1400: DC 22 reports to LIBERATOR he'll be out until 3 and fuel is 50K
1401: BANGER 21 flight (F-16 NJ-ANG) also going to BayWatch area and contacts DEVIL flight leader on «138.425» per orders by KINGPIN. DEVIL tells him to hold at 17,000
NOTE: I've heard this KINGPIN call before from the NJ guys. I think that's their SOF callsign comparable to SENATE for the DC-ANG.
1402: DC 22 calling LIBERATOR again on «351.2» no reply to a couple of calls
1403: BANGER flight working «138.875» tac
1406: BANGER 21 flight into BayWatch area on «270.8» says they'll be at altitudes 3500-35000 and will be MARSA with DEVIL.
1410: BANGER 21 flight moves to «138.425» with the DEVIL flight and contacts WARDOG (who is one of the DEVILs) for targeting info.
1412 and beyond: BANGER/DEVIL/WARDOG in ground attack on two semi trailers on a 4-lane divided highway. Their mission is to wipe them out. Of course, the two truck drivers are merrily driving down the road not having a clue that warplanes have targeted them for practice bombing. Next target is a tanker truck.
1425: A-10s from the MD-ANG Martin State up on tac «142.3»
1426: BANGERs finish their attack and go back to V-17 on «138.875»
1428: BANGER flight mentions two A-10s below them and climbing (the Martin flight?) «138.875»
1428: MD A-10s in ground attack exercise...still no callsign heard. «142.3»
1431: MD A-10s mention changing to Patuxent V-11 «142.3» They're level at 14,000 feet at this time. They mention trying an attack "that was in the book" but one of them is having trouble with his pod. (I didn't hear them on a Pax River freq)
1433: WILD flight of 4 F-16s still doing air combat exercises...«127.275/139.15»
1435: Have someone talking on Pax River freq «119.275» about the BANGER flight in R-4006. It doesn't sound like the A-10s and it's not any of the NJ guys.
1437: WILD flight leader to SOF on «139.9» mentions another half hour of work. They mention something that was supposed to start "at 20 but is not starting until 45" over on «127.275» Flight leader tells them to set "bingo" at 1600 pounds. He's going over to V-6 to talk to WILD 3/4.
1438: The "something" is a ramp freeze at Andrews which is going to start at 45 after the hour and go for half an hour per WILD 1 to WILD 3 on «139.15»
1441: WILD flight leader goes to SOF freq «139.9» and calls JUSTICE. (Not sure if that's a name or a new SOF callsign.) WILD 1 reports he has 45 minutes fuel left until he has to go to Pax but WILD 2 only has 20 minutes until bingo. He asks if SOF can make some phone calls and "shmooze" to get them permission to land at Andrews in spite of the ramp freeze.
1445: Sounds like they've been cleared to land and are heading for the field...in a hurry. Again WILD 1 calls JUSTICE on SOF freq «139.9» say they are going to stay on this freq to get "first hand" info...both report Code 1. #2 goes for ATIS, reports runways wet. #1 does the Potomac TRACON things and comes right back to this freq.
1447: BANGER flight still in ground attack mode on tac «138.875» and DEVILs on «138.425»
1450: AirEvac 164 to Andrews on «141.55» 30 minutes out, Code 1, needs fuel and wants Andrews to ask AirEvac Ops for upload pallet info.
1452: NJ flights working with ground controller SNAKE. He mentions that SNAKE was stepped on by the RAVENs which just might be out MD-ANG A-10s.
1453: WILD 3 to SENATE on SOF freq «139.9» giving mission results. WILD 3 is Code 2 for targeting pod, WILD 4 is Code 1 and they want status of ramp freeze. "Okay, on the hour," is his next statement. They then go back to V-6 on «139.15» and say it'll be okay if the ramp freeze is over on the hour.
1456: Ref the item at 1435...that "someone" was probably a tanker. Heard an aircraft mention RTBing to McGuire that sounded like the same guy. «119.275»
1500: TESTER 16 with BayWatch on «270.8» And a TESTER 26 on same freq.
1502: WILD 3/4 with SOF on «139.9» mention they are planning for landing at Pax if they can't get into Andrews.
