Summit County 800 System
KWs
Kent , Ohio
The 853.1125 frequency is not a Summit control channel after rebanding. I believe that will be corrected soon in database.
My info from Mike Szabo back in May re: CC.
Old New
855.2625 855.2625
853.5125 858.7125
853.3625 858.5125
853.1125 857.9625
can't format this correctly, but the first column is old, second column is new.
fpo701
OH DB Admin
Akron, OH
Ed,
That corresponds to what I am seeing. I've removed the extra control channels.
xusmarine1979
Louisville, Ohio
Hey guys, does anyone know what's going on with the system? I'm not picking up a CC, and I'm hearing S.O. units testing radios on ECOMM 8 and 9 on MARCS... just fyi.
KWs
Kent , Ohio
It was a total system failure ... System was restored about 10:20.
MARCS is the designated backup.
jimmyo
Cuyahoga Falls, Oh
Cuyahoga Falls
Since the rebanding, i haven't been able to pick up channel 1 or 2 in the talk groups. I've downloaded all the current talk groups thru RR, but still no 1 or 2. Anybody have any updates or info?
KWs
Kent , Ohio
Nothing changed TG wise . no problem with hearing here.
Are you getting other Summit /Akron TGs ?
Check and be sure you don't have them locked out.
I have Cuyahoga Falls programmed in my scanner but normally don't have it enabled. I did enable it tonite after seeing your post and can confirm I'm getting PD Ch1 TG 39280 here.
jimmyo
Cuyahoga Falls, Oh
Yes I have and receive all of Akron and Summit Co fine and nothing locked out, just thought i was missing something because yesterday they said go to secondary (39312) and i received nothing. 39280, main dispatch I'm receiving fine.
kd8mvc
Twinsburg, Ohio
Wonder if someone could help me with this, using a pro-106 on the Summit System it stops on a TG but no voice hearing only a few TG mostly analog nothing for Akron or Summit County SO heard Mosquito Control and the telemetry TG's this morning and that's it, the problem seems to have started when I entered the freq's from the latest update it was fine before that.
jimmyo
Cuyahoga Falls, Oh
Mine seems to be working great now and i scan most law, fire and ems in the summit county area. I would be glad to send you a copy of my p500 file if i knew how!
Making note of the close distance of your QTH and the location of the Twinsburg site, I wonder if it's overloading your scanner. I'm not familiar with the 106. Is there an attenuator? Perhaps just take off the antenna and see how it is. Or just use a paperclip as an antenna for a test.
a388sig2
Suddenly Silent
PSR800, Hudson area, monitoring SO.
I'll see data, on both the scanner and in Unitrunker (separate SDR dongle receive), but receive no voice. Seems voice is intermittent and sporadic.
Updated with the control channel and alternates, have tried various antennas, but no joy.
Seems to be a recent phenomenon.
No problem here. Have 15 hits since 0830, latest at 1026. Scanning lots of stuff, but SCSO seems normal. Twinsburg site is full scale.
wa8pyr
Staff member
Lead Database Admin
Ohio
Ed,
Frank,
That's the rebanding change/correction we discussed. I suspect that 853.1125 will disappear from the Summit license before too much longer.
a388sig2
Summit County 800 System .
Ed,
Full voice call hits?
a388sig2
