1945: WILD flight of four F-16s off the deck at Andrews...with TRACON 348.725 and on interflight 143.6...to TRACON (BWI) 317.425 at 1949...then to ZDC-Swann 360.7 at 1951 at 14,000 feeet, six miles front to back...cleared to climb to FL 210.
1952: WILD asks for the block 15-16000 due to weather...they get it...360.7
1954: WILD flight handed to ZDC-Kenton 354.15 and check in in the block 15-16000...currently six miles front to back...closing to non-standard at two (miles front to back)
1957: WILD flight handed to ZDC-Cape Charles 256.8 and check in with same message....now in 2 mile non-standard formation.
2002: WILD asks ZDC if they can get down to about 13,000 for weather...they're given the block 11-13000...256.8
2003: WILD flight handed off to Giant Killer and call GK on 238.1...x2, no joy.
2005: No joy on 238.1 so they switch to 249.8 and make contact there. They check in to work W-386 A-F. They'll work 312.3 and switch there at 2005.
2014: The WILD flight isn't doing much talking...some chat on 143.6 and almost nothing on 312.3. I didn't hear them mention tanking during this flight but I'm searching all my known AR freqs just in case.
2019: BATON 52 (EC-130J, 193rd SOW, PA-ANG Harrisburg) with Giant Killer in W-107 giving his routing home to KMDT...direct Sea Isle, DuPont, Lancaster, field...255.0
2021: REACH 480 (C17A, 00-0174, 62nd Airlift Wing, McChord AFB WA) with TRACON but didn't catch if it was 118.95 or 119.85 (going from or coming to ADW)
2027: The WILD flight is doing some red/blue air ACM work...WILD 1 and 2 are on 143.6 and 3 and 4 are on 312.3
2029: ARMY 1778 (C37B, 04-1778) landing at Andrews...125.35
2030: Guard Copter 16251 calls Leesburg Radio on FSS about flying from 3W3 to Davison AAF...Leesburg tells him he doesn't have a flight plan on file for him so the copter says he'll land and file it...255.4
3W3 is Kentmorr Airpark in Stevensville MD
2034: DC 32 Heavy (KC135R, 61-0307, 756th ARS Andrews) with ADW Tower...reports gear down and locked heading for runway 19R...125.35
2038: A couple of the WILD F-16s are now using interflight 139.15 (not sure which two are there)
2039: CRAB 55 (C130J, 98-1355, 135th Airlift Squadron, MD-ANG Warfield ANGB) to Crab Ops to announce he's about to make a drop...not just any drop...a REAL drop...385.9
2041: CRAB 55 reports 3 minutes to drop...385.9
2041: DC 32 didn't make a full stop landing...he's going around in the pattern...now with Approach...119.3
2046: AR-636 active...someone descending from FL 270 to 210...238.9
2047: BLACKJACKs working with ADW Tower...125.35
2047: BLACKJACK [female] also working 139.7
2048: ARMY 01052 (UC35A, 00-1052) landing at Andrews...125.35
2050: The AR-636 work is between a MOVER (KC10A McGuire) and a STEEL 61 (KC135R PA-ANG Pittsburgh)...238.9
2050: All four WILD fighters are back together on interflight freq...143.6
2058: WILD flight on the way home...143.6
2059: WILD flight to TRACON...on the way to Andrews...8 miles front to back formation...wants to split the flight into two two ship flights...WILD 3/4 8 miles in trail...270.275
2100: WILD was just on 139.7...not sure why just yet...sounded like he was giving his in-flight report there instead of on 139.9
2101: CRAB 51 (C130J, 97-1351, MD-ANG) also with Crab Ops...reports 14,000 pounds of fuel remain...385.9
2103: BLACKJACK 1 and 2 are doing practice intercepts on each other...139.7
2106: WILD 1 and 2 handed to ADW Tower for landing...349.0
2108: BLACKJACK 1 doesn't want to do any more of this training...he wants to go to Davison AAF and do some NVG training approaches...BLACKJACK 2 tells him Davison isn't open...he doesn't care, he's going...139.7
2109: WILD 3 and 4 over to ADW Tower for landing...349.0
2111: CRAB C-130Js working with drop controller...148.925
2112: DC 32 coming home in A-3 condition...recites some of the problems with the aircraft...says crew chiefs were aware of them before they took off. ..378.1
2112: BLACKJACK 1 with ADW Tower getting clearance for his self-assigned training (he's got a loud squeal in his transmitter)...125.35
If you see 118.4 anywhere above for ADW Tower instead of 125.35, it was out of habit...I think I found them all and changed them.
