Summit County 800 System
kbigdog
Ohio
I am also having problems. Pro 197....updated firmware to 2.1 downloaded new rebanded info from radioreference software ARC 500. this is what it is downloading as:
FREQUENCIES:
853.1125
853.3625
853.5125
855.2625
LO HI OFFSET BASE STEP
440 759 440 851.02500 25
0 719 0 851.0125 25.0
720 759 0 848.000 25.0
815 831 0 846.625 25.0
958 958 958 868.975 25.0
961 1022 0 843.400 25.0
These are all set in the new rebanded software.
Also it downloads at Motoroloa UHF/VHF.......I tried changing it to Motorola 800/900 with no luck. Please help. Its Friday and 75 degrees out there bound to be alot to listen to this weekend.
I don't have a Pro-197 but I assume someone here does and could send you the programming. The old and new main CC is 855.2625. I had word that the changeover to the new rebanded frequencies was May 23. Although it may be changed already or partly so. I have a 996XT and the active CC today is 855.2625 whether they are narrowbanded or not it's working for me. I have both the old and new CC freqs in mine.
It's very active at this moment...
jojo1064
Akron OH
What I dont understand is that my 996 was not functioning correctly, but my 396 was. I copied over the programing from the 396 to the 996, still no luck. I then had to change to a custom band plan. I cannot figure it out, but it seems like something is slightly off in the RR DB. So far it seems to work and my feed is live again. I have a feeling more things will change before this is all said and done.
fpo701
OH DB Admin
Akron, OH
Mike,
Did you make sure to put the custom band plan in like KWs noted above?
I reprogrammed my HP1 this morning, having already converted my 396XT a day or so ago. I did get some add traffic for a bit this afternoon. Rebanding is in progress, so there may be some hiccups along the way. Things seems to have returned to normal as of 4:30.
kbigdog
Ohio
Well it was the perfect storm for me. The Twinsburg tower moved, the county rebanded, so I assumed my problems were related to these. I had time to take my scanner apart and 1 little wire to my antenna was loose. It works great now. Thanks to all for your help. If nothing else I learned a lot while troubleshooting this. Also thanks to jojo for the APD feed. I always listen when I'm not near my scanner.
fpo701
OH DB Admin
Akron, OH
I removed the custom band plan that was in the DB for Summit. It was messing with the import ability of some software packages. Most software understands the reband flag and sets the plan correctly.
If you need the details on what to set, see Software Support for Uniden Rebanding - The RadioReference Wiki.
That should clear up some of the monitoring issues people were having.
KWs
Kent , Ohio
Nasby
Ohio
Anyone know what the MAC and MERC talkgroups are used for?
Are they listed in the Summit Co. database?
KWs
Kent , Ohio
Yes, they are all listed in database.
MAC is used everyday regularly for mutual aid incidents / tactical ops both FD and PD.
MERC is used infrequent, mostly FD ops for large scale incidents like trench rescue.
I believe these TGs are going away, to be replaced with new TGs under rebanding. Don't know new TG IDS yet.
FYI new CC for rebanding went in effect today .. 857.9625.
MotorolaDave
Brunswick, Ohio
Heard a Norton unit advise his supervisor that his portable radio displayed out of range and was making a long buzzing noise. Looks like someone forgot to reband that portable!
Nasby
Ohio
Thanks for the info KWs. I was wondering why I wasn't hearing summit County.
85chevy4x4
Would anyone mind posting a simplified version of programing a Pro-106 for the rebanded Summit County System? The rebanded setup posted on page 3 is a bit confusing to me, not sure what numbers go where in my scanner. It would be much appreicated.
aPod
If you are able to use the ARC software for your scanner (ARC-96 for my pro-96) it was pretty easy. There may be a way that is easier; I don't know anything compared to the other people on here. In the software, I just went to "settings" under the bank that I wanted to reband. After clicking on settings, go to "edit multi tables" at the bottom. When this opened, I clicked on "Load Reband Tables" then clicked OK and uploaded it to my scanner. Hopefully this will help you out a little bit but I'm sure that there is someone else on here that probably knows an easier way.
85chevy4x4
I vaugely remember when the Richfield system rebanded, I was able to reprogram my scanner for that. Problem is now I dont remember how I did it.....
fpo701
OH DB Admin
Akron, OH
One note for everyone having problems even using a custom band plan and the new control channels. I've seen some Yahoo Group posts from users experiencing the open mike issue and comm bleed-over. There are two things to check:
1) make sure End Code is not being ignored (thanks JoeM)
2) make sure squelch isn't too low that the radio can't detect the end code (thanks UPMan)
kraftwrk
I have the GRE-800 and tried updating the database and reprogramming the scanner. I live in Cleveland and used to pick up Summit Co., no problem. Now there's nothing. Does that have to do with the rebanding? Sorry for the novice question, but I am kind of new to this and rebanding.
KWs
Kent , Ohio
Make sure you have the new control frequency programmed ...857.9625.
StarkFlyer
Canal Fulton
I have a PRO-106 and was reprogramming it to receive the Summit system. It had also been programmed to receive the Start/Canton system. These are two seperate TSYS programmed into the scanner. I could not get the Summit system to work until I noticed when analyzing the summit frequencies that both 853.1125 was a control frequency along with 857.9625. 857.9625 when analyzed showed as Summit's control. 853.1125 when analyzed is Stark/canton's control frequency. I changed the 853.1125 in Summit's system to 851.0375 (just to make it different). Now I can receive both Summit and Stark/Canton. Per the DB 853.1125 is an alternete control frequency for the Summit system. Will this be a problem in the future?
Side note: when analyzing 851.0375 I heard morse code.
