Absolutely would appreciate anything you can add Dave from your location. I know I've heard the Martin State A-10s go to Duke and then stop at Kiowa (Bollen Range) on the way back. When the DC-ANG F-16s do it though, they seem to perform strictly in that area and then come directly home. I didn't realize they were refueling up there also but it makes sense because of the distance involved. They wouldn't have much time on target without refueling.
1247: CODY 01 (AFRC/911th AW, 758th AS, Pittsburgh PA) to McGuire Command Post on «349.4» IDs as a C-130, tail #86-0419, arriving at 1805Z, will RON, needs a power cart, parking spot and crew transportation for 8 and will need 30,000 pounds of fuel.
Also found some info on this plane....undercarriage failed during approach to Roosevelt Roads, Puerto Rico Mar 21, 2001 and starboard wing was damaged and fire broke out in number 4 engine.
1345: Caught the end of a transmission from an U/I aircraft to Raven Ops on «347.2» Female speaker said they would ERO and needed transportation for 19 pax.
1407: REACH 984 calls Andrews Command Post on «378.1» a couple of times and then makes contact at 1413. Says he's an inbound C-17 that will arrive at 20 after the hour, cargo (blocked), 1 pax to offload and needs transportion for 7 crew members.
1422: REACH 3127 to McGuire Command Post on «349.4» inquires about status of parking spot (which also means he already contacted the CP with basic info) and he notifies McGuire that he has hazardous cargo on board...class 9 and class 3.
[Edit] Dave, I don't see either of those two freqs under the Cleveland Center list in the database here at RR - or for NY Center either. I go to the the database, select Ohio, and under the list of counties is a link for Cleveland Center ARTCC. I think that's telling me that the database list is wrong. If so, hopefully I'll be able to update it soon.
Now that you added more Center freqs, I went to look them up and none of those are on the list for Cleveland Center. I found only one of them - 323.2 - and that's listed for Indianapolis Center. I've got to get the latest frequency lists. That's all there is to it.
