1200: PITMAN 25 to Potomac TRACON telling them he needs to really do a wx check in the south nearer to Andrews because that's where the weather is deteriorating...254.25
1202: DRAGO 51 flight now with ZDC-Irons 360.85
1203: DRAGO 51 out of FL 220 for 190...360.85
1203: PITMAN 25 says he'd like to track south for about 20 miles and then climb back into the Guard Dog area...254.25
1204: PITMAN 25 handed to Potomac TRACON (BWI) 307.9 and repeats his above message...ground tells him to maintain 12,000 feet at 180 degrees heading.
1204: DRAGO 51 cleared down to 15,000 feet...360.85
1205: PITMAN 25 handed off to Potomac TRACON 348.725 and requests a vector
1207: DRAGO 51 handed off to Potomac TRACON (Reagan/Andrews) 335.5 where they check in and say the flyby time has been moved up to 1800(Z)...direct Nottingham at the current time....at 12,000 feet
1208: PITMAN 25 still being vectored around the area in the south of the CAP checking wx...348.725
1209: DRAGO 51 says he can expect a lower altitude in about 6 miles...335.5
1209: PITMAN 25 is done with his scouting mission and is sent back to his home freq...348.725
1210: PITMAN 25/26 back together on 139.7
1210: PITMAN 25 to Guard Dog heading back to the CAP...350.25
DRAGO 51 sounds like a "heavy" - not a fighter type.
1211: PITMAN 25 reports to HUNTRESS he's reestablished in the CAP...first on 350.25 and then..oops...139.7 where he gives the PIREP to HUNTRESS of his findings...including a report of icing between FL 190 and 230
1212: DRAGO 51 descending...now at 4000 and going to 3000...335.5
1213: PITMAN 26 tells 25 to go to V-8 and they turn up on 139.825 (not 138.825) where they chat about a problem 26 is having with her radar//gadget bent
This makes the third reference we've had to a V-8 for the 77th...143.8, 138.825 and now 139.925
1215: PITMAN 25 tells HUNTRESS that 26 has no radar capability...gadget bent...139.7
1217: DRAGO 51 reports established and holding...335.5
1219: PITMAN 26 says her radar is now working and she's heading for the tanker...139.7
1219: PITMAN 26 to Potomac to say she's ready to go to the tanker...350.25
1220: PITMAN 26 reports weapons safe...and confirms altimeter set at (standard) 2992...139.7
1221: PITMAN 26 toTANKER 03 to say she's about 4 miles away...he says he's only doing about 290 (speed) now...139.7
1221: DRAGO 51 calls DRAGO 02 (ground control at Arlington)...no joy...279.575 (the standard flyby freq)
1222: PITMAN 26 tells the tanker she's 3000 feet behind him...her speed 310...tanker is now at 300...139.7
She's calm, cool and collected throughout the earlier freq confusion and through her radar problem and for the refueling. Sounds like a pro. She's been the #2 for a couple of CAP mission flights and had the lead for one of them. She's good.
1224: PITMAN 26 nose cold...ready for contact...139.7
1225: TANKER 03 tells PITMAN 26 he's going on the comm radio...too much static on the boom intercom (which is why I'm hearing him). She confirms...he clears her to come toward the boom...and gives her minor position changes along the way...139.7
1227: DRAGO 51 back on 335.5
1228: TANKER 03 clears PITMAN 26 to contact the boom...then reports contact...139.7
1230: PITMAN 26 off the boom and re-established in the CAP...TANKER 03 asks her if she got enough...she did...139.7
DRAGO 51 seems to just be flying a pattern around the Nottingham area and holding because of the changed flyby time at Arlington...don't know what was originally scheduled but it's now at 1300 local.
