TinEar said:
AXEMAN flight of A-10s reporting airborne at 2001 to Raven Ops on 347.2
AXEMAN flight working interflight freq 142.3 and with ZNY-Lancaster 239.05 climbing from 11,000 to 14,000 (might be going north to the Duke MOA.
AXEMAN 1 cleared direct Slate Run at 2008 (confirming they're heading to "The Duke")
AXEMAN flight handed off to ZNY-Middletown 322.4 at 2014 and check in there....then a handoff to ZBY-Williamsport 338.3 at 2016 and check in at 16,000 feet non-standard formation.
Good Evening All and thanks for the hand off Tin...
2026: Axeman 1 switches Tacan to 29Y, does not pick up the tanker. (142.30)
2028: Axeman flight switch to 353.85 (338.30)
2029: Axeman flight checks in with Clevland Center (353.85) and is at 16,000.
2030: Axeman 1 asks ZOB if OPEC 29 (KC-10 McGuire AFB) is in the Duke. (353.85)
2030: Axeman 1 has Axeman 2 go onto 29Y on Tacan to see if he can get a fix on the tanker. Axeman 2 does not have contact (142.30).
2031: Axeman 1 gets freq of 303.0 from Cleveland Center (353.85) to contact OPEC 29.
2032: Axeman flight contacts OPEC 29 (303.0). Opec confirms they are on 92Y for Tacan.
2033: Axeman 1 has contact with tanker on Tacan (142.30)
2034: OPEC and Axeman Flight work their join up (303.0)
2037: OPEC 29 radio check with Axeman Flight (303.0). Female boom operator.
2038: Axeman 1 in to refuel. He does not have much luck in joining up and 2043 clears the boom to have Axeman 2 come in to try. (303.0 and 142.30)
2045: Axeman 2 is stabilized and is cleared to the boom. He is just creeping up to the boom, Axeman 1 gives him his distance to the boom. (142.30)
2049: Axeman 2 comes off the boom, he got about 1,000 Lbs. He will try again (303.0)
2051: Axeman 2 disconnects again. (142.30 and 303.0)
2051: Axeman 1 will come back to the boom. Relays to OPEC 29 that they will be going to R-5802 (Bollen Range) after their work (303.0).
2052: Axeman 1 back in and disconnects after a few minutes. (303.0)
2055: Axeman 1 reports they will drop to 16,000 and head out (303.0), they thank each other for the work.
2056: Axeman flight pushes 353.85 and reports in to Cleveland Center. They will be spending about 30 minutes a R-5802 and then will be headed direct to MTN.
2059: Axeman flight switches to 140.00.
2100: Axeman flight checks in with NY Center (338.30).
2101: Axeman 1 confirms he is on 30Y and Axeman 2 confirms 93Y for air to air TACAN.
2106: Axeman 2 switches to 237.20 (Bollen Range Control - Balky). Reports they are 10 minutes out and gets a weather update.
2107: Axeman 2 reports weather to Axeman 1, they are about to head into the range where I will lose them. (140.0)
So that wraps it up from the Duke. A different mix of aircraft than the norm, a nice change of pace. A little difficulty refuelling, but good work by all players.
Dave
