BCD436HP/BCD536HP: Talkgroup Issues
Bolts2013
Frederick
I am having trouble scanning and programming talkgroups. I have tried reading the manual and have tried doing everything manually and even with the Sentinel software. But the main problem is I cant hear or my scanner wont pick up the talkgroups. I used to use the BC125AT scanner but then I upgraded to the BCD436HP. I have tried looking this stuff up online but couldnt find many answers or videos. I did not think this scanner would be that hard to setup and program. So any help would be greatly appreciated.
drdispatch
If 1000 hertz, think what 1 gig must feel like
Fightin' River, Michigan
First things first.
Is the system you're trying to program using simulcast in your area? Are the departments/talkgroups you are trying to monitor encrypted?
Post a link for the RR page of the system in question, and we can help you figure it out.
Whiskey3JMC
Surfer of the Delaware Valley Airwaves
Simulcastylvania, TE
Hi & welcome to the RR forums:
Taking a look at the database for Frederick, MD & focusing on this trunked radio system, I'm seeing there are simulcast cells contained within. Have a read about simulcast distortion, it's one of the most discussed technical issues here on the forums. It seems to fit what you're describing pretty well & can really wreak havoc on a non Uniden-SDS series scanner. Basically most scanners lock up, stutter, sputter, etc when dealing with the same frequencies coming from multiple different TX sites at the same time. The Uniden SDS100 & 200 are the only currently marketed scanners designed to mitigate the effects of simulcast distortion. There are workarounds for other scanners mentioned in the wiki I linked but they work in very few cases
Bolts2013
Frederick
First things first.
they aren’t encrypted and some are using simulcast and some aren’t.
I already did all that and nothing worked.
First things first.
wtp
Port Charlotte FL
why not just listen to the regular system and turn off the simulcast to hear the difference ?
if you listen to two it would be hard to tell.
drdispatch
If he can't receive that Brunswick site, turning off the simulcast will result in hearing nothing.
tvengr
Well Known Member
Baltimore County, MD
Try setting the squelch to 2.
wtp
Port Charlotte FL
my take on that, drdispatch, is that he has more than one thing running.
wtp
Port Charlotte FL
i don't know how many things you have going but the old saying here is
the more you try and listen to, the less you hear.
that is your radio could be doing other things and you are not hearing the stuff you want.
i have many older radios doing other things and i listen to my counties trunking system on one radio an only have that system running.
Bolts2013
Frederick
ok thanks!
