Sticky Thread For MilAir IV
mdmonitor
Some intermittent logs:
1805 EDT- Reach 372 on 141.55 w/Griffin for landing.
1843- Reach 359 w/ZDC Sea Isle (133.125)
1846- PAT 285- w/ZDC Sea Isle (133.125) & ZDC Salisbury (120.975)--at 1907 cleared to HARCM for holding.
1849- Reach 693- w/ZDC Casino (127.7)
1851- Reach 1195- w/ZDC Salisbury (120.975)
1852- Reach 841- w/ZDC Salisbury (120.975)--at 1855 cleared direct to JOBOC--at 1907 w/ZNY Oceanic (133.5) at JOBOC.
1852- Reach 359- w/Griffin (141.55)
TinEar
Glen Burnie, Maryland
1805 EDT- Reach 392 on 141.55 w/Griffin
392 or 372? He's showing RCH372 on Mode-S (C-17A, 04-4129, 6th AS McGuire). You fixed it so...nevermind. :)
There's also a SAM flight (5236 displayed) ahead of him on approach (C-37A, 99-0404, 99th AS Andrews)
1812: REACH 809R (C-17A, 89-1190, 437th AW Charleston) passing overhead at FL 340 (per SBS)
1813: Confirm...it's SAM 5236 reporting to ADW Twr on 5 mile visual for runway 1L...cleared to land 1L...standby for gear...118.4
1814: "SAM 5236 is gear down"...118.4 (SAM 5236 departed Andrews just after midnight early in the 0000 hour on 9 July and scooted off to Europe. Last two logs on that side of the pond before he showed up here were in Switzerland and Hungary so it didn't do the UK flight route.)
1820: REACH 6004 (C-17A, 96-0004, 437th AW Charleston) noted on SBS descending into the area.
1821: REACH 372 to ADW Twr for landing...visual for runway 1L...118.4
1826: Navy T-6A (165985, TW-6) overhead at FL 240 (per SBS)
1829: REACH 370 (C-17A, 92-3292, 437th AW Charleston) departing Andrews and climbing out. (per SBS and later on TRACON 125.65)
1834: REACH 369 (C-17A, 00-0178, 62nd AW McChord) departing ADW w/TRACON reporting at 1600 feet and climbing...118.95
I'm not hearing the transmissions from these REACH flights to ADW Tower as they takeoff and switch to TRACON. Either conditions are lousy today or they simply aren't making that report anymore.
1838: REACH 370 handed off to ZDC-Montebello and checks in there...121.675
1838: Have a KC-10A (showing HOIST 90) descending into the area (79-1712, 305th AMW McGuire) per SBS. Caught the end of a transmission on 319.4 but after he had given his callsign so not yet confirmed.
1842: HOIST 91 (KC-10A, 85-0033, 305th AMW McGuire) to BRICKYARD with arrival msg...30 minutes out, A-2 with 3 minor writeups other than "during boom retraction loud noise heard"...later adds no pax, no cargo...319.4 (So the HOIST 90 is probably correct for 79-1712)
1843: LOBO 338 (UC-35D, 166715, VMR-1 Cherry Point) noted climbing in the area from 14-23K. Not hearing him on radio - just SBS.
1850: WORLD 9637 Heavy (DC-10, N138WA) w/TRACON and climbing...118.95
1850: REACH 359 (C-17A, 04-4131, 6th AS McGuire) noted on SBS at FL 250.
1850: Also seeing SPAR 78 (C-40B, 02-0042, 76th AS Ramstein) descending into the area on SBS. (There you go Andrew)
1851: REACH 1195 (C-17A, 01-0195, 437th AW Charleston) noted on SBS at FL 330
1851: REACH 841 (DC-10, N612AX, Omni Intl) noted on SBS at FL 310.
1858: NAVY JU967 (C-9B, 159119, VR-56) noted descending into the area on SBS. [See item at 1905 for correct callsign]
I don't know about anyone else but I can't listen to both Potomac TRACON arrival and departure VHF freqs at the same time - just too much traffic. Right now I've got the departure freqs on...figuring I'll catch the arrivals on ADW Tower freq eventually. And that's the beauty of the SBS receiver. It gets them all no matter how many aircraft are operating in the area.
