TinEar
Just to confirm the CAP is still active in the 1200 hour. Freqs are as freqhopping outlined them...
Primary...139.7
Boom......228.9
Potomac Approach....135.525/350.25
Players are PITMAN 43/44 from the 77th FS at Shaw AFB and the refueler is TANKER 01, a KC-135 from the 77th ARS at Seymour Johnson AFB.
1218: A DEVIL flight of two F-16s from the NJ-ANG Atlantic city is just wrapping up their work at Patuxent. Using 138.875 for interflight, leaving Pax on 270.8
1219: DEVIL flight to ZDC-Cape Charles 256.8 and then ZDC-Casino 285.4. They're at 11,500 feet and descending for an approach to Atlantic City.
1224: DEVIL flight to Atlantic City Approach...requesting initial to runway 31...cleared to 2500 feet...327.125
DEVIL 13 is the one doing all the talking but he has identified as a flight of just two F-16s. This must have started as a 3-ship flight with one of them returning early.
1238: On boom freq 228.9, HUNTRESS tells TANKER 01 to come up on 139.7. TANKER 01 responds that he'll drop 350.25 and monitor 139.7. HUNTRESS doesn't like that and tells him a couple of times that 350.25 is for Potomac...it appears he doesn't realize TANKER 01 is monitoring 135.525 instead of 350.25. TANKER 01 explains the he has three radios - one on boom freq, and the other two on 135.525/350.25. Bottom line is that TANKER 01 goes to 139.7 as instructed. There 01 explains about monitoring Potomac on 135.525. Prior to all this, both HUNTRESS and the PITMAN pair were trying to contact TANKER 01 on 139.7 and couldn't establish contact with him.
I hear HUNTRESS loud and clear when he came up on the 228.9 freq but not on the others.
1243: TANKER 02 coming into the area...reports that he's on time for Guard Dog...cleared in at FL 240...135.525
PITMAN 43/44 are using 350.25 as an interflight freq rather than switching their VHF radio away from 139.7
1245: TANKER 01 relieved by HUNTRESS on 139.7 and switches to 135.525 for clearance out of the area...female driver explains to Potomac they want to stay at FL 250 because the fighters are at 230 and the new tanker is at 240. She's cleared to DCA then Nottingham and then flight plan route but didn't state her home plate.
1248: TANKER 02 checks onto the HUNTRESS primary freq...139.7
1251: TANKER 01 handed off to ZDC-Brooke 126.875 where it's a male voice checking in this time and he's cleared to a flight plan route taking him home to Seymour Johnson AFB (GSB).
1254: TANKER 01 handed off to ZDC-Calvert 133.9 where he checks in at FL 250.
1256: NAVY SD 536 (SALTY DOG VX-23 Patuxent NAS MD) with ZDC-Irons 360.85 where he reports altitude 17,500 VFR.
1300: NAVY the SD 536 handed off to ZDC-Calvert 281.4 where he checks in at flight level 17,500.
1301: NAVY SD 536 reports descending...281.4
1301: TANKER 01 handed off again by ZDC-Calvert and here's where I drop him since we know he's going to Seymour Johnson.
1308: PITMAN 43/44 are given a TOI by HUNTRESS....43 reports he has radar contact with the TOI...139.7
1310: PITMAN 43 reports he's tally on the TOI...it's white on brown...139.7
High noise level again today on VHF prevents me from opening squelch to hear the HUNTRESS transmissions.
1311: PITMAN 43 repeats his mission is to headbutt the target...139.7
1312: PITMAN 43 reports he's going after the TOI, 44 will remain in Guard Dog area...139.7
1312: PITMAN 43 to Potomac on 350.25 to get permission to leave Guard Dog to descend down to 3000 feet to headbutt the TOI
1312: 43 tells 44 to get some distance and keep radar contact on the target...139.7...43 reports to HUNTRESS that he's told to change freq to 135.52(5)...all approved so over 43/44 go to 135.525 and check in there...or try to...takes 3 tries to establish contact and then he requests clearance down to 2000 feet.
1315: 43 reports he's tally target...course 270..off his nose for 3.5 miles...135.525
1315: 43 tells 44 to confirm from HUNTRESS that he's to headbutt the target north...350.25
1316: Takes 44 four tries to make contact with HUNTRESS on 139.7 to confirm the northern headbutt...139.7
1316: PITMAN 44 tells HUNTRESS the target is landing at a small airport...139.7
1316: 43 IDs TOI as a 2 engine, low wing, white...landing...44 relays to 43 to let him land...350.25
1317: PITMAN 43 reports TOI landed...350.25....44 report to HUNTRESS the TOI has landed...139.7
1318: PITMAN 43 tells Potomac he's orbitting in current position at 4500 feet...135.525
This comm relay system could be better...43 is working 135.525 with Potomac, 43/44 working together for comms on 350.25...and then 44 has to switch to 139.7 to relay to HUNTRESS. It's working though which I suppose is the bottom line.
