Pax and 2 was just hanging around the area...270.8
1349: BRAVE 61/62 still down at Pax doing simulated intercepts..."BONDO simulation GCI"...they are also working with Potomac TRACON on this freq to request altitude blocks for the intercept as they would in a real life situation...139.7
1357: BRAVE 61/62 get a new intercept mission on an airliner...just shadow for now...139.7
1358: BRAVE confirms it's a United Airlines Boeing 767...they've followed it from 12,000 down to 5,000 feet (Apparently it's preparing to land at one of the local airports)...nice simulation...139.7
1404: BRAVE new mission -- going after a "stolen Leer Jet" and must count bodies in the cockpit....report just one body...139.7
1405: BRAVE 61 leaving Pax...270.8
1406: BRAVE 61 to Potomac TRACON...335.5
1407: BRAVE 61 to CAPITOL to report RTB...5 minutes out, Code 1...says he's coming home first...139.7 (BRAVE 62 will probably hang around for another 20 minutes as they often do on scrambles.)
1409: BRAVE 61 to Andrews Tower for landing...349.0
1409: BRAVE 62 to 3500 feet as reported to Pax...270.9
1410: BRAVE 61 reports..."base, gear, stop, right"...349.0
1411: BRAVE 62 to Potomac to report a couple of approaches at Patuxent and then RTB to Andrews...139.7
1423: WILD flight back in range on interflight freq after going to the Duke MOA...139.15
1434: BRAVE 62 with Potomac TRACON at Nottingham...335.5
1435: BRAVE 62 to Andrews Tower for landing...4 miles to the southeast...349.0
1438: BRAVE 62 cleared to runway 1R...349.0
1439: WILD flight to V-1 SOF...give mission resutls...33 miles to the north...all 3 are Code 1...139.9...Push v-6 and go back to interflight freq 139.15
1440: BRAVE 62 reports gear down....349.0
1441: WILD flight with Potomac TRACON...269.0
1442: WILD 1 reports flight at 4,000 feet and has field in sight...269.0 (WILD 2 clears off interflight freq to fetch the ATIS report)
1444: WILD 2 comes back to interflight with the ATIS...active runway 1L/R...139.15 Push U-4
1444: WILD 1 to Andrews Tower to report in as a flight of three for runway 1R...349.0
1448: WILD 1 reports gear down, right base, full stop, 1 right...2 does the same...3 joins the parade...349.0
1451: And here comes Langley,....interflight active...315.85
1453: KEVLAR 41 (Langley) calling Giant Killer...238.1
And after break, phone work, email answering, and adding to my MilAir reference book that I'm in the process of building...
Final notes of the afternoon...at 1602 there is a RATS 11 (four F-22A) flight from Langley with Norfolk TRACON 370.925 heading out to W-386. They then check in with Giant Killer on 238.1 and say they'll be MARSA with a BUGSY flight (also F-22A) for the next 30 minutes flying over the entire W-386 area. RATS is a new F-22A Langley callsign (but previously used for F-15s) and I'm adding it as "first noted" to the callsign list as of today. RATS is working 233.525 for interflight.
AT 1614, BUGSY 21 flight of three F-22As with Norfolk TRACON climbing to FL 230, then switching to '7' where they contact GK on 238.1 to enter W-386 for the next 40 minutes MARSA with RATS.
1632: There is a BATON 24 [female] talking to Baton Ops on 395.1 asking about BATON 20 and affirming that 20 is now airborne. (EC-130J from the 193rd SOW, PA-ANG Harrisburg)
1643: BUGSY 21, two ship RTBing to Langley via HEELS at 14,000 feet...238.1/249.8 (they left 23 behind in W-386)
1645: RATS flight 5 minutes from RTB...flight leader says they'll split into two flights - RATS 11 (with 12) and 13 (with 14)...238.1/249.8
1648: RATS splits the four ship flight in half and reports RTB...238.1/249.8
1650: BUGSY 23 reports RTB through HEELS...238.1
