TinEar
33 degrees and partly sunny at BWI at noon
1211: BLUETAIL reports to ZEUS that it's time for him to RTB. He says he can stay in the net for another 15 minutes but will start his RTB now. «280.6»
1212: BLUETAIL tells ZEUS he hopes they were able to provide him some good help with their work today. They were obviously testing a DATALINK and trying to follow various tracks that ZEUS put up for him. «280.6»
1214: Have a SHERIFF 1 with Andrews Approach on «119.3» (Whose sheriff department has an aircraft in this area - probably Northern Virginia area since I know of none in Maryland?)
1222: BLUETAIL tells ZEUS "we can leave it on until we get a little further south." I guess he means whatever piece of equipment they were testing. «280.6» (This was the last transmission heard from BLUETAIL.)
1227: TARA 97 (Unk) coming into Andrews...says he'll be there in 23 minutes. «141.55» Gives his tail # as 09001 which is also what he reported when he came here on 10/13/05 under the TARA 91 callsign. The following is from Joe Baugher's website:
A Boeing 757 was photographed at Capetown AP, South Africa Aug 3, 2003,apparently unmarked except for the 'tail number' (actually carried on the rear fuselage) '09001' (which may be 00-9001 or may be spurious). Plane with same tail number seen at Stuttgart, Athens, Naples, central Asia, Sofia, Helsinki in Nov 2003. Seen at Edmonton, Alberta May 2005. Aircraft allegedly operated in support of US State Dept's Foreign Emergency Support Team.
1231: DC-ANG F-16s active on tac «127.275» Callsign WILD, flight of two.
1231: PACER 24 with Andrews Approach on «119.3»
1232: BOBCAT 2 with ZDC-Patuxent on «281.4» heading for Andrews
1233: WILD 1 with ZDC-Paatuxent on «281.4» at 15,000 ...push 305.2
1235: WILD 1 flight with BayWatch on «270.8» they want surface to 20,000
1238: WILD push 344.4 (which is a BayWatch freq) «127.275»
1238: WILD 1 says they are 13 out «344.4»
1240: WILD 1 says gear up speed is 240 knots...WILD 2 mentions high winds. «127.275»
1242: WILD 1 says with those winds he doesn't have enough energy...WILD 2 says, "I'd expect that with the gear down and I still don't have mine down." «127.275» (Are they landing at Pax River?)
1251: U/I female pilot (sounds like a fighter and I just can't catch her callsign) leaving Andrews at 1K, then 3K then cleared to 11K at 1253. Working Reagan TRACON «257.2» She requests Uniform freq.
1254: She's cleared to Gordonsville «257.2»
1256: She then goes to ZDC-Bucks Elbow Va on «284.7» thru FL210. Her suffix is 94 but still can't get the callsign.
1259: Well, the WILD flight didn't land at Pax River...they're still flying around the Pax River area using tac «127.275» Doing air combat exercises.
1305: DEVIL 11 flight (F-16 NJ-ANG Atlantic City) with ZDC-Sea Isle on «285.4» mention direct Richmond
1305: BOLAR 50 with Dover Command Post on «349.4» arriving Dover in 15 minutes and has writeups.
1307: That suffix 94 female still doing her thing on «284.7» and will push 351.9
1308: Sure enough, she comes up on «351.9» with ZDC-Green Bay VA checking in and I stilll can't catch her callsign. Along the way, she mentioned direct Greensboro.
Okay...it's break time....I currently have six scanners going and every one of them is full of activity...can't possibly keep up with it and the noise is driving me outside to enjoy the cold, clear air. Be back in a bit.
