0917: CADE 1 (A-10 PA-ANG Willow Grove), flight of two chatting on interflight...142.25
0919: CADE 1 flight with Philadelphia TRACON...319.15
0920: CADE 1 handed off to Phil. TRACON...269.25
0925: CADE 1 flight handed off to 257.85 which is not a good freq...think the controller meant 257.875...anyway, CADE 1 comes back to 269.25 to say no one answers him on 257.85 and so they're handed off to 323.0, which is another Dover App/Dep freq, where they check in and explain the problem.
0930: CADE 1 flight is talking about the wrecked C-5 off the end of the runway at Dover. One is amazed it's still there....they mention just the mid-section of the fuselage is left...142.25
0932: The CADE pilots are talking about what they'll do at the range - which targets to attack and how (Warren Grove Range I suppose)...142.25
0934: RHODY 34 (C-130 RI-ANG Quonset State Airport) chatting on the RHODY Ops freq of the RI-ANG...talking about fighting an ice problem...says he has to go down and up...worst ice he's seen in awhile...says he's fighting to maintain 145 knots...383.3
0938: RHODY 34 says he's over Langley at this time and has icing at every flight level he's tried...383.3
0943: The two CADE pilots are still chatting on interflight freq but I haven't heard them check onto the range if they've done that...142.25
1005: Couple of chatters on tanker interflight freq...mention something about Elkins but believe that's only a waypoint, not the IP...143.825
1005: CADE 1 flight still on interflight chatting but haven't heard them anywhere else recently...142.25
1020: The aircraft on the tanker interflight freq are talking about adjusting speeds...one says he can't go any slower than about 268...says he's too heavy today...143.825
1025: CADE 1 flight announces RTB...354.8
(Thanks for the freq Jeff...I flat out missed them entering Pax)
1026: CADE 1 handed off to Patuxent App/Dep...leaving 7000 for 5000 feet...direct Smyrna...314.0
1029: CADE 1 flight handed off to Dover Approach...257.875 (Kind of unusual to go straight from Pax to Dover without a stop on a ZDC freq along the way)
1032: The CADEs are talking about a potential problem...maybe...and one of them is going to practice a single engine landing procedure in case he ever needs it...and they're talking about the possible problems with a single engine landing - reading off the procedures...142.25
1035: CADEs are 10 miles from Dover...flight plan takes them from there to over New Castle, to Philadelphia International and then home...142.25 (Problem is a right engine hot light)
1036: CADE 1 flight handed off to Philadelphia TRACON...where they check in at 5000 feet and say they're looking for a straight in, full stop landing...269.25
1038: CADE 2 to SOF on Ops freq...CADE 1 is Code 3 for right engine hot light and Code 2 for OFP...CADE 2 is Code 2 for MFCD...he explains the problem aboard CADE 1 to the SOF...says they are not declaring IFE at this time...343.0
1040: CADE 1 flight handed off to U-6 (previously confirmed preset), PHiladelphia TRACON where they check in at 5000 feet...319.15
1041: CADE 1 talking about the procedures he needs for the single engine landing...also says he has a fuel imbalance of about 700 pounds between left and right tanks...says the fuel problem began at about RTB time from Pax...142.25
1042: CADE 1 requests lower altitude due to weather...cleared to 3000 from current 5000...319.15
1042: CADE 1 asks CADE 2 if the SOF had any questions...2 explains that he simply described the problem and that it's not serious at this time....142.25
1045: CADE 1 says the right tank has more fuel...(and that's the side with the potential problem and the engine he's going to shut down for landing)...142.25
1045: CADE flight handed off to U-5 (Previously confirmed preset) Philadelphia TRACON and check in at 3000 feet...291.7
1048: Very weak transmissions on the Willow Grove Tower freq but not copiable if this is the CADE flight...340.2
That transmission at 1045 was the last I heard from the CADE flight. I assume they both landed safely. I don't hear the crash trucks rolling out. (IKOC)
1103: RHODY 31 calling RHODY 32 on Ops freq...383.3
Twice in one day for that freq is a new record - and with different aircraft.
