Sticky Thread For MilAir IV
jsoergel
Cincinnati/Dayton, OH
I'd bet if we had an SBS user in the Moscow area, we'd hear REACH 960 landing at Moscow-Vnukovo in a few hours.
Give it a couple days and you'll probably see it on Airliners.net...the spotters over there are pretty consistent.
Going over my recordings from Friday morning, I have N200XT departing KMGY for MYAX...tells the controller it's a Phenom 100, serial [50000]029, just built a month ago. Spent a day there and returned today after a stop at KFPR. What a slick jet that thing is - I'm hoping to drive over to the airport and catch it sometime.
jetcrafter
Southern Maine
Maine evening logs July 5th
0022z 311.000 ETHYL LIMA 1 wkg Maineiac OPs, boom's in the green.
0023z 341.750 ETHYL LIMA 1& 2 A-A
0023z 311.000 ETHYL LIMA 2 wkg Maineiac OPs, boom's in the green.
0026z 341.750 ETHYL LIMA 1 & 2 and JADE 44 coordinating their rendezvous in AR-20NE.
0035z 123.900 JADE 44 wkg Moncton Center, MARSA with ETHYL flight block 25-27 AR-20NE.
0042z 128.750 REACH 281 wkg ZBW.
0054z 128.750 OMAHA 41 wkg ZBW.
0058z 125.050 ETHYL 71 climb out of Pease switching to ZBW on 128.200
0104z 133.450 REACH 960 check in w/ZBW.
0105z 341.750 ETHYL 71 and REACH 960 coordinating their AR.
0107z 349.700 ETHYL 71 and REACH 960 switching to AR-20 Secondary as ETHYL/JADE flight is on Primary.
0116z 133.450 ETHYL 71 wkg ZBW, MARSA w/ REACH 960 block 19-21 AR-20NE.
0118z 128.200 ETHYL 14 descending back to Pease with ZBW.
0124z 133.450 AF1 check in w/ZBW.
0124z 321.000 ETHYL 14 wkg PACK Control, 15 out, 28k onboard, four write-ups.
0128z 133.450 REACH 281 check in w/ZBW.
0129z 133.450 SAM 91 check in w/ZBW FL310.
0135z 136.725 AF1 and SAM 91 A-A talking about conditions - smooth!
0137z 128.325 CANFORCE 225 wkg ZBW direct DOVEY.
0143z 341.750 ETHYL 70 and REACH 276 in AR-20.
0149z 134.950 CANFORCE 225 check in w/ZBW.
0150z 128.750 REACH 281 check in w/ZBW FL340.
0159z 133.450 CANFORCE 3253 wkg ZBW direct DOVEY.
0202z 123.900 ETHYL 70 wkg Moncton Center with end AR requests.
0205z 124.525 REACH 281 check in w/ZBW.
adrian65
Marthas Vineyard, Ma
FYI, ETHYL 71 recently took off from Pease and is now meeting up with REACH 960 in AR-20NE
using the secondary freq of 349.700 JADE 44 and ETHYL LIMA 1&2 are using the primary freq
341.750 but are way out of my range now.
RCH960 was 04-4133 C-17A
also earlier were
RCH373 02-1100 C-17A 6.30pm FL270
RCH374 01-0190 C-17A 7.45pm FL200
Also just noticed that RCH281 was through here headed Eastbound in the climb [FL290-FL330]
at 8.35pm and coming back Westbound at 9.55pm. Wondering if he had a problem.
jetcrafter
Southern Maine
1950 ABYSS 74 E-4B #74-0787showing level 31k
Thought I heard callsign JADE 44 with ZNY Kennedy.
Mark, nice logs!
I went back and listened to my recording, you were correct about JADE 44.
He gave ETHYL LIMA 1 his tail number in AR-20NE and it was indeed
74-0787 the same as your ABYSS. Hope this helps.
jetcrafter
Southern Maine
Adding a small piece to the pie.
Never did get SAM91, he must have headed up further north.
Just had RCH276 07-7180 C-17A with ETHYL[70?] 63-8003 KC-135R on the box, and
heard on interplane. RCH276 said he was just out of Charleston, only a couple of hours
into his day. Going to Rota, long day ahead.
8.30 to 8.45pm had KC-10A`s 84-0188 and 85-0030 pass through [SBS Team15 and Cabal81].
Possible these were the ETHYL L1/L2 from the E-4 earlier
Adrian, just to add....