1503: WILD 4 says if he goes to Pax, he'll land with only 300 pounds...WILD 3 says to let him know when he's at 1500 pounds. Of course he will. «139.9»
1504: DEVIL/BANGER flight doing buddy lase attacks on ground targets under control of SNAKE.
1505: WILD flight looks like they got cleared into Andrews....WILD 2 did not land earlier with WILD 1....WILD 2 now declares emergency for low fuel and is cleared directly onto runway 1R on «349.0» with WILD 3 and 4 following closely behind.
1506: Various TESTER aircraft working Pax River freq «392.675» for their ops
1508: WILD 2 just setting down on runway 1R..others right behind for full stop. (Those ramp freezes at Andrews sure cause some nerves to rattle. I've heard this same situation happen in the past with the DC F-16s running out of gas.)
1511: DEVIL flight reports he and BANGER flight will stay below 19,000 «270.8»
1511: DEVIL/BANGER back to ops on «138.875» says they'll stay below 19K and will be over Vienna (MD) they then give coordinates of their targets.
1513: DEVIL/BANGER flights operating very close to extreme limits and want ground commander's initials for a "danger close" report. This is about the third time they've reported/requested that same condition during this flight. (I sure wish I could broadcast this attack. It's a simulated Iraqi situation. There is a sniper atop a minaret that is their target...it's really the Vienna water tower.) «138.875»
1518: Had an aircraft ???? 5 (missed callsign) into BayWatch area on «354.8» and reports he's a single F-10 and will be in the area for 90 minutes.
1521: MAPLE 14 (F-16 VT-ANG Burlington) with ZDC-Green Bay VA on «351.9» says he's direct Gordonsville.
1524: FUZZY 22 (KC-145, 136th ARS NY-ANG Nigara Falls) to McGuire Command Post on «319.4» landing in 30 minutes.
1526: Bollen Range in the Kiowa MOA is active on «237.2»
1529: DEVIL flight back to their own tac freq «138.425» for more ground attack.
1530: MAPLE 14 reports over Gordonsville, direct Shaw «351.9»
1531: LOBO 13 calling Command Post on «139.3» (Might be a C-9B from Cherry Point)
1532: WARDOG and RAVEN are the A-10s from MD-ANG Martin State at the Bollen Range on «237.2»
1535: BANGER flight on «138.875» mentions seeing some aircraft in their area...one of them says, "It's beautiful," while the other says, "Love that paint job." I wonder if they are seeing that F-10?
1537: DEVIL flight reports direct Atlantic City at 15,000 to BayWatch on «270.8»
1538: Again the BANGER flight mentions seeing that aircraft descending rapidly going past them. One says..."Damn...that's fast!" «138.875»
1540: Now one of the BANGERs mentions passing a "Buckeye" which I guess is a T-2, two-place trainer.
1542: DEVIL 11 flight with ZDC-Sea Isle on «285.4» and then "push 6" to get to Atlantic City Approach on «327.125»
1542: DEVIL and then BANGER both took a turn on ops freq «261.0» to report status
1543: BANGER flight with ZDC-Snow Hill on «256.8» 15,000 feet direct Atlantic City
1543: RAVEN 1/2/3 all at Bollen on «237.2»
1546: BANGER 11 (who is really 21) with ZDC-Sea Isle on «285.4» descending to 11,000
1547: AXEMAN 1 and 2 (A-10 MD-ANG) coming home to Martin State with Raven Ops on «347.2»
1548: BANGER flight down to 8,000 with Atlantic City Approach on «327.125» Has ATIS info Lima. That pair of F-16s is still chatting on tac «138.875» while heading for the runway at AC.
1550: AXEMAN with Martin Tower on «297.2» reports as flight of two coming in for a full stop landing holding hands to runway 33...no reply so he repeats it on VHF tower freq «121.3»
1552: RAVEN 3 reports into Raven Ops on «347.2» with Codes for all three aircraft 1/2 are Code 1 and 3 is Code 3
1558: RAVEN 1/2/3 landing with Martin State Tower on «297.2»
1559: MISTY 01 (many choices for this callsign) with Reagan TRACON on «343.7»
1600: Now that WILD 1/2/3/4, DEVIL 1/2, BANGER 1/2, AXEMAN 1/2, RAVEN 1/2/3 are all nesting for awhile, it's time to get out of here. Sure wish I heard more from that guy that IDed as an F-10.