1119: Couple of aircraft chatting on 293.7 which I've had used in the past as a STEEL (KC-135 Pittsburgh) interplane freq.
1121: RHODY 31 back on Ops...383.3
1123: The pair chatting on 293.7 talking about speeds...one calls the other "Hawk" but I'm not sure if that was a nickname or a callsign....at altitudes 190 and 200...and these are fighters...it's a flight of 5 aircraft.
1127: HAWK appears to be a flight of five fighter aircraft...there is also a STEEL tanker talking to them...293.7
The HAWK callsign is used by many, many units with many different airframes so impossible to ID them with the info gleaned so far
1130: HAWKs talking about going down to the 15-16000 block to see how conditions are down there...293.7
Don't have these aircraft on any other freq - neither interflight nor ATC but they just got that altitude change from an ATC freq somewhere.
1131: HAWKs talking about asking for the Savannah weather...293.7
1132: STEEL tells HAWKs to squawk 7300 per Center request...HAWK flight leader says they're right on STEEL's wing...293.
1136: FAME 19 (Prob C-21, Keesler AFB MS) calling SHARK Ops on 385.5 but he's probably on the wrong freq...this one is for Atlantic City Approach....Shark Ops of the CT-ANG Bradley should be 349.7
1136: HAWK flight adjusting altitudes and speeds...sounds like they're getting ready for the AR op...293.7
1138: Someone - probably one of the HAWKs - asking for Savannah weather but he's being blocked by noise on the Metro freq...239.8
1143: One of the HAWKs asking the STEEL tanker to pull his speed back to 230..."No problem," says the STEEL....293.7 (STEEL has not used his suffix since I've been listening on this freq)
1154: One of the HAWKs comes back to the freq to report the wx for a couple of locations...one is Cherry Point and the other was blocked...293.7
And I still haven't heard any of them on an ATC freq up to this point. VHF perhaps?
1203: HAWK flight leader asks STEEL to slow down...says they're ready now for the refueling op...293.7
I had assumed they had already refueled after all this time flying together...guess not.
1203: STEEL reports he's slowing down to 220 now for the refueling...and he's talking to Norfolk TRACON...says they'll only be in his airspace for a little bit and then will move on...says they're going to Savannah...370.925 (And I didn't get on the freq in time to hear STEEL's suffix)
Since the fighters are all in a group with the STEEL tanker, I'm guessing STEEL is doing the ATC reporting for all of them. He'd be doing that on VHF which is why I'm not hearing the fighters on the UHF ATC freqs. I don't regularly monitor VHF Center freqs.
1208: First HAWK going to the boom...wants topoff, about 10,000 pounds...293.7
And since these fighters are using the boom method of refueling, we can rule out the four Navy units listed under the HAWK callsign in the database. We can also rule out the C-21 unit that uses that callsign. Also knock off the B-1 and F-117 units and that leaves us with a couple of F-16 units. One is from Shaw and one from Spandahlem Germany. Unlikely to be Shaw.
1213: Another HAWK going to the boom...293.7
A little chat about a minute later and then they fade from my listening range...just too far south now as they should be about 10 minutes flying time south of Norfolk at a fairly low altitude of 15-16000 feet.
1220: Warren Grove Range active...haven't heard any callsigns yet...283.1
1224: U/I A-10s with ZNY-Kennedy 282.3 which are probably the guys at Warren Grove Range.
1227: And those U/I A-10s are using 139.9 for an interflight chat freq which should put the MA-ANG Barnes tag on them.
1250: And it has been dead for about 1/2 hour now so it's break time. Continued below if necessary.
Ref message #1034 below:
Tony said:
Hi guys,
Thought this might be of interest.
The following ex-VA ANG F-16Cs have come to the 121st FS DC ANG recently:
86-0230/DC 121st FS ex VA/149th FS 5C-336 06dec06
86-0232/DC 121st FS ex VA/149th FS 5C-338 nov06
86-0243/DC 121st FS ex VA/149th FS 5C-349 nov06
Very interesting Tony. Thanks. Wish we knew why...we could speculate all day and not know the real reason.