I did hear SAM 91 check in w/ZBW on 133.450 at 0129z at FL310.
You were correct, it was ETHYL 70 with REACH 276.
The ETHYLs, L1&L2 were from Bangor. I only heard a small snippet from their tails but L1 started wit 59-
Reception was bad at that point and I thought it was 59-1436 and L2 ended with 1470. Very hard to pull them out
of the recording.
Hope this helps,
jetcrafter
Southern Maine
I thought I heard him on 128.75 then leave, then come back to it.....hmmmm. Your right, wonder if he
did have a problem. Last I heard him was on 124.525 ZBW.
TinEar
Glen Burnie, Maryland
of the recording.
Hope this helps,
Ed, I believe they were 59-1482 and 59-1470. Those two were logged by a Halifax station at the same time shortly after 2100 local. About 45 minutes later, 62-3506 from Pease was noted too.
Waltz41
Willow Grove, PA
2003 Also some comes on 363.300 listed as VMA-231 A/A
mentions he tried Dover,McGuire metro's with no joy.
Could be VMA 231 AV-8's flight southbound to Cherry Point.
SPADE 11 flight trying Andrews or any metro 344.600..nobody home!
Must be the Ace of Spades VMA-231
That would indeed be AV-8's from VMA-231. I'm guessing it was a flight of 3, headed home from Binghamton NY where they performed at an airshow. They stopped in at Willow Grove on Thursday about 1415 for a quick fill up, then onto Binghamton. Pilot said they were trying to get as close as possible to Binghamton with some uncertain weather, and KNXX was the stop.
One had the 'new' paint scheme, pilot said it 'looks rediculous, and just plain old makes no sense'. Supposed to only use two shades of grey instead of three, so a tatical 'weight' advantage. He said BS.
carbineone
0121 sparky 5 and sparky 8 with McGuire Departure 124.15 (Sparky 5 says he will be talking to ZNY and Boston center)
0125 Sparky 5 with ZNY says he will be the northern ship tonight working the coast and his sister ship Sparky 8 will be the southern ship 128.3
0138 Sparky 8 headed south with Sparky 5 now with ZDC on 125.45 says he will be MARSA with Sparky 5 and doing left turns. Sparky A/A is 255.7
0149 Sparky talking with Gypsy 314 asking if he can see him yet 255.7 I Cannot hear Gypsy might be a ground unit.
carbineone
0320 Sparky flights (RC-12S) are still up and keeping 50 mile distance between themselves on their pattern and talking to Gypsy 255.7
JohnFB
Western Mass
0121 sparky 5 and sparky 8 with McGuire Departure 124.15 (Sparky 5 says he will be talking to ZNY and Boston center) [snip]
Darn, I wish I had brought my scanners to work .... wonder if these were RC-12s? Had a couple of SUNNYs up this way in Feb I think.
mdmonitor
Egyptian C-130
Around 1300 EDT saw Egyptian C-130 landing at BWI---didn't have usual desert camouflage---but was in silver, white & blue color scheme---Egyptian flag prominent on the rudder.
jsoergel
JOSA 469 (C-21A, 84-0118) dropping off 2 pax (1 S4), 2 space A's going through; departed at 1302Z, asked Dispatch to pass on departure message to MacDill
PAT 533 (unid) called in but was scratchy, think he said it was a passenger pickup; departed at 1705Z and climbed quickly - might've been a UC-35; direct ROD before switching to ZID
NASA 806 (ER-2, N806NA) back on the ground just after 1730Z
The MOAs are hot right now, but I'm not hearing any A/A comms at the moment.
TinEar
Mode-S tells me it was C-130H, 1281/SU-BAM. Log began at 1247. This should have been flight EGY 1113 if they kept the numbering sequence in order. This is what it looked like in April:
Logged this today Ron..
(01007E) SU-BAM C-130H Egyptian Air Force 16Sq 2009/07/06 1651z-17:00z
callsign showing was jibberish Q1MFFF B
TinEar
A second Air Force air wing (451st Expeditionary Wing) stood up today at Kandahar, Afghanistan. Its commander is BG Guy M. Walsh who was plucked from the commanders role at Martin State. He led the 175th Wing before this new assignment. The other wing in Afghanistan is at Bagram. I wonder if he'll start plucking some of MTN's aircraft for a tour there?
This aircraft flying around at 2300-2700 feet the last hour.
squawking 1200.
(A22683) N238D Cessna 206H Dept of Justice.