2115: BLACKJACK 1 and 2 tell ADW Tower they're going to discontinue their training due to traffic in the area and will join Route 3...tower tells them the aircraft landing right now are the last of the traffic tonight...125.35
DC 32 is coming in for a landing and there might be a REACH 3115 in there too that I missed on 378.1 when he gave his arrival message.
2121: DC 32 reports gear down and locked...125.35
2122: OPEC 38 (KC10A McGuire) to McGuire CP with arrival msg....319.4
2123: BATON 52 reports RTB to KMDT (Harrisburg) to Giant Killer...255.0
2126: JOSA 963, home station C21A gives arrival message to Griffin Command (missed callsign)...25 minutes out, mission complete upon landing...378.1
2128: DC 32 reports full stop landing (at last) to ADW Tower...125.35
2131: BLACKJACK 1 and 2 are back to doing practice intercepts...currently at 2800 and 3000 feet for this run...139.7
2132: Guard Copter 627 calls Weide Ops and says ops normal at APG...229.4
2140: REACH 506 with arrival message to Andrews...30 minutes out, A-1, 17200 pounds of cargo (fades)...378.1
2146: JOSA 963 (C21A, 84-0129, 457th AS Andrews) ready to land at ADW...125.35
2150: CRAB 55 gives arrival message to Crab Ops...10 minutes out, A-1, 18400 on the fuel...385.0
2151: BATON 52 [female] to Baton Ops with arrival message...395.1
2151: Civil Air Patrol flight 18G talking to ADW Approach about chasing down an ELT signal that's 4 miles west of Andrews...119.3
2154: CAP flight reports ELT now at a fixed position 3 miles west of Andrews...125.35
2154: REACH 475 (C17A, 89-1192, 437th Airlift Wing Charleston AFB SC) reports airborne at this time...378.1
2158: CAP flight 18Golf requests right turn near Andrews to search for the ELT...125.35
2205: CAP flight 18G is now very, very low near Andrews and difficult to hear...I think he just reported the ELT is coming from a helicopter on the ground...125.35
2208: REACH 506 (C5B, 83-1285, 436th AW Dover AFB DE) landing Andrews...125.35
2211: CAP Flight 18G still talking about the ELT to Andrews Tower but he's just too weak to pull the context out of the noise...125.35
2219: CAP Flight 18G says he's narrowed the ELT down on 243.0 mHz to the western half of ?Hyde/High? Field...now he's going to try to narrow it down to the western quarter...125.35
2225: MOVER 35 (KC10A McGuire AFB NJ) with arrival message to McGuire CP...A-1, no pax or cargo, 61,000 on the gas...319.4
2230: CAP Flight 18G talking to PG2 copter and tells him he believes the ELT is very close to the field...125.35
2232: COBRA 30 (VAQ-209 Andrews) reports 15 minutes out on squadron freq...280.2
2237: COBRA 30 with ADW Approach...119.3
2238: COBRA 30 with Andrews Tower for landing...349.0
2247: ARMY 301 landing Andrews...125.35
2248: STEEL (couldn't hear suffix) KC135R with arrival message to Steel Control...20 minutes out, A-2, 22K on the gas...311.0
2255: Guess CAP Flight 18G is done...he reports to ADW Approach that he's 5 miles northeast of Andrews at 1500 feet and will land at Freeway Airport...119.3
2314: NAVY 101 with TRACON...119.85
2316: NAVY 101 (C37B, 166376, VR-1 Andrews) to Andrews Tower for full stop landing...on the ILS to runway 19L...125.35
trainman111/Nick said:
And now for a general question...
How do you guys find the tail number and homebase of REACH a/c based solely on their callsign??
You slowly but surely build a database of as many C5 and C17 type aircraft as you can. Get their tail number when they give it, cross check it at the Scramble website to get the unit and go on to the next one. REACH aircraft with four-digit suffixes are built from the last digit of the year and the last three number of the serial. So, a C17A with tail 06-6156 would become REACH 6156 and 93-0603 becomes REACH 3603. When you hear REACH 3603 you figure the year is probably 93 or 03 so check it against the database you've built and find the whole tail number. Back to Scramble and check his home base. REACH aircraft with 3-digit numbers are almost impossible to firmly ID unless you've picked up some info from his flight - either a tail number or chat about home or something that tips you to his ID.
Or....you call your buddy in the tower and ask him.