1902: SPAR 78 to Adw Tower for landing runway 1L...standby for gear...118.4 (confirming callsign)
1904: "SPAR 78 gear down for full stop 1L"...118.4
1905: NAVY JU242 [female] on the visual for runway 1L...cleared to land...118.4 (This is the one showing JU967 so callsign is corrected from SBS)
END OF LOG FOR NOW
Ref below: Finally got the VC-10 here Mark at 1818. Appears he was coming in from north of you. I tracked him on SBS down to 4,000 feet so he must have gone into Dover rather than McGuire....however, Travis says it landed at Dulles so that takes care of that.
I'm just reminded again what a great area this is for monitoring milair. We get more in an hour than most people get in an entire day. I can only imagine if I had an antenna on a tower above the oaks surrounding me.
1800 RRR 2320 VC-10 XV102 dropping down around here from 28k
to 20k.Should be ASCOT 2320.
1825 ASCOT dropped off my screen at 10k so not into Dover.
couldn't find anything on radio but typical busy time as well.
Alan He didn't go into Dover as I have those freqs loud and clear. I was thinking more
like Harrisburg or something like that.Nothing on CP freqs either.
A couple Mcguire KC-10's inbound Mcguire from West I believe.
HOIST 90 #79-1712
HOIST 91 #85-0033
Hopefully Shuttle will launch at 2113 local..
2100 Shuttle on wx hold and doesn't look good..storms within 20 mile area..
2102 NASA says Shuttle launch scrubbed for 24 hours...so close!
Ok Thanks Travis for ASCOT mystery landing spot..
freqhopping
ASCOT-2320 just landed at Dulles. Go figure.
I just came back to the computer after being out for a few hours to see it at 1600ft so I immediately tuned into Dulles freqs. At that altitude I knew it was too low for ADW.
1925- CONVOY-2471 164997 about to cross over IAD.
jsoergel
Cincinnati/Dayton, OH
I caught HOIST 90 (KC-10A, 79-1712) earlier calling Grissom Metro for weather for McGuire at 2300Z (same frequency as Patterson Metro).
Had SPAR 78 (C-40B, 02-0042) come in earlier and depart (heading 320 before the handoff to ZID).
Barely got BREW 71 (C-130H) switching from Dayton to ZID. I think they must've been off KDAY, because I didn't hear them departing Patterson. Wasn't sure of the type until I heard them chatting with the center controller and mention "No-Hope Pope." Over to ZOB soon after that.
ROMAN 87 (F/A-18?) called Patterson Metro, no response.
VADER 02 (C-130H, 89-9102) is in - maybe for an aeromed mission, but I didn't hear them call ahead like they usually would.
mdmonitor
Guess I got timed out--some more logs:
2115- Reach 0534 w/.ZDC Salisbury (120.975)--at 2122 reports they are direct to Dover
2117- Tazz 83 (KC-135R 121ST ARG OH ANG RICKENBACKER ANGB OH) w/ZBW Calverton (124.525) at FL350.
2119- PAT 285 w/ZDC Sea Isle (133.125) cleared to Hampton.
2135- Reach 889- w/ZDC Coyle.
2145- Reach 482- w/Griffin CP (141.55) w/inbound msg. At 2151 checks in w/ZDC Casino (127.7)
2220- Blackjack 1 & 2 (HH-65Cs, CGAS Wash)-w/Huntress (139.7) in intercept training.
Done for the night !!!!!!
Mateo
The Dee Sea
Isn't part of the usual mil takeoff clearance to depart and call departure? I know I've heard it from the ground side of NGU Tower while driving past. They seem to skip that part where Tower affirmatively hands them off. Certainly was a busy C-17 day today - I was at the terminal at DCA and saw one departing and heading south at 1714, as well as westbounds that passed overhead at 1807 and 1833. I can confirm the 1833 one was a McChord; the 1807 one was a bit further south, and couldn't see the band before it was lost in a sea of distortion and support beams.
TinEar
Yes, SOP is to switch to departure upon starting the takeoff roll...BUT...many, actually most, contact tower for the handoff once they go wheels up. That includes AF1. It may be because so many of the Andrews aircraft work with civilian airports in their travels and so get in the habit of doing it that way rather than according to mil guidance. In any case, I heard none of them today before showing up with TRACON.