1320: Fuel checks...43 has 7600 pounds with wing tanks feeding, 44 has 8100 pounds and feeding...350.25
They never mentioned the airport the TOI was landing at that I could hear but I know it was in the southern portion of the CAP track. (Gaithersburg maybe?)
1321: PITMAN 43 requesting clearance back into Guard Dog and freq change...135.525...he changes back to HUNTRESS on 139.7 and the excitement is over. If BLACKJACK came up for the intercept I never heard him.
1330: Freq changes...PITMAN fighters are to monitor Potomac 135.525 and HUNTRESS on 260.9...they're dropping 139.7 for now.
I would be willing to bet the freq change is a result of the extremely high noise level on VHF today. The several attempts it took PITMAN 44 to contact HUNTRESS during the intercept on 139.7 was probably the deciding factor.
1331: TANKER 02 is given the same freqs to monitor...02 is confused and wants freqs clarified...139.7
1331: PITMAN 43/44 check in with HUNTRESS on 260.9
1331: PITMAN 43/44 check in with Potomac on 135.525
1332: TANKER 02 finally has the correct freqs sink in after a couple of repeats...139.7
1333: TANKER 02 checks in with HUNTRESS on 260.9 and is told boom freq will be 228.9
1351: PITMAN 43 heading for the tanker...reports weapons safe...he's tally TANKER 02...pushing boom freq...260.9
1353: PITMAN 43/TANKER 02 make contact on boom freq...02 tells 43 he's pushing up his speed to about 310 (knots)...228.9
1355: TANKER 02 reminds 43 his nose should be cold, 43 affirms...43 gives tail number as 96-085...43 is cleared for pre-contact...228.9
1359: 43 makes contact with the boom...takes on his fuel, disconnects and breaks left...228.9
1400: PITMAN 43 checks back to HUNTRESS on 260.9
1400: 43 reports fuel as 12,100 pounds and feeding...44 reports 5800 and dry...43 sends 44 to the tanker...44 reports weapons safe and says he's changing to the boom freq...260.9
1402: 44 makes contact with 02 on boom and says he's 4 miles in trail...228.9
1402: PITMAN 43 given another TOI by HUNTRESS....at 166 degrees, 5 miles...260.9
1402: PITMAN 43 reports tally with the TOI...now 340 degrees, 15 miles at 6000 feet.
1402: A-10s from MTN airborne...report off the deck on the hour...callsign RAVEN...142.3
1404: PITMAN 44 gives tail number to tanker as 93-540...228.9
1404: PITMAN 43 has the BRA on the TOI as 204/11/1000...260.9
1404: TANKER 02 clears PITMAN 44 to contact the boom...228.9
1406: PITMAN 43 reports no joy on the TOI...is told to "skip it" by HUNTRESS...260.9
No chat on the radio by 43 during refueling earlier or by 44 now so I assume they're using the boom intercom.
1409: TANKER 02 reports disconnect of the boom from PITMAN 44...44 reports breaking off low to the right...228.9
1410: PITMAN 44 reports back in the CAP...260.9
1410: RAVEN flight reports to Patuxent as a three ship...281.8
From there, the RAVENs "Push 13" but that one is not recovered and I can't find them...yet.
Found someone on ZDC-Calvert 281.4 that might be them...at 7000 feet. If this is U-13 it would fit within the rest of their presets since U-12 is another ZDC freq.
1419: Yup...it's the RAVENs...now back to Pax on 281.8
Adding U-13 as ZDC-Calvert 281.4 to my preset list for the MD-ANG.
1427: MUSSEL 04 requesting TACAN to runway 1R at Andrews...119.3
1430: All is quiet...PITMAN 43/44 just refueled, TANKER 02 is fairly new on station and isn't going anywhere...the RAVENs are somewhere in the Pax area but are working at very low altitude and can't be heard. Be back later as the new PITMAN pair comes on station. PITMAN 43/44 are obviously doing more than the normal 4-hour shift since they came on station at around 1000. They must be taking a 5-hour shift so two 4-hour shifts will remain before closing at 2300 tonight.
Ref below: Thanks Ben. That was my guess but it's good to have it confirmed. I would think the pilot is presenting all kinds of ID about now and will have a long afternoon.
And you can say your squelch setting any old way you want...we know what you mean - it's a very noisy day.
Primary...139.7
Boom......228.9