1232: PITMAN 25 asks HUNTRESS to call DNS XXX-XXXX where he'll get their "Top 3" and give them the PIREP including the icing...he also wants HUNTRESS to pass the Victor and Uniform frequencies to them...wants it on the secure line since he doesn't want the frequencies in the clear
))...139.7
1235: DRAGO 51 checking in with Potomac TRACON on a different transmitter to make sure it works. (it's not nearly as good as what he was using)...335.5
1236: DRAGO 51 calling Andrews on 378.1...asks if they're DSN phone patch capable
1236: There's also a DC 51 tanker calling LIBERATOR at the same time on 378.1
1237: DRAGO 51 wants Andrews to call a DSN XXX-XXXX and check the TOT (time over target) to see if the time has changed from 1300 to 1352...378.1
1239: DRAGO 52 calling DRAGO 01 on primary...279.575 (so we know it's at least a flight of two aircraft...this guy sounds like a heavy also)
1241: DRAGO 51 back with TRACON on 335.5...still trying to find out what they're supposed to be doing...guess they'll just circle around Nottingham at low altitude (3000 feet) until they find out the real TOT. By all accounts, the wx in the ADW area is pretty bad.
1242: DRAGO 51 asking Andrews CP if there's any word on that message...378.1
1242: DRAGO 51 calling DRAGO 01 and then DRAGO 02...279.575 (no joy to a couple of calls)
1246: PITMAN fuel remainders...25 has 7600, 26 has 11300 pounds...139.7
1250: TANKER 03 asks PITMAN 25 if he's coming for gas...25 says in about 10 minutes...they agree on 370 for an air speed and 03 says he'll push it up...139.7
1251: DRAGO 51 gets his TOT from DRAGO 02 as 1352...279.575
1251: DRAGO 51 says they had bad intel and the time is 1352, not 1300...335.5
In spite of all these plans for the DRAGO 51/52 flight, I'm not sure there's a proper ceiling for their flyby which they normally do at 1000 feet over Arlington. Cloud deck is pretty low - at least in my area. It's much too warm but it sure feels like snow out there.
1255: PITMAN 25 has fuel remainder of 6900 pounds with outboard tanks dry and 26 has 10500 with tanks feeding (she first said "dry" and then corrected herself)...139.7
1255: PITMAN 25 and TANKER 03 ready for the AR op...139.7
1259: PITMAN 25 finishes refueling and reports back in the CAP (they must have been on boom intercom since no words were passed on the radio)....PITMAN 25 and TANKER 03 coordinating the next refueling up at FL 270 so they can do the AR at a speed of 310...TANKER 03 tells 25 to just tell him what to do and they'll do it (a laid back boomer)...139.7
1301: PITMAN 26 asks 25 to go to V-8 and then go to 139.825 to talk about speeds, the wx and what they'll do for the next AR...at FL 270.
1302: PITMAN 25 tells TANKER 03 they'll do the refueling at FL 270 and 310 indicated air speed for the AR...139.7
1306: DRAGO 51 calling DRAGO 02...279.575...no joy
This guy has suddenly changed from the normal DRAY-go to DRAG-oh pronunciation.
1314: DRAGO 51 calling DRAGO 02 again on 279.575 and again no joy.
This was another voice aboard 51 and he's back to DRAY-go.
1316: DRAGO 51 to DRAGO 02 and makes contact this time to say they're established in the orbit at 3000 feet...279.575
1321: DRAGO 51 to Potomac TRACON to say their TOT is 1352 and will be heading out about 10 minutes after that around 1900Z...335.5
1323: DEVIL 11 flight (F-16 NJ-ANG) with Giant Killer to enter W-107 at 7000 feet...255.0
I'm pretty much stuck on the two DRAGO freqs and the four CAP freqs and am not using my other radios for search so don't really know what else is out there flying this afternoon. Feeling lazy.
1325: PITMAN 25 has 10300 pounds of fuel with tanks feeding and 26 has 8100 with tanks feeding...139.7
ref below: Jeff, I've never heard a CAP pilot as confused as PITMAN 25 was...he was just a wreck for a bit.
NOTE: It appears to me the 77th FS at Shaw has decided on a frequency plan for their radios that has the CAP interflight freq placed in position V-8 no matter which freq is selected for mission interflight chat. That's the only thing that makes sense considering we've had three different freqs for V-8 referenced by them. On the way to the CAP they were using 138.825 and then once in the CAP it became 139.825.
1325: Break time...want to be back before DRAGO 51 does its flyby.