Mateo
The Dee Sea
Yep, I've certainly heard any number of them call back on 118.4 "over to departure, good day" once they clear the ridge. Did you pick up anything on the other two C-17s I saw?
Also, for those of you who keep track of the USCG Dauphins, 6517 and 6552 were outside at DCA this afternoon. 6595 and 6598 were around last Monday. One of them was flying pretty low, searchlight blazing, about a mile WNW of the White House around 0115L last night. Wasn't anywhere near the river, either.
JohnFB
Western Mass
John,
SBS evidence indicates that your mama IDF 100 was 275/4X-JYV B703 IDF.
Tony
tnx for the ID and tnx for the info on Hebrew v Yiddish from everyone.
And any idea on the ID of the chicks and how many ... ???
EDIT: Never mind ..... I remebered the Nellis Flt Ops site ...... FWIW
Red Flag Participating Flying Units
13-24 July 2009
Day/Night Launches
Red Air
F-16CG, Nellis AFB, Nev.
F-15C, Nellis AFB
Blue Air
F-15C/D, Mountain Home AFB, Idaho
Interdiction
F-16CG, Toledo, Ohio (Air National Guard)
F-16C, Israeli Air Force
Suppression of Enemy Air Defenses
F-16CJ, Shaw AFB, S.C.
Command, control, intelligence, surveillance, reconnaissance
E-3, Tinker AFB, Okla.
Aerial Refueling
KC-135, Fairchild AFB, Wash.,
KC-135, Scott AFB, Ill.
KC-135, RAF Mildenhall (U.S. unit)
Number of aircraft: 62
JohnFB
Western Mass
At 0855 EDT also noted working on 347.2. This is MD ANG CP freq at Martin State but Gold 71 sounded like he was working some sort of ATC controller.
1231Z/0831L : GOLD 71 clg "Raven Ops" on 347.200
Does Martin State CP use "Raven?"
JohnFB
Western Mass
DEALER 902 calling McGuire Metro twice at 1710 local on 239.8 with no joy. (Never heard DEALER before)
Pete
I heard him also, clg WRI WX for almost 15 mins repeatedly. Don't know why he didn't try someone else ......... I never caught him with ATC, however.
Certainly was a busy C-17 day today.
Yes has been a constant parade of POTUS support flights
of C-17's inbound all weekend from overseas.
0430 this morning REACH 361 C-17 #06-6157 Travis inbound
Quantico on their ops req c/ag.Prob to drop off choppers.
CitationJet
Northern Virginia
Re: CNV 2471
Hop,
I heard this as CONVOY 3471 - 119.850 @ 2330Z right over the house.
SBS log from out west seems to confirm that I heard it right:
2137Z
[_______] / C-130T / 164997 / ANDREWS AFB-NAF
MODE-S / AE03E4 / (CNV3471) / FL280, 260 / 2546
Tony
TinEar
Yes, they sure do. RAVEN is the CP callsign for the 175th Wing. It's also the squadron callsign for the A-10s of the 104th FS. The 135th AS at MTN (C-130s) use CRAB for their squadron CP call. The morning in question, we had six A-10s departing from Martin State as MAZDA 21-26 and a whole gaggle of tankers as GOLD. GOLD 71 met them at Sea Isle and 61 and 62 were loitering at ACK awaiting their arrival.
TinEar
Here's my SBS log so far today...
69-5825 ALLIED 1 12:24:01.008 C-130 USAF
159114 RS114 12:21:04.694 C-9B VR-46
62-1836 KING 31 12:20:14.526 EC-130E 55W/
------- ------- 12:19:33.498 C-130T VR-53/AX
86-0035 TEAM10 12:16:32.060 KC-10A 305thAMW
79-1710 RCH9710 12:15:29.332 KC-10A 305thAMW
02 C102 12:11:25.603 C-143A CGASWashington
85-1265 ------- 12:09:53.112 C-12T VARFC
84-0062 RCH4062 12:07:23.500 C-5B 436thAW
79-1710 RCH9710 12:07:05.127 KC-10A 305thAMW
86-0035 TEAM 10 12:06:06.523 KC-10A 305thAMW
69-5831 WAXEN65 12:04:50.764 MC-130p 352SOG/67SOS
------ ------- 12:00:24.696 T-6A NTPS
83-1285 ------- 11:58:17.757 C-5B 436thAW
159114 RS114 11:56:55.172 C-9B VR-46
01-0030 ------- 11:48:16.775 C-37A 310thAS
163691 ------- 11:47:35.545 C-20D VR-1
04-4135 RCH128T 11:46:13.242 C-17A 6thAS
01-0040 VENUS30 11:41:24.656 C-40B 76thAS
XV102 RRR2320 11:36:48.250 VC-10/C1K 101SQ
------ ------- 11:34:22.250 T-38C NTPS
83-24149 ------- 11:32:31.250 C-12D USARMY
161309 ------- 11:25:34.640 UC-12B Washington
------- VVCOD02 11:21:32.250 ----- -------
84-0092 ------- 11:16:35.750 C-21A 457thAS
161319 ------- 11:10:53.484 UC-12B WillowGrove
165962 ------- 11:08:42.250 T-6A NTPS
96-0006 RCH371 10:59:57.250 C-17A 437thAW
84-0077 JOSA397 10:54:30.765 C-21A 457thAS
78-0807 ALLIED 1 10:53:51.250 C-130H AFRC/911AW/758AS
160047 LOBO2 10:48:51.265 C-9B VMR-1
00-0182 RCH493 10:48:40.578 C-17A 62ndAW
160047 ------- 10:45:25.578 C-9B VMR-1
163691 ------- 10:40:02.250 C-20D VR-1
166715 ------- 10:39:25.250 UC-35D VMR-1
99-0404 S5236 10:09:39.359 C-37A 89thAW/99thAS
02-1863 PAT63 10:07:09.859 C-37A OSACOM/PAT
61-0294 BACKY11 10:01:07.250 KC-135R AFRC/916ARW/77ARS
------ ------- 09:38:51.250 MC-12W ---
84-0188 TEAM11 09:32:33.656 KC-10A 305thAMW
83-1285 ------- 09:29:32.265 C-5B 436thAW
86-0035 TEAM10 09:29:25.812 KC-10A 305thAMW
62-3556 DECEE11 09:27:08.906 KC-135R AFRC/459ARW/756ARS
160050 JT050 09:23:51.250 C-9B VR-52
161326 ------- 09:23:37.656 UC-12B Patuxent River
02-1111 RCH363 09:22:25.546 C-17A 62ndAW
160048 ------- 09:12:50.078 C-9B VR-52
161501 ------- 09:10:22.703 UC-12B Patuxent River
N810AX RCH295 09:09:33.250 DC-10 OmniAirInternational
84-0145 ------- 09:09:18.015 C-12T OSACOM/PATDet7DEArNG
N65327j JENNA094 09:04:29.984 C-206 FBI (Tail is wrong. Anyone?)
02-0203 BOXER 45 08:53:14.187 C-40C 201stAS/DCANG
166378 VV400 08:50:33.109 C-37B VR-1
CitationJet
Northern Virginia
Re: SBS Log 07.13.2009
Hi Tin,
ASCOT 2320 departed rwy 19L @ KIAD on 120.100 at around 1525Z and was switched over to PT DEP 126.650.
Re: 85-1265: Scramble has this as WV ArNG EAATS Det. 1. Confirmation of it now being VA RFC and if so, based where?
I've seen two C-12s in your recent logs listed as VA RFC, this one and another one which escapes me at this time (EDIT: it was 86-0084). I'm curious as to where this information is coming from.
Thanks,
Tony
jetcrafter
Southern Maine
Been listening to BADLY 07 working his way inbound to land at Bangor.
He is currently working Bangor approach on 118.925 at 1713z. Sounds like
prop noise in the background and is a slow mover. Been descending for awhile.
Also just had two tankers from Pease, ETHYL W3 flight, take off and are heading to up to a final
block of 32-33. They've been using 341.750 as their A-A on the way up. Must be heading to AR-20SW as
the SUA website has it active at 1750z. Might be meeting up with the RAMA flight but I'm not sure.
I have a Coast Guard Aux 27G passing through from N to S working Boston app on 118.500
Also COAST GUARD 2133 inbound to land at Pease.
1719z ETHYL W3 flight just switched to Moncton Center on 127.125
